TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 9, 2018 at 3:01 PM
    aboftofbeam
    aboftofbeam Well-Known Member
    Karl
    San Diego, CA
    2012 Taco Off Road DBCB
    S/C, UCON, 2.8 pulley, bedrug, Crashnburn's ultimate headlight/tailight upgrade, Moroso oil-catch can, soundproofing, speaker and H/U replacements, bed stiffeners, SHMELLFAB Sliders, ICON AAL.
    Thanks!! Yep, I am blind as a bat sometimes (no offense to bats...):cheers:
  2. Dec 9, 2018 at 3:28 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Welcome to TW man.
  3. Dec 9, 2018 at 3:55 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's not your fault. It is mine. I listed the part number previously both in my build thread and here but in the banter pages. I forgot to carry over the part number into page 1 and only recently added it. Like I am talking between yesterday and today sort of added it.
    So... sorry about that. :bananadead:
  4. Dec 9, 2018 at 6:55 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeah I've got an ok bumper, I just added a lower skidplate down to the crossmember that killed my approach angle, found a different design that will be way better.
  5. Dec 10, 2018 at 11:37 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Murphinator likes this.
  6. Dec 10, 2018 at 12:31 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Someone's watching over me. It turns out we have an evap canister here at my work from a recent previous job from a 2009 Venza that had a defective leak detection pump (vent valve) and so the assembly was swapped out for a new one. Mine is in good condition and the canister is a direct bolt on. Minus specific brackets which will be transfer over items.
    I just saved myself over some $200. Merry Christmas to me indeed!
  7. Dec 10, 2018 at 4:56 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Santa was early
  8. Dec 10, 2018 at 5:19 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    LOL at the marketing, I'm sure it's going to offset rising fuel costs when you're pinning it everywhere.
  9. Dec 10, 2018 at 5:52 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Sweet setup. Just like my house, Santa left the tag on...Did you mean to post your addy?
    Murphinator and BassAckwards like this.
  10. Dec 10, 2018 at 6:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    He's discretely looking for more boost presents. :D :santa:
  11. Dec 10, 2018 at 6:28 PM
    DocME
    California
    '07 FJ Cruiser
    Ohhh, I like that plan.
  12. Dec 10, 2018 at 7:30 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    We call him Tony now.
  13. Dec 11, 2018 at 1:50 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Ya never thought of the address lol. If @DocME and @TodayWasTHeDaY csn delete my quote that would be good. Thanks lol.
  14. Dec 11, 2018 at 1:52 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
  15. Dec 11, 2018 at 4:54 AM
    TodayWasTHeDaY
    Russ
    Calgary
    Like a kid at Christmas! Too excited!
  16. Dec 11, 2018 at 4:58 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    but i mean if anyone wants to send me anything just pm me. sponsorships welcome lol
  17. Dec 11, 2018 at 5:40 AM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    You're going to have amazing fuel economy at the track now!
  18. Dec 11, 2018 at 5:48 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
  19. Dec 11, 2018 at 6:13 AM
    DocME
    California
    '07 FJ Cruiser
    looking forward to your review on this!
  20. Dec 11, 2018 at 6:15 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    wont be till spring...
    BassAckwards likes this.
