TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 27, 2018 at 1:55 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Better get Roush and Nissan logos on that shit too! :bananadead:
  2. Nov 27, 2018 at 1:59 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    @loginfailed's truck is no longer going to be a Toyota Tacoma we'll have to rename it "The Dwayne." :bananadance::bananadead:
    :smokertransformer:
  3. Nov 27, 2018 at 2:22 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Actually the closest to off road I've gone was a mile or two on a gravel road. I'm going for the lifted street truck look. Zero practicality with compromises as well.
    Roostfactor, skyking3, Torspd and 3 others like this.
  4. Nov 27, 2018 at 2:23 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    At least it doesn't have the four letter word with a blue oval.
  5. Nov 27, 2018 at 3:12 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
  6. Nov 27, 2018 at 3:33 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I ordered the Roush tensioner on Wednesday. On eBay now looking for Nissan stickers.
    May I remind you that everyone’s Magnuson/TRD Supercharger Kit comes with belt tensioners that are originally spec’d on a bunch of Fords. :D
    mr.trd, BassAckwards, Norton and 5 others like this.
  7. Nov 27, 2018 at 3:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    ^^^ he's not wrong either!
    Blower pulley spec'd off a GM Cavalier/ Sunfire 4 banger, a tensioner spec'd off Ford Explorer V8's, and coolant pump's as well as reservoirs spec'd off of Lightning F-150's and Cadillac CTS-V's. Our entire supercharger setup was assembled from already on the shelf items.
    Our truck's are also now confused.. are they 4 bangers, 6 cylinders, or 8 cylinder GM's or Ford's? Lol.
  8. Nov 27, 2018 at 4:03 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ford had to copy something good didnt they?
    12TRDTacoma[OP] likes this.
  9. Nov 27, 2018 at 4:05 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Nope, the trucks arent confused. Just the owners when they find out the value at resale timeo_O
  10. Nov 27, 2018 at 4:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    All seriousness, no hate on domestic. I just wont buy another after this truck:thumbsup:
    mr.trd and 12TRDTacoma[OP] like this.
  11. Nov 27, 2018 at 4:07 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Thus is.getting very sexually confusing:anonymous:
  12. Nov 27, 2018 at 4:11 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    You had better get a Johnson pump then.
  13. Nov 27, 2018 at 4:15 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Only if Roush makes one
  14. Nov 27, 2018 at 4:55 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Does anyone know what year(s) automatic trans are compatible with a 15?
  15. Nov 27, 2018 at 5:18 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    if it was an 8cyl gm wed have more power :stirthepot:
  16. Nov 27, 2018 at 5:22 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Level 10 builds you a new one. Looking into it.
  17. Nov 27, 2018 at 6:11 PM
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    What's the difference with the upgraded valve body and a shift kit from ratio Tech?
  18. Nov 27, 2018 at 6:15 PM
    GeoScout
    GeoScout Calgary Geo
    Vill
    Calgary, AB
    2015 MGM TRD SPORT 6MT
    MAGNUSON Superchager URD 2.85 Pulley Icon Stage 9 Pelfreybilt Armor AFE INTAKE TRD EXHAUST TRD QUICK SHIFTER Warn Zeon 10S Icon Alloy - Six Speeds Nitto Ridge Grapplers TRD Pro Grill Leer XR Canopy Front Runner Roof racks Treeline Outdoors RTT
    Did you order right from Australia is there a distributor in the US? Mind sharing a price?
    loginfailed[QUOTED] likes this.
  19. Nov 27, 2018 at 6:25 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Then fall apart...
  20. Nov 27, 2018 at 6:49 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    FIFY :rofl:
    Drove mine over a median once. Had to get out of the Whataburger parking lot because the drive through line was too long.
    I'm actually pretty surprised at how much money these things bring at resale.
    I'd run an LS swap if it was easy to get everything working. ABS/TRAC/4WD etc.
    Ordered from @Cruiser Brothers they are having a black November sale right now for $200 off Long Range Automotive tanks. The Tacoma tank runs $1595. So $1395 if you get your order in by 12/3. Shipping is extra and cost will vary by location. If you call them up, ask for Ward Harris. Super nice guy, excellent service.
    See link below for details on the sale:
    https://www.tacomaworld.com/threads/black-november-sale-cruiser-brothers.578839/#post-19192932
    Here is the product page on the Cruiser Brothers website:
    https://www.cruiserbrothers.com/brands/long-range-automotive/#product-listing
    BassAckwards, Torspd and Roostfactor like this.
