TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 9, 2018 at 9:19 AM
    #9221
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    There is an easier way..
    That's what you wanted to hear right? :bananadance:
    Everytime I work on my junk I curse. I have just accepted it as a constant truth at this juncture in my life.
  2. Nov 9, 2018 at 9:22 AM
    #9222
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Haha. In all seriousness, how do you guys get at that tensioner without taking the fan/shroud off. It’s no biggie to take them off but shortcuts ard nice!
  3. Nov 9, 2018 at 9:26 AM
    #9223
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My dude, I get at my beef tensioner with the decreased effective working area without having to remove the fan. It is very doable.
    Then again I've been called Gumby on this thread before so I guess I make a lot of things normally not possible without removing x and y other items off, possible.
    I use a large 1/2 rachet and when that wont give me the leverage I need to finish the job I use a 1/2" non ratcheting breaker bar which is a little longer than the rachet. I usually just rest the rachet inside of my BAMF 1/4" skid plate to hold the pressure of the tensioner while I do the routing I need to do of the belt to put it back on.
  4. Nov 9, 2018 at 9:38 AM
    #9224
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    A ratcheting wrench was low-profile enough and worked for me... it's tight but maybe I have small hands or something.
  5. Nov 9, 2018 at 10:15 AM
    #9225
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I remove the skid plate and go in from the bottom with a 1/2" ratchet. Its a tight fit and you have to have the mechanical fan in a certain position so the ratchet can clear some of the cooling fins on the fan clutch, but its doable. Then I use a pipe extension to hold the tension and remove the belt.
  6. Nov 9, 2018 at 10:17 AM
    #9226
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is exactly how I do mine. There is a space in between the fan clutch and I place my rachet or breaker in between those locations to provide additional slack to the tensioner to be able to slide the belt on and off.
    JacksonTacoma[QUOTED] likes this.
  7. Nov 9, 2018 at 10:18 AM
    #9227
    Speedwaytacotuesday
    Calgary, Alberta
    Thank you all!
    I will try these methods for next time
    Athlaos[QUOTED] likes this.
  8. Nov 9, 2018 at 10:36 AM
    #9228
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Harbor freight tensioner bar. I bent it slightly to fit and the fan has to be in a certain position but it makes it easy to do from the top of the engine. I'll post a pic on Monday when I get home if someone reminds me.
  9. Nov 9, 2018 at 10:39 AM
    #9229
    Speedwaytacotuesday
    Calgary, Alberta
    Great! We have a similar place for cheap tools here.. called Princess Auto. Tools that don’t commmand any real amount of quality, that’s the place to hit.
    Roostfactor[QUOTED] likes this.
  10. Nov 9, 2018 at 11:09 AM
    #9230
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    yes, it butts right up against the hole in the inner fender where the stock air take went.
  11. Nov 9, 2018 at 11:12 AM
    #9231
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
  12. Nov 9, 2018 at 11:15 AM
    #9232
    richiep
    Rich
    NY
    I use a 1/2" breaker bar, I gently slip it into the square of the tensioner, yes, I have to sometimes rotate the fan to get it in between fan blades, but once it's in, there is room to swing it to get the belt off & on.
    Roostfactor, Norton and Athlaos like this.
  13. Nov 9, 2018 at 11:17 AM
    #9233
    richiep
    Rich
    NY
  14. Nov 9, 2018 at 11:21 AM
    #9234
    DocME
    California
    '07 FJ Cruiser
    Yeah, I've broken three Harbor Freight specials. They tell me it's not supposed to be used as a breaker bar.....I used this gear wrench tool for the cam gear swap, it's very stout. I give it :thumbsup::thumbsup:
    Roostfactor and richiep like this.
  15. Nov 9, 2018 at 11:24 AM
    #9235
    richiep
    Rich
    NY
    does the handle it self ratchet?
  16. Nov 9, 2018 at 11:24 AM
    #9236
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    This guy showed up and started grinding on my truck.
    He really likes Tacomas. :dancingbacon:
  17. Nov 9, 2018 at 11:25 AM
    #9237
    DocME
    California
    '07 FJ Cruiser
    The end wrench looking tool does. You can just flip it over to reverse direction.
  18. Nov 9, 2018 at 11:27 AM
    #9238
    richiep
    Rich
    NY
    but not the long handle with the red grip?
  19. Nov 9, 2018 at 11:38 AM
    #9239
    Speedwaytacotuesday
    Calgary, Alberta
    Looks like I just didn’t have enough patiences, you guys all seem to be able to do it no issues!
    Good find! if I find the other methods are a bit finicky or troublesome I’ll invest into this thing.
  20. Nov 9, 2018 at 11:56 AM
    #9240
    Athlaos
    Leigh
    Edmonton
    Princess Auto stuff is pretty good. Sometimes.
