TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 23, 2018 at 4:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Nov 23, 2018 at 4:24 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I have heard that about the Turd gens. Interesting how there is so much difference in attitude. It reminds me of the C-130 engine mechanics vs what we call the straight jet engine mechanics. The C-130 guys like myself always had each others backs and took care of each other. We just kicked ass and had fun, where the straight jet guys always seemed disgruntled and ready to place blame elsewhere.
    Biscuits likes this.
  3. Nov 23, 2018 at 4:39 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Same thing happened on the FJ forums. It was a mixture of innovative folks and inexperienced keyboard jockeys. Most of the members that were forum pioneers have had to abandon the platform for something that fits a car seat. The forums have really slowed down from where they were. I'm not that smart and refuse to give it up.
  4. Nov 23, 2018 at 4:46 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Strong work!
    ...and where did you get the idea for that peeve!?! :hattip::boink:
  5. Nov 23, 2018 at 4:53 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Well, you're welcome here man.
  6. Nov 23, 2018 at 5:03 PM
    Roostfactor
    TX panhandle
    ^^This^^
    richiep, Biscuits, DocME and 3 others like this.
  7. Nov 23, 2018 at 5:04 PM
    Roostfactor
    TX panhandle
    It was engrained long ago but recently re-emerged to the surface. :D
    Torspd and loginfailed[QUOTED] like this.
  8. Nov 23, 2018 at 5:37 PM
    DocME
    California
    '07 FJ Cruiser
    Aww, thanks guys!
  9. Nov 23, 2018 at 5:41 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Have you seen my Figg reservoir tank? Lol.
    Torspd, Norton, Roostfactor and 4 others like this.
  10. Nov 23, 2018 at 5:47 PM
    DocME
    California
    '07 FJ Cruiser
    Haha, I have and it is very nice......it’s also quite Spendy.
  11. Nov 23, 2018 at 5:55 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Don’t you have two now? :D
  12. Nov 23, 2018 at 6:05 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    If you do, sell me one!!!
  13. Nov 23, 2018 at 6:44 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Great job on all your work @DocME!
    You are more than welcome here.
  14. Nov 23, 2018 at 8:04 PM
    Roostfactor
    TX panhandle
    :stirthepot::stirthepot:………………………:crapstorm:…………………………………………………………………………..Your just begging for it!!!...……………………………………………………………………………………………………………………………………………………………………………….
  15. Nov 23, 2018 at 8:18 PM
    Roostfactor
    TX panhandle
    Hmmm, $375 coffee cup or $1000 y-pipe. This one is 80% erected?
    Biscuits, Murphinator, Norton and 3 others like this.
  16. Nov 23, 2018 at 8:25 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I choose door number 2.
    Biscuits and Roostfactor[QUOTED] like this.
  17. Nov 23, 2018 at 8:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Stop. It can only get so erect!
  18. Nov 23, 2018 at 9:31 PM
    ThomasMore66
    Reported!
    rmepilot, Torspd, Biscuits and 2 others like this.
  19. Nov 23, 2018 at 9:45 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't care. :)
  20. Nov 23, 2018 at 9:46 PM
    ThomasMore66
    Figgs is designed to be seen.
