TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 25, 2018 at 5:56 AM
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    I have a level 10 torque converter
    mr.trd likes this.
  2. Nov 25, 2018 at 7:00 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Scratch built one or yours overhauled? What changed performance wise with your truck after install?
  3. Nov 25, 2018 at 10:36 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    It doesn't get any more definitive than this, especially when it comes to four month old promises...
    "Once we have all of them ready we will send them. Not sure what else could be said, if we haven't sent it then it's not ready to send to everyone."
  4. Nov 25, 2018 at 10:42 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    They are built from scratch. All stall converters usually are if it is a legitimate company backing it.
    Balls to the wall performance. The converter is usually constructed to flash up to the engines powerband and upon shifting you dont drop off RPM like with a stock level torque converter, rather stay within the powerband. Cruising performance remains similar, it only affects you when you give the go pedal some more juice. There is a lot more to it, and STR comes in to play, but that is the basics of it.
    This mod is strictly for performance but if you offroad I strongly advise you against this mod as the sudden RPM flash can and usually is violent. Something you DON'T want while rock crawling or even desert running.
    Another thing to note is due to the fact that you are allowing slippage up to a certain RPM to allow the converter to flash up, there will be a lot more heat generation. Transmission cooling temperature is of the utmost importance, and something like Roost's CSF radiator mod would almost be mandatory to do, or a larger independent trans cooler, or both. Transmission temperature monitoring is recommended as well to ensure you do not exceed dangerously high temperatures during operation. Some additional wear can be expected on the clutch packs as well, but given that we have a much more well constructed transmission over one built by GM I wouldn't worry about that too much, unless you have already high mileage and dont do regular maintenance on your tranny fluid.
    Put it to you this way, it is a mod commonly done by the muscle car community, so results will be similar to muscle car performance (e.g. drag racing).
  5. Nov 25, 2018 at 11:21 AM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Sent my datalogs to Scott. He responded this morning and said everything looks great. My air flow was only 258g/s. Elevation sucks. He said it looks good to go down a couple pulley sizes. I didn't even ask or bring it up. Guess that is his way of saying i need more power. So, next step. 2.7 or 2.6? Want the best dependability for what I have in supporting mods. Reccomendations?
    loginfailed, Athlaos and Torspd like this.
  6. Nov 25, 2018 at 11:23 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Go 2.5 then you dont need to fuss with the tensioner stop to make the belt fit correctly.
    loginfailed and mr.trd[QUOTED] like this.
  7. Nov 25, 2018 at 11:23 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Are you manual or auto?
    If you are either you will require either an upgraded clutch or a Ratiotek shift kit to speed up shift time.
  8. Nov 25, 2018 at 11:26 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I've been a year of abusive driving and my stock clutch is still holding up. Smoked it a couple times but you can get by for a bit without upgrading. I know it'll be needed eventually though.
    mr.trd likes this.
  9. Nov 25, 2018 at 11:29 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    2.7 will be safe for all but the the lowest altitudes and temperatures. My injector duty cycle was 93% with a 2.7 at 1000ft elevation and 80's temperatures.
    A 2.6 may work great for where you are but you may have to be carefull if you go to lower altitudes unless you install larger injectors.
    2.5 with 61lb injectors is awesome.
    loginfailed, Biscuits, Torspd and 6 others like this.
  10. Nov 25, 2018 at 12:02 PM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Automatic. Have about 5k miles on a used one thst had 45k on it and I put a transgo shift kit in the valvebody at that time. I am at 4400 feet here in Idaho, but my travels take me much higher often and down to about 2200 feet at the lowest often. Would love to feel the truck at anything under 1000 feet. I have my old trans that I am thinking about rebuilding and doing the ratiotek. Also thinking about just pulling the valve body and putting the ratiotek in it to just test the difference. Would love to go 2.5 right off the at but thinking 2.7 would be smarter. Baby steps. And cost. Just got my CSF radiator and ordered hammer hangers also. And still need to re do my rear suspension again. Lol too many projects. Thank you all for you input and your knowledge! I have learned so much on this thread.
  11. Nov 25, 2018 at 12:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I want to and need to convert my rear shackles out to hammer hangers as well. One of the few pending projects I have put off for a while now.
  12. Nov 25, 2018 at 9:56 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just so you guys know, I'll probably be off posting for a few days. I'm currently nursing a post concussion headache and have some mild memory loss right now. Much love homies.
  13. Nov 25, 2018 at 9:57 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Owch. Hope you're ok man.
  14. Nov 25, 2018 at 10:07 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Hope you are alright and it is nothing serious. Good news is you still recall TW, so you still have your priorities.
  15. Nov 25, 2018 at 10:12 PM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Take care of yourself man. We will boost for ya. And I will plan higher boost!
  16. Nov 25, 2018 at 10:16 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Damn dude. Right back at ya, bro. Do whatever is necessary to take care of yourself.
  17. Nov 26, 2018 at 3:55 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Rest up and heal my friend. I had this happen as a child and the headache lasted 2 weeks.
  18. Nov 26, 2018 at 12:47 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I've debated doing that for a while...but I'm starting to lean towards wanting to upgrade the 4.0 internals first so they can handle 400+ HP
  19. Nov 26, 2018 at 1:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Smart choice.
    BassAckwards likes this.
  20. Nov 26, 2018 at 1:10 PM
    VolcomTacoma
    Jeff
    NorCal
    Will probably be hitting you up someday about what to do/where to go for parts and questions about getting a little more displacement ;)
    Torspd[QUOTED] likes this.
