TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 16, 2018 at 4:25 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Quality tools make all the difference. I had ‘forged’ Chinese made pullers explode on me, multiple times, trying to remove the pulley and failing. I finally bought a made in the USA Forged Craftsman puller rated at 5 tons. It pulled the pulley off like it was child’s play with no deflection in the tool. You can see my experience here:
    https://www.tacomaworld.com/threads/urd-2-85-stealth-supercharger-pulley-install.416267/
    rmepilot, henryp, Torspd and 5 others like this.
  2. Dec 16, 2018 at 5:34 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Samesies. I always try to buy the biggest shit. Like if the pulley says "a 2 ton pulley puller will work" I'll go find a 4 ton or 6 ton. Jack stands, 6 ton (upgrading to 12 ton soon for higher length/strength because long travel). These days I'd rather spend the extra money on something I know won't break, than cheap out and risk wasting that "saved" cash and having to buy another one
    Learned that lesson enough times.
    mr.trd, Torspd, Norton and 4 others like this.
  3. Dec 16, 2018 at 5:47 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    If I did it over again I would drill and tap holes so u could use a steering wheel puller.
    12TRDTacoma[OP] likes this.
  4. Dec 16, 2018 at 6:00 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It will work, but the only difference is in the pulley ribs. Most M90's take a 6 rib pulley while the Cavalier/ Sunfire one has our 5 rib design.
  5. Dec 16, 2018 at 6:34 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    for those tuned in following the starting issue with the truck: got the battery tested and proved to be a bad battery (assuming I can trust the Advance Auto parts store and the tester they have).
    Gonna try and dig out the receipt for the Interstate battery since I bought it back in March '18 and HOPEFULLY can do a 1 for 1 swap under warranty. If not, then I will continue honing my search for a new battery to buy. I am tired of wasting money :annoyed:
    mr.trd likes this.
  6. Dec 16, 2018 at 6:41 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    It's only wasting money if its restoring a nissan.
    mr.trd and rmepilot like this.
  7. Dec 16, 2018 at 6:50 PM
    Skootter14
    Jeremy
  8. Dec 16, 2018 at 7:11 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    @Roostfactor @o0opackersfano0o @12TRDTacoma
    Looking back on this discussion from October about MAF readings on the TRD tune, I think Roost is on to something here.
    My max MAF on TRD tune was 321.8 on the Torque app and about 322 on the OVTUNE handheld real-time data (real-time data for TRD tune viewed on the handheld).
    This weekend, I swapped out my 2.5" TRD catback for a 3" banks exhaust and neither of the readings changed. Also cleaned my dirty AFE dry filter. Expected to see some kind of improvement, but still can't top 322.
    @12TRDTacoma you recently said you have MAF readings around 322 on a 2.3 pulley, correct? O0opackersfano0o was limited to 322.
    I think Roostfactor is correct and the tables in the TRD tune are limited to 322 or so.
    Has anyone with a TRD tune topped 322 MAF g/s?
  9. Dec 16, 2018 at 7:25 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Mine topped out at 322.45. Here a video of my data log when doing it. U can see it top out https://youtu.be/XTMSQggcp10
  10. Dec 16, 2018 at 7:31 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    So maybe some minor variances in sensor readings or what's being picked up in the datalogging, but the max MAF limits are still very similar.
    Roostfactor and 12TRDTacoma[OP] like this.
  11. Dec 16, 2018 at 7:37 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Seems to be. I don’t. I what ucon does to change that. I feel like it’s more the sensor maxing out but it can’t be if others are getting a higher reading using the same maf
  12. Dec 16, 2018 at 7:40 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Right, that's where I tend to agree with @Roostfactor 's theory that the ECU/TRD tune is limiting what we see in our logs. The sensor likely can read higher than 322-323
  13. Dec 16, 2018 at 8:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So the software top out appears to be 322 gm/ s apparently, but us who are hitting that limit are not being limited to that amount of power. As even after hitting that I feel the evident strength of pull as I continue to climb in RPM. So we must be hitting over 380 crank HP without a doubt.
    JacksonTacoma and Roostfactor like this.
  14. Dec 16, 2018 at 8:44 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Agreed. By installing a larger exhaust this weekend, my butt dyno feels a definite increase in power, but no change in max MAF readout.
  15. Dec 16, 2018 at 8:50 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I remember OVTune saying how much larger and better the TRD sc tune was over stock na tune. Not that the tune itself was better but the trd sc tune had much more expansion to the map from which he can tune from.
    It sounds like you guys might be hitting the top end of the TRD tunes map.
  16. Dec 16, 2018 at 9:01 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    The good news is it sounds like OVTune is planning on developing even larger maps so maybe he can address this and the fuel injector issue.
    I was hoping to get some incremental MAF comparisons when upgrading the exhaust and then adding your ypipe. Still plan to do another dyno after all those upgrades, but won't have a baseline dyno to compare each mod.
    Maybe one of the UCON guys can do before/after MAF comparisons for your ypipe
  17. Dec 16, 2018 at 9:49 PM
    VolcomTacoma
    Jeff
    NorCal
    Gotcha. Why couldn't you order the M90 quickchange and then just get some 5 rib pulleys from the m45 or something. I imagine the bolt ins should match up, just different shaft widths. Just wondering if you still have to shave the shaft way down for the m90 or not.
  18. Dec 17, 2018 at 12:35 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I already have the pre pipe data log on my UCON at 354g/s. Just waiting on the hardware for the followup. I've been wanting to take advantage of local dyno days. Hopefully I can get a pre and post in....We'll see.
  19. Dec 17, 2018 at 5:56 AM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    12TRDTacoma[OP] and ThomasMore66 like this.
  20. Dec 17, 2018 at 6:44 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Because there is literally zero point in doing so. The hub is the exact same, and the shafts are both the same specs. The M90 one is no more heavy duty or more special than the M45 one, as their hubs are both billet, as are the pulleys. So you would just be doing double the work by buying twice unless you are wanting to buy a pulley size which is outside the normal offerings Pulleyboys or Smoothflow has in their kits.
    This! We need some answers!
