TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 27, 2018 at 6:52 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I was semi interested in that tank for a while, but you're talking a couple hundred lbs of added weight on one side. no bueno for what I do. I think I'm locked in to some sort of fuel cell in the bed someday if I want more than 21 gallons
  2. Nov 27, 2018 at 6:58 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    My experience with GM has proven otherwise, as I'm now over the power levels of a stock LS2 at the wheels on a GTO. (330HP) ;)
    Unless you are heavily modding an NA build, then you are good for 450 or so HP at the wheels. Still very expensive to mod to get max effort NA power though.
  3. Nov 27, 2018 at 7:03 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I thought about adding a fuel cell. Since I have the swing out rear bumper with tire carrier, there's a decent amount of space where the spare tire used to be. But I'm saving that space for onboard air stuff.
    I know you like plowing through sand dunes and kicking up big rooster tails so the difference in weight distribution wouldn't work well in your case.
    I'm just commuting to and from work and making an occasional trip half-way across Texas. This tank will increase my range between fill ups from 250 miles to 400.
    BassAckwards likes this.
  4. Nov 27, 2018 at 7:11 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah I think a 32 gallon cell right up against the cab like standard everywhere would work well for me.
  5. Nov 27, 2018 at 7:17 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Add that to that long ass list you posted earlier! :D
  6. Nov 27, 2018 at 7:20 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah It never fuckin ends.
  7. Nov 27, 2018 at 7:22 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Just when I think I'm to the point I can leave the truck alone for a while, I find more shit that I NEED to do to.
  8. Nov 27, 2018 at 7:29 PM
    VolcomTacoma
    Jeff
    NorCal
    Same! I was happy, then suddenly a bolt snaps and its a cascade event lol. Now I'm like fuck, this this this this this this and this need replacing before I can offroad again, and this this this this and this should probably get replaced soon.
    mr.trd, snowsk8air2 and Roostfactor like this.
  9. Nov 27, 2018 at 8:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Nuthin' but barrel rolls.
    mr.trd likes this.
  10. Nov 27, 2018 at 8:06 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    The ratio tek shift kit is beefier springs and larger orifices. IPT valve body is that plus upgraded internals.
    rockporttaco[QUOTED] likes this.
  11. Nov 27, 2018 at 8:12 PM
    VolcomTacoma
    Jeff
    NorCal
    which sounds like fun, but isn't.
    mr.trd likes this.
  12. Nov 27, 2018 at 8:19 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Not without a full cage and a helmet.
  13. Nov 27, 2018 at 8:20 PM
    VolcomTacoma
    Jeff
    NorCal
    Pretty sure even then its still not fun, especially when you get out and assess the damage lol
  14. Nov 27, 2018 at 8:21 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Coming soon to a truck sitting in my side yard. Well springtime hopefully.
    stairgod and Roostfactor like this.
  15. Nov 27, 2018 at 8:34 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    20181127_231456.jpg 20181127_231952.jpg 20181127_232223.jpg 20181127_232305.jpg
    The Roush showed up today. Definitely sturdier than stock.
    One thing I noticed on the Roush is the seat for the inner race of the pulley bearing is half the height of the stock tensioner. Probably not a big deal if you tighten the pulley bolt properly and maybe add a dab of blue threadlocker, but you'll notice in the 2nd to last pic the seat is only half way up the race.
    Also no protruding spring issues on this piece.
    Athlaos, mr.trd, BassAckwards and 4 others like this.
  16. Nov 27, 2018 at 8:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No need for thread locker on that bolt, as the pulley is what sees any sort of load or even vibration. Just tighten it down really good. And you should be good to go. I don't like how about half of the inner race has no support, but the bolt will support it. I initially had the same issue with my Thump unit, but the double bearing pulley I got from LFP provided the billet space I still had to modify to make it all work and fit nicely within the sleeve housing and bolt hole.
    Your call how you want to proceed with it, but myself I'd be much more comfortable running some kind of sleeve to cover the rest of the slack that is no longer covering the inner race.
    It otherwise looks like a nice beefy unit. Be aware that there will be reduced clearance between the actual fan plastic material and space to put in some sort of breaker or 1/2 rachet drive. Nothing a prybar can't fix.
  17. Nov 27, 2018 at 8:46 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    That or I may hack off a portion of the seat on my broken tensioner and drill out the threads as a spacer.
  18. Nov 27, 2018 at 9:01 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dremel with a cut off wheel and you'll be good to go! Just cut at the base and you'll be solid. I'm excited for you! That tensioner will never fail.
    JacksonTacoma[QUOTED] likes this.
  19. Nov 27, 2018 at 9:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    My steeda is getting returned for one of the rousch units. Certain areas on the steeda looked like hairline fractures. I know what casting Mark's are too. Just didnt like the idea. Welding a thick plate introduces a lot of heat to a casting.
  20. Nov 27, 2018 at 9:23 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah as of right now, it appears to be that the Roush units are the most viable option but will inherently require some minor modification to the idler pulley bearing support in order to run reliably on our setups.
    The only other options that remain are the very expensive billet versions, Thump, ARS, etc. As the $200 UPR ones are no longer being made, which is sort of a shame.
    mr.trd likes this.
