TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 6, 2017 at 11:23 AM
    #1081
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Engineers that will never work on what they design. I used to argue with my engineering buddies about things they were designing. Either little mods for their trucks or projects around the house. Me being a mechanic at the time would always tell them to simplify things so they worked better.
    But then here I am now back in school going for mechanical engineering. Gonna be interesting when I get into higher classes and start challenging other students and teachers on their theories
  2. Dec 6, 2017 at 11:25 AM
    #1082
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    They thought taking it off and labeling it "non-servicable" was a good idea. Whatever makes the dealers more money is the name of the game here.
  3. Dec 6, 2017 at 11:31 AM
    #1083
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The photo directions on the included instructions for the valve body rehaul are not necessarily user friendly. Neither is the way the valve body solenoids, and valves, set up so I could see how you got confused with some distractions.
  4. Dec 6, 2017 at 11:34 AM
    #1084
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Been there. It is an uphill battle.
  5. Dec 6, 2017 at 11:35 AM
    #1085
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Life time intervals cause we throw away cars at 100,000 right?!?!?
  6. Dec 6, 2017 at 11:36 AM
    #1086
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Links... we wants links!
  7. Dec 6, 2017 at 11:37 AM
    #1087
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah I'm planning on it being one. But at least I already have good work experience when I finish and am looking for a job
  8. Dec 6, 2017 at 11:37 AM
    #1088
    12TRDTacoma
    Rob
    Concordia
    Boosted
    To them we do... remember we no longer fix, we REPLACE items. Even cars. Sort of like household appliances.
  9. Dec 6, 2017 at 11:52 AM
    #1089
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Its fun. Allt of problem solving and when it works as intended its a great feeling. Just try to not play the business side too much.
  10. Dec 6, 2017 at 12:18 PM
    #1090
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    There is a command which will shut down the UCON and then Techstream can make all the diasnostics again.
    loginfailed[QUOTED] likes this.
  11. Dec 6, 2017 at 12:47 PM
    #1091
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Tell me more...
    jojotoo likes this.
  12. Dec 6, 2017 at 1:39 PM
    #1092
    FinnJ
    Finland
    I sent PM to you.
  13. Dec 6, 2017 at 1:40 PM
    #1093
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Some doomasss
  14. Dec 6, 2017 at 1:41 PM
    #1094
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'll be better than they can can't grasp.
  15. Dec 6, 2017 at 2:22 PM
    #1095
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Thank you sir. That's the plan at least
  16. Dec 8, 2017 at 11:58 AM
    #1096
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Couple questions for those of you in the know.
    I have an opportunity to purchase a used TRD branded supercharger for my 4.0 with everything necessary to install (besides ecu re-flash)
    What should I be looking for when picking this thing up?
    Should I just re-build it before putting it in? Has receipts showing just under 60k miles.
    Whats a ballpark average price these are going for? (Obviously not looking for anything exact)
    I'll admit I have ALOT of reading to do, just decided to pull the trigger a week ago and havnt had time to sit down and do all of the research.
  17. Dec 8, 2017 at 1:24 PM
    #1097
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I may be in the minority, but the only way I would buy a used supercharger is if I was able to see/drive the sellers truck with the supercharger installed and running. Then have both trucks present and do the parts swapping. This is how @TacoCat sold his charger and both parties were pleased with the transaction.
    There’s always this bolt or that bracket missing. That hose that got lost. That funny noise that wasn’t disclosed. Etc etc. Then you have your truck torn apart and realize a piece is missing and have to scramble to find a new one or just jerry rig it or you end up having to buy a whole new fit kit to get all the parts you need. Too much potential hassle, IMO.
    Norton, Biscuits, Skootter14 and 5 others like this.
  18. Dec 8, 2017 at 6:20 PM
    #1098
    excorcist
    Reno, NV
    Here are the pictures he sent me.. see any stuff missing? If so I can ask to make sure he has it somewhere.
    I understand why some people wouldnt buy a used supercharger without seeing it in action. In my particular situation the potential pros outweigh the potential cons, just looking for proper protocol for this unique situation. Thank you :)
  19. Dec 8, 2017 at 6:56 PM
    #1099
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Did it come from a wrecked vehicle? I ask as normally they keep the injectors on the vehicle as the ecu is flashed for them and they can continue to operate the vehicle and/or sell it. Also is it local to you or would it be shipped?
    excorcist likes this.
  20. Dec 8, 2017 at 7:00 PM
    #1100
    excorcist
    Reno, NV
    Not wrecked, owner is selling truck and looking to re-coup money, I am actually driving to Arizona from Nevada to pickup a Habitat (~350lb camper shell) and this is on the way, and figure I could use the extra power for the extra weight.
