TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 13, 2018 at 2:05 PM
    #9441
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    No offence meant here mang, you do know your stuff, but if all roots did was spin air faster then I wouldn’t be getting 16psi at WOT like I did when it was cold the other day...
  2. Nov 13, 2018 at 2:05 PM
    #9442
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Damn.. wish id have seen your post about the maf sooner, heres the one I got
    https://www.amazon.com/gp/product/B00AZP83ZE/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
    Either way, hope it solves your issues
    Roostfactor likes this.
  3. Nov 13, 2018 at 2:24 PM
    #9443
    ThomasMore66
    Dallas/Fort Worth & Durango
    It's all good. I just want to make sure I have one if my current one is bad. Nothing worse than being stranded on a DFW highway at rush hour. I did go out at lunch, check all my fittings, and then find a frontage road that appeared lonely. I think the homeless guy under the overpass appreciated me disturbing his slumber. No code and 9 psi.
  4. Nov 13, 2018 at 2:26 PM
    #9444
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’d really like to get another vehicle that’s 25 years or older. So the emissions part and the OBD part is less of a complication.
  5. Nov 13, 2018 at 2:27 PM
    #9445
    Athlaos
    Leigh
    Edmonton
    9psi, does that mean your issues are fixed?!
  6. Nov 13, 2018 at 2:32 PM
    #9446
    ThomasMore66
    On a good run I can hit 10, just not in the distance I had at lunch. I hit 10 this a.m., held it for a few seconds, and then boom. Check engine and the trac-off light came on. It actually made me laugh, and then I got concerned that something had really happened. No black smoke. No parts on the ground behind the truck. I've blown two engines. I'm familiar with the signs.
  7. Nov 13, 2018 at 2:34 PM
    #9447
    BassAckwards
    :eek::eek::eek:
    In the taco? Dare I ask how?
  8. Nov 13, 2018 at 3:12 PM
    #9448
    ThomasMore66
    A 454 in a work truck pulling a trailer in the middle of BFE NM, and a little 4 cylinder in a GrandAm driving down the highway. Apparently there was a known flaw in the Pontiac motor where a bolt backed off the oil pump. I found Toyota shortly thereafter.
  9. Nov 13, 2018 at 3:28 PM
    #9449
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Biscuits, skyking3, Torspd and 6 others like this.
  10. Nov 13, 2018 at 3:36 PM
    #9450
    ThomasMore66
    BassAckwards and JuanitoBonito like this.
  11. Nov 13, 2018 at 3:51 PM
    #9451
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  12. Nov 13, 2018 at 4:11 PM
    #9452
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
  13. Nov 13, 2018 at 4:15 PM
    #9453
    BassAckwards
    This makes me feel much better:D
    Athlaos likes this.
  14. Nov 13, 2018 at 5:01 PM
    #9454
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
  15. Nov 13, 2018 at 5:13 PM
    #9455
    ThomasMore66
    I’ve thought about this all afternoon. 16 psi. At some point here it seems new rods would be a good idea. Do we know where failure is? @Torspd probably can tell us.
    Norton likes this.
  16. Nov 13, 2018 at 5:24 PM
    #9456
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Stronger rods anytime would be a good idea. Preferably before the block decides to be perforated.
    Norton and Roostfactor like this.
  17. Nov 13, 2018 at 6:38 PM
    #9457
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The real question is when does the heat from psi start to diminish the TRD blower?
    Norton, Roostfactor and loginfailed like this.
  18. Nov 13, 2018 at 7:01 PM
    #9458
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Depends on how much 'alternative' fuels you use. Or add ice to the coolant system.
    Athlaos and Roostfactor like this.
  19. Nov 13, 2018 at 7:10 PM
    #9459
    ThomasMore66
  20. Nov 13, 2018 at 7:34 PM
    #9460
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Cool shit, saw that this morning. I’d be in tears if I woulda lost my trophy though...
    Biscuits and Roostfactor like this.
