TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 18, 2018 at 3:51 PM
    #9721
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Ok. I’ll be here watching when you bust in here like the Koolaid Man later on proclaiming you discovered AN fittings and how they’re the holy grail of fuel plumbing.
    :rofl:
    BassAckwards, TRON and Roostfactor like this.
  2. Nov 18, 2018 at 3:52 PM
    #9722
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    OHH YEAHHHH!!!
    Lol, well if this was a breath holding contest you'll be turning blue in the face. :D:bananadead:
  3. Nov 18, 2018 at 4:12 PM
    #9723
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Lean conditioning at idle makes sense when you have the fpr mod and vacuum occurring with fuel trims. While the idle conditions should be the same regardless the size of the pulley.
  4. Nov 18, 2018 at 4:13 PM
    #9724
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Double the resolution. Cant have too much data!
  5. Nov 18, 2018 at 4:15 PM
    #9725
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh, yes that makes sense! So let's do a quick experiment then, I'll reverse the mod and run it standard connection to intake as designed for the FPR and see how much lower adaptation will go down.
  6. Nov 18, 2018 at 4:15 PM
    #9726
    Roostfactor
    TX panhandle
    Try swapping just the input leads to your afr gauges to see if the delay follows to the other gauge or stays on the same gauge. Its possible one gauge reads slightly slower than the other.
  7. Nov 18, 2018 at 4:17 PM
    #9727
    Roostfactor
    TX panhandle
    Beat me to it. Right you are Godfather :hattip:
    BassAckwards and 12TRDTacoma[OP] like this.
  8. Nov 18, 2018 at 4:18 PM
    #9728
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @TRON I was actually thinking this may had been tied to my pig rich at fill ups issue, but it seems like all is okay and the pig rich at idle after fuel up is a seperate isolated issue.
    Darn. Lol. I'll figure it out eventually!
  9. Nov 18, 2018 at 4:23 PM
    #9729
    Roostfactor
    TX panhandle
    Most jet engine fittings are aluminum AN style. Reliability is paramount at 30,000+ ft so if there was an issue with leakage they wouldn't be used.
    There is a difference between AN and JIC fittings though and they are commonly used together incorrectly. They have a different degree of taper so don't mate correctly when seated. That may have been your issue.
  10. Nov 18, 2018 at 4:28 PM
    #9730
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Good thinking, will do this and report back
    Athlaos and Roostfactor[QUOTED] like this.
  11. Nov 18, 2018 at 4:30 PM
    #9731
    BassAckwards
    Do you read STFT & LTFT's with an OBDII gauge? or how do you do this? and what do the percentages mean?(ie higher vs. lower numbers)
  12. Nov 18, 2018 at 4:38 PM
    #9732
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes the STFT and LTFT's are read using an OBD2 scanner. Negative numbers indicate rich activity while positive numbers indicate lean activity.
    BassAckwards[QUOTED] likes this.
  13. Nov 18, 2018 at 4:52 PM
    #9733
    BassAckwards
    Thanks for explaining this sir:thumbsup:
  14. Nov 18, 2018 at 5:46 PM
    #9734
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dude I tried pulling off that pulley today and seeing how the belt would run in correlation to the tensioner. The belt was ultimately going to slap on the sensor and looking at your picture it looks like it is rubbing on the plug at the bottom.
    Roostfactor likes this.
  15. Nov 18, 2018 at 6:13 PM
    #9735
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    It might be best to move the O2 sensors side to side. If you have a lazy one, which happens, you’d find it that way.
    Edit: this is in regards to the stock sensors
    12TRDTacoma[OP] likes this.
  16. Nov 18, 2018 at 6:15 PM
    #9736
    BassAckwards
    @12TRDTacoma GREAT info on the first page especially with all the updates. I noticed that you had a section relating to the valve body upgrade for auto transmissions. Do you think you could put something in there about the manual trucks needing a clutch pressure plate upgrade? I have seen multiple folks with manuals end up needing a clutch after a short period of time because the OEM one just doesnt have the holding power.. Just think this would be a good bit of info for those considering supercharging with a 6spd. Its an added cost that some might not consider up front.
    richiep likes this.
  17. Nov 18, 2018 at 6:32 PM
    #9737
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Ay, that sucks, yeah it looks pretty close in my picture but there is about 1/4” clearance.
  18. Nov 18, 2018 at 7:28 PM
    #9738
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When you unknowingly mate 32º with 37º.
    Roostfactor[QUOTED] likes this.
  19. Nov 18, 2018 at 7:29 PM
    #9739
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Thanks man! Just trying to keep the front page informative as possible! I still need to add @Roostfactor lower plenum mod, and his equal length y pipe mod as well. As well as recommendation of which gauges are solid setups to run, NOT INNOVATE MTX series! Lol.
    I was considering it, but I do not have enough knowledge of the 6 speeds to make proper suggestions as to which clutch/ flywheel combo or mods you can make to the current setup to be able to run the setup reliably to both be able to handle maximum boost and yet last the test of time.
    The only thing I can contribute to manuals in the front end is running the TRD short shifter which will eliminate synchro grind which the long throw shifters are notorious of doing.
    Believe me, it is something I have been considering in adding for a long time, but again my lack of knowledge in the 6 speed MT field makes me hesitant to add simply because I dont want to give out misinformation.
    That's so weird. I wonder why mine does not like running like that.
  20. Nov 18, 2018 at 8:14 PM
    #9740
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just want to take a moment to acknowledge all of you who have contributed in depth to this thread and have continued to not only provide further knowledge, but post and keep this thread active and running for all new incoming and current members to remain engaged and happy while breaking down new barriers on our blowers. You guys rock! :)
    Back to our regularly scheduled shenanigans...
