TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 11, 2018 at 6:19 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm testing right now:)
    BassAckwards and TodayWasTHeDaY like this.
  2. Dec 11, 2018 at 7:28 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yeah but I can't do that because you deleted your address.
    TodayWasTHeDaY likes this.
  3. Dec 11, 2018 at 7:33 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    How much higher does your Snow controller show your boost is vs your other gauge? my AEM is showing about a pound less of boost than the snow controller..
  4. Dec 11, 2018 at 7:39 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That's me too!! I dont know which one to believe. I guess a mechanical gauge could confirm.
  5. Dec 11, 2018 at 7:41 AM
    BassAckwards
    Interesting, its got me curious now.. will have to find someone with a mechanical gauge to help me confirm.. 8lbs sounds about right (thats what my snow gauge reads) at 2k ft elevation, a 2.6, and fully opened exhaust. could still have some belt slip though
  6. Dec 11, 2018 at 7:42 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Me too. Meth boost #s seemed more accurate for the mods I have as well.
    BassAckwards[QUOTED] likes this.
  7. Dec 11, 2018 at 7:45 AM
    BassAckwards
    Finally got my meth in. Was having troubles with it leaking some around the fittings on the pump. Think I finally sorted that out though thanks to @Athlaos . He recommended some of the real teflon tape (plumber's tape is what it was called) that's good for gas & oils, and that seems to have solved my issues. Loving it so far, and I only have it activating based on boost #s at the moment. Need to wire in the wires for IPW though, just too damn cold here to want to work outside for extended periods of time. Truck feels a good bit quicker though!
  8. Dec 11, 2018 at 7:46 AM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Check the battery, it has full warranty. We started to see lots of Interstates coming back to us in under a year so we stopped carrying them and now just carry the Toyota TrueStart Batteries, same battery, different sticker and longer warranty for the customer. I personally run a Odyssey because overkill.
  9. Dec 11, 2018 at 7:53 AM
    BassAckwards
    Anyone have some ideas as to how to make a gauge mount like this? @loginfailed perhaps? I know you have a similar one for your truck, but this is the first kind ive seen in a manual. Needless to say, im running out of places for gauges so I am now exploring this as an option..
    Norton, Athlaos and loginfailed like this.
  10. Dec 11, 2018 at 8:12 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Strike 2 for Interstate. I was telling him earlier that they were no longer no good either.
    Skootter14 and mr.trd[QUOTED] like this.
  11. Dec 11, 2018 at 8:21 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    I was in the same boat as you until 2 weeks ago. I can tell you,you are slipping the belt. I went with the Fleetrunner on page 1 listed for the 2.7/2.8 pulley and it has been a night and day difference. I thought I had belt slip before because of low boost number, but after the belt, I had belt slip for sure because now I hold the boost. Not any higher but it hold the number where as before it would jump from 3.6/1.2/2.5/.7/3.2/1.8 and continue to keep doing that through my whole pull. Now it goes to about 3.6 and hold within a tenth for the whole run. And my AFR has quit bouncing around as it is not constantly trying to adjust for a changing boost. And as for cutting it, I just counted out the ribs and layed the belt on a stainless steel work bench, had a buddy hold the belt and used a new razor and cut through the bottom of the V of the groove. Lifted the belt and razor at the same time after each stroke until we can around to the starting point and made sure I lined it up perfect so there was no "step". Basically cut the whole thing with one smooth razor cut. The cords inside to not run straight and you will run through them and see some when you are done cutting. Just like the outside cut from them.
  12. Dec 11, 2018 at 8:35 AM
    BassAckwards
    Go with a northstar battery if you can swing it. They are very good quality. Im running a 27F deep cycle in my truck and it is great!
  13. Dec 11, 2018 at 8:36 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's becoming fairly apparent to me that AEM can't make a boost gauge that reads boost accurately. Similar to how Innovate can't make a properly functioning MTX-L AFR gauge to save their lives.
  14. Dec 11, 2018 at 8:38 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I will buy a new belt just not right now. I plan on getting the rousch tensioner, smaller pulley (can’t decide what size yet) and meth injection kit all in one.
    I received my v3 logging cable from ovtune yesterday. No instructions on to use it yet though.
  15. Dec 11, 2018 at 8:44 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I cant be certain it's the aem gauge with the inaccurate reading. Who knows, it could be the snow gauge. Until a test with a mechanical gauge I will have only speculated.
    BassAckwards likes this.
  16. Dec 11, 2018 at 8:48 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    So keep my Innovate boost and AEM x-guage AFR? Like what you had/have? The OCD is killing me to not have them the same!
  17. Dec 11, 2018 at 8:51 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Same here, getting the Rousch tensioner and going to a smaller pulley. Just not sure what size.
    Murphinator[QUOTED] likes this.
  18. Dec 11, 2018 at 9:06 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I'm supposed to be getting the v3 cable here soon. I wonder if it's any different than the tactrix cable or not. Now with the announcement that 2019 is dedicated solely to Toyota tuning, I may hold out for the full tune software.
  19. Dec 11, 2018 at 9:12 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm not sure what gauges to keep. A mechanical gauge for a test would tell the truth. I may be able to borrow one in the near future. I'll happily share results.
    mr.trd[QUOTED] and BassAckwards like this.
  20. Dec 11, 2018 at 9:14 AM
    BassAckwards
    Please do! I will do the same once I figure out a manual boost gauge I can use
