TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 10, 2018 at 11:38 PM
    #9341
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm thinking a billet spacer like the ones for x-runner oil pans. Then paint the riser to match. If two guys bought one exchanger and split it in half to have it welded as an extension. Or... find a correct size dirt bike radiator that is bigger and fits.
  2. Nov 10, 2018 at 11:41 PM
    #9342
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'd already be running it but they haven't returned any of my emails. If they have no dyno numbers I'll pass.
  3. Nov 10, 2018 at 11:50 PM
    #9343
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I've seen those, those are badass, and would be feasible like I said, but the cover wmodified to accept a new radiator would be a whole new challenge in itself. I would love to do that, but I'm sure there is big $$$ behind that cost.
    Not worth as highlighted by a few members I have read of in the past running it, here and I believe in the Tundra forums. Not only did these guys have AC performance issues because of it, but it didn't have the ideal street ability that you would think it would have.
  4. Nov 10, 2018 at 11:53 PM
    #9344
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes, like all mods. Pricey. I'm in!
    12TRDTacoma[OP] likes this.
  5. Nov 10, 2018 at 11:55 PM
    #9345
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Problems with killerchiller I gathered when I called them.
    You have to run your ac all the time.
    To get the most benefit you have to disconnect your supercharger ltr, otherwise the ambient air will warm up the super cooled air. So if you have your ac off, no intercooler at all.
    I already have disappointing ac performance, I couldn’t imagine adding more stress to the system.
  6. Nov 10, 2018 at 11:57 PM
    #9346
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I agree inside the blower needs to be bigger but you got them mixed up. Our intercooler is located inside the blower. Heat exchanger is with radiator. Even on the hottest days racing around my heat exchanger is always cold to the touch
    DocME, Norton, BassAckwards and 3 others like this.
  7. Nov 10, 2018 at 11:57 PM
    #9347
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    If we could somehow modify the supercharger intercooler to mount a meth nozzle over it spraying the heated air as it hits that intercooler.. that would be something.
    *Fixed from Tron’s correcting ;)
  8. Nov 11, 2018 at 12:00 AM
    #9348
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Actually I think you might have it backwards. Lol I'm not sure anymore.
    Let's just call it the cooler inside the blower case.
    Yeah though I agree after giving my blower nothing but hell the external radiator is always cool. I think that is more than capable for our setups.
    Lol you meth head.
  9. Nov 11, 2018 at 12:01 AM
    #9349
    TRON
    Are you talking about @Coupe design? He made a select few for the XRU.
  10. Nov 11, 2018 at 12:03 AM
    #9350
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That's what I have now. By the time it hits there its atomized pretty well too.
  11. Nov 11, 2018 at 12:09 AM
    #9351
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes
  12. Nov 11, 2018 at 12:10 AM
    #9352
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You know, he would probably be the best man for the job of making a blower riser, while keeping the cost down for us.
    His oil pan spacer was absolutely bitchin'!
  13. Nov 11, 2018 at 12:12 AM
    #9353
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    You are spraying pre throttle body correct?
    My idea would be spraying after tb, right before the air passes the cooler inside the supercharger.
    On an unrelated note but probably because of gofastmods i think one of my CVs is starting to fail. I keep hearing a popping randomly when turning. Its not consistent and I cannot for the life of me figure out what it is :(
  14. Nov 11, 2018 at 12:14 AM
    #9354
    TRON
    Speaking of spacers, how about find an intercooler about 1 inch taller than what we have with all other dimensions the same. Use that spacer in between the blower and our intercooler lid.
    Not sure how much clearance we can work with though hitting the hood
  15. Nov 11, 2018 at 12:18 AM
    #9355
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Someone start doing some digging! @White lightning boosted see if you could find something with Dirtbike radiators. If you can find something good maybe we can contact @Coupe to make us a riser and then we could get to work on fitting it. The setup would require longer bolts as well. New deals most likely too.
  16. Nov 11, 2018 at 12:20 AM
    #9356
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That's why I suggest dirt bike radiators. Dozens of different sizes. Cowl hood with a purpose!
  17. Nov 11, 2018 at 12:23 AM
    #9357
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Cool. I bet something from an 80-125cc two stroke would be best. SoCal probably has way more bike scrap yards to prowl. I'll look too.
  18. Nov 11, 2018 at 3:29 AM
    #9358
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    ^This^
  19. Nov 11, 2018 at 7:43 AM
    #9359
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    They are both heat exchangers.
  20. Nov 11, 2018 at 7:44 AM
    #9360
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Hottest I have seen my SC coolant temps was 140 this summer while towing my camper uphill in Virginia.
