TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 4, 2018 at 8:13 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You are good to go then! The 69.5 or 69.6" belt?
    There is a reason any good V8 D1SC/ P1SC Procharger and Maggie owners run Fleetrunner belts.
    Prior to finding the correct sizes all of us with the TRD blowers were living in the stone age as far as serpentine belt technology was concerned. The future is now. :D
    After you run your new belt, you will love your setup that much more. I promise you.
    mr.trd and BassAckwards[QUOTED] like this.
  2. Dec 4, 2018 at 8:14 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yup the open exhaust from headers back will definitely lessen any boost numbers @rjbiii But make no mistake MAF makes rwhp!
    mr.trd, Roostfactor, Norton and 3 others like this.
  3. Dec 4, 2018 at 8:17 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Its the k060696hd. I believe 69.56" according to pg.1 of this thread..
    Cant wait to get everything put on! Need to get a tensioner now though..
  4. Dec 4, 2018 at 8:18 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    My humble suggestion is the roostfactor belt wrap first. Easy, quick install, instant results. Gives you a more accurate measure of whatever size pulley you run.
  5. Dec 4, 2018 at 8:18 PM
    BassAckwards
    Thats what i thought as well! Thanks for confirming sir!
    12TRDTacoma[OP] likes this.
  6. Dec 4, 2018 at 8:20 PM
    BassAckwards
    I agree, i will probably do this, then the tensioner, and then put the new pulley on. Meth goes in this weekend though! So excited for that:D
  7. Dec 4, 2018 at 8:25 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm searching for best price on the tensioner now. Might hold out for a last minute online coupon. I'm also looking for a meth plate. Might alter one from a chevy ls. Wish I knew the bolt pattern between tundra and chev. Let me know if you have questions with the install.
  8. Dec 4, 2018 at 8:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @rjbiii If you plan to run both simultaneously the proper belt size is critical if you want to upgrade to the Roush tensioner in the near future shortly after. Striking the aluminum clutch fan blades will not sound pretty and will also cause some damage.
    BassAckwards likes this.
  9. Dec 4, 2018 at 8:29 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    How does that edlebrock tensioner you posted a couple pages back compare to the Roush one? @12TRDTacoma
  10. Dec 4, 2018 at 8:33 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's not a tensioner. Only additional reinforcement for the stock OE unit. The stock OE unit spring strength is still the same.. however, as I previously mentioned is not currently available, as Edelbrock is currently not producing it for some reason. The item is out of stock anywhere you look, even on Edelbrock's site.
    JuanitoBonito[QUOTED] likes this.
  11. Dec 4, 2018 at 8:37 PM
    BassAckwards
    Let me know if you find a good deal on it..
    What kinda meth plate you talking about?
    Will let you know if i have questions. Hopefully its a pretty straight forward install. The extra knock protection is my main reason for adding it. Im paranoid af now after having fueling issues for so long
  12. Dec 4, 2018 at 8:38 PM
    BassAckwards
    It is imperative to run the shorter belt because that forces the tensioner back down to where it would be with the stock length belt and the bigger pulley right? Just trying to get this straight in my head.. dont have an efan and probably will stick with my fan clutch for a while
  13. Dec 4, 2018 at 8:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Roush, Steeda, Thump, and ARS are the only full tensioner replacements still available.
    Pick the poison which best suits your wallet.
    Obviously ARS, and Thump are better choices due to the fact that they are fully overhauled full strength billet units, with not a single piece of cast aluminum in them, expensive, however, and will require decent modification to be a direct transfer on to the serpentine setup, including the purchase of a new double roller idler from LFP, which I've highlighted in page 1, which further drives the cost up (unknown if ARS requires as much nodding as the Thump unit). Rousch is the next bet which will require minor modification as well to work reliably on the serpentine system. It is stronger than the OE unit in every way and is cheaper than the full billet overhaul versions, however, is still cast aluminum.
    Pick your poison @JuanitoBunito.
    JuanitoBonito likes this.
  14. Dec 4, 2018 at 8:45 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you run a slightly longer belt with a higher effective length number the tensioner will rest at a position more south than the shorter properly sized belt, which makes the tensioner arm rest at a higher position which is a little closer to he clutch, but will never strike as the belt cannot become tighter than its brand new length, only loosen over time. The chance of striking the fan clutch decreases with a longer belt, but your ability to properly maintain belt pressure on the serpentine system falls back onto your tensioner, which is the wrong answer, even if it is half an inch longer over the properly sized belt.
    I hope that makes sense.
    BassAckwards[QUOTED] likes this.
  15. Dec 4, 2018 at 8:48 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I returned the steeda FWIW. Didnt like the idea of increased stress welding on a cast piece. Besides, you're paying a bunch for a pulley you cant use.
  16. Dec 4, 2018 at 8:50 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ball valve. My work is done here.
  17. Dec 4, 2018 at 8:51 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Murphinator and Torspd[QUOTED] like this.
  18. Dec 4, 2018 at 8:52 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    This I'm searching for to fit a tundra tb.Screenshot_20181204-205118_Samsung Internet.jpg
  19. Dec 4, 2018 at 8:54 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Could you tap some holes in the URD adapter?
  20. Dec 4, 2018 at 8:59 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Most certainly. I just know I can eff things up easily. Meth nozzles are tapered threads. I'm not sure how to do that. Advice welcomed.
