TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 28, 2017 at 8:08 AM
    #941
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Too long a story......
  2. Nov 28, 2017 at 8:08 AM
    #942
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Does the seller have the same?
  3. Nov 28, 2017 at 8:18 AM
    #943
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  4. Nov 28, 2017 at 8:21 AM
    #944
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So at a minimum he has different injectors. You would need the TRD cal file with the 668 cc injectors.
    Or a used facotry ECU, then swap in those injectors.
  5. Nov 28, 2017 at 8:34 AM
    #945
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    ok thanks @Torspd thats the kinda stuff i was worried about. :thumbsup:
    Torspd likes this.
  6. Nov 28, 2017 at 5:39 PM
    #946
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Well I got P219A again.. sigh.
    It always happens at idle. I have no idea how to fix it at this point or what’s wrong with it.
    My ballast in the fuel pump housing still wont go below 3/4 tank after I adjusted and got the top white ring on tight 1.5 weeks ago.
  7. Nov 28, 2017 at 5:45 PM
    #947
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    What was P219A again?
    It sounds like you have a bad fuel sender unit. Which is somewhat of a common occurance. They're somewhat delicate and it it is damaged even a little bit on removal or re-entry back into the tank they will go bad.
  8. Nov 28, 2017 at 5:45 PM
    #948
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Don't drive so slow:notsure:
  9. Nov 28, 2017 at 5:51 PM
    #949
    GT7
    Grant
    Phoenix
    2013 DCLB
    Nothing I can do at a stop light. P219A is like bank 1 lean or something.
    Fuel sender unit hm? I guess Ill look into it
  10. Nov 28, 2017 at 5:54 PM
    #950
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I used to get P219a and p219b. Scott did something to the UCON and it never happened again.
    Mine seemed to set it at idle as well.
    Grant do you still have cats? I forget..
    Skootter14 likes this.
  11. Nov 28, 2017 at 6:20 PM
    #951
    GT7
    Grant
    Phoenix
    2013 DCLB
    Nope no cats, scott made the “fix” a long time ago.
    The first time P219A ever came was 50 miles and the day after I installed the ucon.
  12. Nov 28, 2017 at 6:34 PM
    #952
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    You don’t wanna hear this...
    Do a leak down test. You’re looking for leakage past the valves primarily. Pressurize each cyl @ tdc on comp stroke. Listen to the intake, exhaust, and oil filler.
  13. Nov 28, 2017 at 6:46 PM
    #953
    GT7
    Grant
    Phoenix
    2013 DCLB
    What is the best way to go about this?
  14. Nov 28, 2017 at 7:05 PM
    #954
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Here’s the TSB. It’s for 2015 models, but could be the end result for other year 1GR engines.
    http://media.fixed-ops.com/Toy_ServiceBulletins/sb0055t15.pdf
    I doubt you need a new head. It’s something to do with how the UCON is sending unicorns and rainbows to the ECU.
  15. Nov 28, 2017 at 7:08 PM
    #955
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is not actual engine related. This is purely a software issue as the issue begun the moment he switched to UCON.
    loginfailed likes this.
  16. Nov 28, 2017 at 7:09 PM
    #956
    GT7
    Grant
    Phoenix
    2013 DCLB
    Grrrr. I just want my truck to work. Which it does. Fuckin cel.
    Should I try the dealer or leave it. Idk
  17. Nov 28, 2017 at 7:12 PM
    #957
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You might want to look into the UCON itself, as it is the one which is the root of the problem.
    GT7 likes this.
  18. Nov 28, 2017 at 7:16 PM
    #958
    BillDaCat8
    Jake
    PHX
    Pull the spark plugs. You’ll need to pressurize each cylinder with compressed air with the valves closed. I’ve got a regular compression tester hose that I remove the Schrader valve from and hook to my compressor hose up to. Crank the motor by hand until you’re in position and apply the air. Have a buddy hold the crank with a breaker bar. Now, while it’s pressurized, listen at the intake, exhaust, and the oil filler. If you hear a lot of hissing, you’ll know which cylinder and which valve is the trouble. In the event of a lot of leakage at the oil filler, obviously, there’s leakage past the piston/rings. There are actual leak down gauges out there that you can buy or rent. They will give you a percentage of leakage number. But imo, that number is unimportant. Just listen to the difference between cylinders and you’ll know where your problem is.
    Biscuits likes this.
  19. Nov 28, 2017 at 7:19 PM
    #959
    12TRDTacoma
    Rob
    Concordia
    Boosted
    He only has 40K. The chances that his head (s) are toast is very slim.
  20. Nov 28, 2017 at 7:26 PM
    #960
    GT7
    Grant
    Phoenix
    2013 DCLB
    I emailed Gadget we will see what happens...
