TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 28, 2018 at 11:12 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Is that what it takes for you to finally come out my way? o_O
  2. Nov 28, 2018 at 11:20 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Yeah maybe I just got a stubby Roush. That's what I get for buying Ford parts.
  3. Nov 28, 2018 at 11:51 AM
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    $100 vs $600 I did the shift kit myself.
    Roostfactor and 12TRDTacoma[OP] like this.
  4. Nov 28, 2018 at 12:16 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Mine is longevity insured as well. All for $45.
    :D
  5. Nov 28, 2018 at 2:03 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Can anyone point me to the exact hose that has the restriction jet in it? Is it the Boost gauge line? Or the line off the back of the blower? I don't have small hands >_<
    BassAckwards likes this.
  6. Nov 28, 2018 at 2:06 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The line off of the back of the blower that connects to the bypass valve. You will need to pull that hose off on the side that connects to the bypass, and it's in the bypass housing itself
  7. Nov 28, 2018 at 2:07 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I thought someone posted a pic... you will bleed removing it.
  8. Nov 28, 2018 at 2:08 PM
    BassAckwards
    [​IMG] Yes, @12TRDTacoma has a pic on the first page. Its this one. Remove the line going into the bypass pictured above. Restrictor jet should be on the nipple that the hose goes onto, or it may have been sucked into the hose itself if it's not there. Yes, prepare yourself for cursing, and bleeding. Have a 12 pack handy for whenever you finish it up
    rmepilot, Norton and 12TRDTacoma[OP] like this.
  9. Nov 28, 2018 at 2:09 PM
    VolcomTacoma
    Jeff
    NorCal
    FML. Guess I'll wait til i service the blower and add the catch can at the same time. Maybe I should just do it next month and pull the blower off to get spark plugs done easily as well. :burnrubber:
    Roostfactor, Norton and mr.trd like this.
  10. Nov 28, 2018 at 2:10 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    It's easy compared to a bypass valve allen screw.
  11. Nov 28, 2018 at 2:13 PM
    ThomasMore66
    Lol. I bled installing the catch can too. PCV is a bitch to get to.
  12. Nov 28, 2018 at 2:13 PM
    ThomasMore66
    Yeah, I haven't done that yet. Looked like something I should take the top off for.
  13. Nov 28, 2018 at 2:14 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    TRUTH
  14. Nov 28, 2018 at 2:15 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm on board for all of that minus the 12 pack. Lol.
    Didn't you guys know that I am apparently you guys' Gumby? I can do plugs, the restrictor jet removal AND the bypass valve adjustment all without removing the blower!
    Falsely true. Lol.
  15. Nov 28, 2018 at 2:15 PM
    VolcomTacoma
    Jeff
    NorCal
  16. Nov 28, 2018 at 2:16 PM
    BassAckwards
    You saying you need more? perhaps a kegger?:D
    Roostfactor likes this.
  17. Nov 28, 2018 at 2:16 PM
    VolcomTacoma
    Jeff
    NorCal
    I literally can't even see it lol. Need to get a ladder and remove the grill so I can lay on the engine when I do all that shit lol. Can't lay on the fiberglass fenders, or they start creaking a bit to much haha
  18. Nov 28, 2018 at 2:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm saying I need less. Like 0 oz of delicious sweet beer. Hahaha.
    It's easy Jeff! Bring that beast over um ray and I'll pull it for you in 2.5 seconds. Actually.. 2.3 because it has to match my pulley size. :D
    BassAckwards[QUOTED] likes this.
  19. Nov 28, 2018 at 2:24 PM
    VolcomTacoma
    Jeff
    NorCal
    Meh, I'm gonna knock it all out in a weekend. Gotta do major overhaul on everything before Pismo.
  20. Nov 28, 2018 at 2:28 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    God I miss Pismo. I still need to rehaul my radiator support as I havent offloaded since. So for now, pavement pounder duties continue.
