TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 5, 2018 at 6:49 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I'm gunna hope Magnuson/trd since he used BD first
    Nvm, I see he updated as I posted
  2. Dec 5, 2018 at 7:10 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    An RP5103 K&N. I would prefer dry, but the filter style is not exactly what I would call super common of those dimensions.
    Roostfactor[QUOTED] likes this.
  3. Dec 5, 2018 at 7:12 AM
    inwood customs
    Dave
    That thing looks huge :eek:
    Did u call AFE with the dimensions?
  4. Dec 5, 2018 at 7:15 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    As long as you inject between filter and TV there are no issues because its atmospheric. Anywhere between tb and sc will see only vacuum and between sc and intake valve will see boost/vacuum.
    Snow has check valves with 20psi cracking pressure and solenoids for the optimum setup because you can place the nozzle anywhere safely.
  5. Dec 5, 2018 at 7:22 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's what she said. ;)
    It's only a few inches larger over my current AMSoil cone filter both ways, definitely larger long ways. Of course I am no longer running a standard style URD intake. It's been modding before the 2nd 90* bend. I am going for bigger before the 90 and more open breathing as well. It will fit and will actually save me some space if I run it lengthwise.
  6. Dec 5, 2018 at 7:22 AM
    Roostfactor
    TX panhandle
    What URD kit?
    It doesnt matter where you buy the Magnuson sc, you have to get the Magnuson fit kit which includes all the brackets, pulleys, intercooler, etc.
    You said you replaced the injectors. Did you replace the sc injectors with new ones? If so, what injectors did you put in?
    We are trying to help you here so as much detailed info you can provide prevents a whole bunch of questions.
  7. Dec 5, 2018 at 7:26 AM
    Roostfactor
    TX panhandle
    I ask because there is a harness that runs the length of the drivers side valve cover. You are supposed to unhook the harness straps so the harness can rest more in the "V" of the engine so the sc doesnt crush it when you bolt it down.
  8. Dec 5, 2018 at 7:30 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    And thinking about it more @Greenwell808 has misfires predominantly on Bank 2. It would make sense if he has a wiring issue and skipped a step during install or whoever installed the SC kit and accidentally pinched wiring and is now having issues.
  9. Dec 5, 2018 at 7:36 AM
    Roostfactor
    TX panhandle
    That's why I said it genius! :D:thumbsup:
  10. Dec 5, 2018 at 7:48 AM
    Greenwell808
    Greenwell808 Member
    2014 Tacoma
    I put brand new injectors in, same that came with the kit from urd, I will have to look at them later to see exactly what they are. It came with everything intercooler, brackets and everything else I needed. I don’t know what kit it was to be exact but it also came with bully dog.
  11. Dec 5, 2018 at 7:50 AM
    Greenwell808
    Greenwell808 Member
    2014 Tacoma
    Yeah I removed the clips that hold that harness down and pushed it into the “v”. I am afraid I will have to pull the sc one more time and inspect the wiring.
  12. Dec 5, 2018 at 7:53 AM
    Greenwell808
    Greenwell808 Member
    2014 Tacoma
    Another thing is that when In park it idles fine right around 1,000 rpm then when I put it into gear it drops down to 500 rpm and that’s when I start to get cel and a rough idle.
  13. Dec 5, 2018 at 7:57 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    If you could fit a 3.5” or 4.0” ID filter you could run a donaldson powercore filter..
    mr.trd likes this.
  14. Dec 5, 2018 at 8:07 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I still have mine. Hope to install the stock pulley on that unit.
  15. Dec 5, 2018 at 8:16 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Do you have a picture of the filter you are mentioning? I am finding multiple results across the board.
  16. Dec 5, 2018 at 8:30 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
  17. Dec 5, 2018 at 8:54 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    1000 rpm sounds high for idle, maybe you split a hose and have a small vacuum leak?
    Normal idle for me is around 700-750
    mr.trd and Roostfactor like this.
  18. Dec 5, 2018 at 8:56 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    @12TRDTacoma when you do the pulley rip mod, how many sets of rips do you make going around the pulley?
  19. Dec 5, 2018 at 9:03 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    depends on the size of the pulley itself. I can't remember how many I did. It might had been 8.
    BassAckwards[QUOTED] likes this.
  20. Dec 5, 2018 at 9:05 AM
    BassAckwards
    Im going to rip my 2.6 this weekend thats the size i was inquiring about
