TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 14, 2018 at 3:06 PM
    #9521
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Here's the document that I got from iTronix regarding how to set/unset the different modes.
    Forgive me, but what is an MIL light?
    BassAckwards likes this.
  2. Nov 14, 2018 at 3:07 PM
    #9522
    eon_blue
    Azusa, CA
    Malfunction Indicator Lamp...same as a CEL (check engine light)
    BassAckwards and Athlaos[QUOTED] like this.
  3. Nov 14, 2018 at 3:08 PM
    #9523
    Athlaos
    Leigh
    Edmonton
    Ah, just looked it up. It is the check engine light, lol. Scott told me that it flashes the number of times for which you have the stage tune installed. Once for stage 1, twice for stage 2, thrice for stage 3.
  4. Nov 14, 2018 at 3:20 PM
    #9524
    Athlaos
    Leigh
    Edmonton
    True. However, as my old boss said, if you're building a project car with as much go-fast stuff as possible, you're going to stop caring about MPG at some point...
    Speedwaytacotuesday and Norton like this.
  5. Nov 14, 2018 at 3:21 PM
    #9525
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Pros:
    Cleaner air
    Cooler (closer to ambient) temps vs drawing from fender/engine bay
    Cleaner air
    Cons:
    slight restriction (I see about half a pound of boost lost with the snorkel)
    stuck using factory filter ( I use an oiled K&N and removed my secondary filter)
    I mentioned cleaner air twice.. because to me.. that is well worth anything else that comes with a snorkel. I've had my truck go into limp mode a couple times out on the trail due to a dirty filter (AFE/TRD) before I got my snorkel. That was the main purpose of installing mine. We get so much dust out here on Arizona trails that I needed the cleaner air. I'm even wanting to replace the head with a ~10" pre-filter. As for the temps.. my readings on Torque showed my intake temps considerably lower as well. much closer to ambient than the previous temps with my AFE. I havent had any real "problems" with mine. Just that half pound of boost loss. I tested that via Torque/AEM gauge and disconnecting the snorkel where it meets the factory airbox. Of course, its then a hot air intake, but.. without the restriction. Now the snorkel vs say the AFE, you might see a pound or so difference IMO. I cant recall my readings back then to compare. Overall.. worth it IMHO.
  6. Nov 14, 2018 at 3:22 PM
    #9526
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    So my truck has been in stage 2 since I had it installed? Is this part of the reason I am still rich and can't generate much boost? LOL but I know I am going well over 1900 rpm. Scott should be responding to my email soon so he can look into my truck/tune. I wonder if I should try to change what mode it is in? Any thoughts?
  7. Nov 14, 2018 at 3:27 PM
    #9527
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Oh it doesn't matter to me. But some it does. Pulled 7-9 mpg to and from CA last weekend. 30+mph headwind both ways and extra wind resistance from the bike
    Then around 4.5mpg playing in the dunes
  8. Nov 14, 2018 at 3:27 PM
    #9528
    Athlaos
    Leigh
    Edmonton
    It's worth mentioning it to Scott.
    mr.trd[QUOTED] and BassAckwards like this.
  9. Nov 14, 2018 at 3:28 PM
    #9529
    Athlaos
    Leigh
    Edmonton
    Nice, I like to support the oil industry as well. Since I work in it and all, it just makes sense.
  10. Nov 14, 2018 at 4:00 PM
    #9530
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    1 flash = stage 1 tune
    2 flashes = stage 2 tune
    3 flashes = stage 3 tune
  11. Nov 14, 2018 at 4:05 PM
    #9531
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I concur .
  12. Nov 14, 2018 at 4:35 PM
    #9532
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Amen! God bless Texas:D
  13. Nov 14, 2018 at 4:43 PM
    #9533
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Thank you. And I believe I should have stage 2. I just emailed Scott today so I am sure he will be responding to me pretty soon.
    loginfailed[QUOTED] and Athlaos like this.
  14. Nov 14, 2018 at 4:52 PM
    #9534
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Had the black TRD blower...I think it was the revised 2nd gen after the grey one. Installed it with the TRD 7th injector right from the beginning. Got about 7 psi boost stock.
    Nice truck you have too. I'm happy with black but man its hard to keep clean
  15. Nov 14, 2018 at 5:54 PM
    #9535
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Confirmed. New BMW M4 is slightly faster than I am. I did get a nod from the guy though.
  16. Nov 14, 2018 at 6:14 PM
    #9536
    Athlaos
    Leigh
    Edmonton
    Good work.
  17. Nov 14, 2018 at 6:20 PM
    #9537
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Need different wheels and tires. Less weight will equate to nearly 30hp. Then I might provide some pucker factor.
  18. Nov 14, 2018 at 6:26 PM
    #9538
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    You got a link? I keep getting P0136/0138, P0156/0158 on the interstate. I figure the rear sensors are going bad since the code pops 1-2weeks routinely along with the cats. I am looking to replace the cats with aftermarket high flow ones when I put in the DT short tubes.
    Smiles per gallon for this guy haha
  19. Nov 14, 2018 at 6:27 PM
    #9539
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  20. Nov 14, 2018 at 6:44 PM
    #9540
    Skootter14
    Jeremy
    So, great news. I just moved back to NC from WA. I just checked on registering and emissions, turns out my county is doing away with emissions testing on 1DEC2018. Huge win for me.
    This makes me ask the question:
    Since I just bought DT shorties and was going to weld in high flow cats, can I just install the headers and extend the y pipes to meet up with the headers? (If I move later on down the road, I assume I will just be able to cut out the extended pipe and then add the cats later).
    Please advise :)
