TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 14, 2018 at 8:01 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Standard intake diameter is 76mm at the maf. The stock tb is 65mm and its further restricted by the butterfly.
    Airflow restriction through a tube is a factor of tube diameter and length.
    The 2nd gen 1gr has a larger intake tube and a different maf but I dont think it would work as @loginfailed pointed out about what the ecu.
    12TRDTacoma[OP] and BassAckwards like this.
  2. Dec 14, 2018 at 8:13 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    What pulley size do you guys think would be needed to be faster than a gen2 raptor? They weigh around 5500 lbs and make 450 hp / 510 tq at the crank.
    Asking for science reasons of course.
  3. Dec 14, 2018 at 8:16 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    A stock na Tacoma. Ford will likely break halfway down the drag strip
    mr.trd, henryp, BillDaCat8 and 3 others like this.
  4. Dec 14, 2018 at 8:17 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Lots of us still waiting on ever-elusive V2 updates from OVT. Any chance you can post what you learn...?
    Torspd likes this.
  5. Dec 14, 2018 at 8:29 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    2.5 + Meth? Further research will be required of course.
    Murphinator[QUOTED] likes this.
  6. Dec 14, 2018 at 8:33 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I'm sure some of the guys on here with 2.5 pulley, full exhaust and a dialed in UCON could take the raptor. Especially with the weight advantage. Probably the 2.5 guys on meth, as well.
  7. Dec 14, 2018 at 8:57 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    2.5 pulley it is.
    Mr raptor says his truck does 0-60 in 5.2 seconds. I’m not sure if it’s 100% credible buttt I think the taco could take it.
  8. Dec 14, 2018 at 9:05 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Swap me to some stock size tires and I'll take him on!!!
  9. Dec 14, 2018 at 9:57 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Shoot I'll take on Raptor dudes as is. Armor, tires, and all.
    I'll probably end up with the eventual P0103 code, but I'll just clear it and keep going. Lol.
    mr.trd, Roostfactor and snowsk8air2 like this.
  10. Dec 14, 2018 at 10:05 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Driver skill to be accounted for as well. I'll beat one.
    5thGearPinned, mr.trd and Roostfactor like this.
  11. Dec 14, 2018 at 10:09 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Why does that sound like it would be really easy to do.
    If changing the voltage is all you need to do to correct the airflow and changing the size of the intake diameter then it should be simple right?
  12. Dec 14, 2018 at 11:22 AM
    Roostfactor
    TX panhandle
    Do you have any pics of your setup? As long as you drop down to 3" before the maf you should be fine. You could step back up after that if you want. You can also try a honeycomb airflow straightener as well to minimize turbulence to the maf. That is my plan if I ever fabricate an intake.
  13. Dec 14, 2018 at 12:13 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Absolutely will.
    BassAckwards and Norton[QUOTED] like this.
  14. Dec 14, 2018 at 12:20 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I've been driving with v2 and seat of the pants, I can't tell any difference from v1. My max MAF on the Torque app dropped from 318 to 311 with v2. OAT temps have been the same.
    I wasn't expecting much because I'm pretty sure the tunes are from a 2.8 pulley. I'm guessing v2 was just static cleanup of v1 tables without any actual vehicle and dyno-tuning. As far as I know, he hasn't provided any specifics on what v2 changes. So far I'm not impressed with v2 and will be going back to TRD tune.
  15. Dec 14, 2018 at 12:23 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    That sucks, I was hoping OVT was a little bit more legit when it came to tuning. Seems like URD still really only has the only Plug and Play stuff for us these days.
    DocME likes this.
  16. Dec 14, 2018 at 12:31 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Don't get me wrong, I think his OVTune 93 file from the handheld is an improvement over the TRD tune on a 2.8 pulley and up. Some guys saw 20hp increase. I would stay on OVTune if I was on a 2.8 or stock pulley.
    It's the smaller pulleys with FPR where the OVTunes lose efficiency IMO.
    I still think the guy is definitely legit with his tuning skills. He hasn't even scratched the surface for our engines.
    Hopefully this year we'll have full tuning software. That's what I'm waiting for.
    BassAckwards and Norton like this.
  17. Dec 14, 2018 at 12:32 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah I saw that he said they were devoting 2019 to strictly Toyota. I just posted up in his thread, if he's got a good tune for me I'll give it a shot. Maybe clean up my AFR a little bit and gain me a little power back from switching to 35s. I won't hold my breath and still plan on UCON, but a little something now would be nice.
  18. Dec 14, 2018 at 12:58 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    U know I always recommend 2.0".
  19. Dec 14, 2018 at 12:59 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    If I wasn't chasing this carrot on a stick for a custom tune, I would have UCON by now. But I like the idea of custom tuning the ECU better than the piggyback, so I'm holding out.
    TodayWasTHeDaY and BillDaCat8 like this.
  20. Dec 14, 2018 at 1:19 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    And what a carrot it truly is. I don't know of anyone that has actually received a functional IOtech setup from OV yet.
    Mine has been bought and paid for for months now. Nothing in my mailbox yet. I've even been given a tracking number. Two weeks ago. Oddly, or perhaps not so oddly, there's been zero movement on that tracking number.
