TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 8, 2017 at 7:01 PM
    #1101
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    For the SC guys that want to go up a size...
    These 61 lb injectors will fit and work on the 1GR. But you'll need the little adapter harnesses.
    SIEMENS DEKA 107961
    Biscuits and excorcist like this.
  2. Dec 8, 2017 at 7:06 PM
    #1102
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    In that case if they keep the injectors you'll need a set. New belt and plugs ikh 22 or 24. Check the rotor tips for wear as well as the gear set. New oil. There are rebuild kits for the minimum rebuild as well as a full resto that included new rotors.
    Torspd and excorcist[QUOTED] like this.
  3. Dec 8, 2017 at 7:27 PM
    #1103
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    The injectors are included as seen in pics... He is including the plugs but I will be getting new ones.
    So looks like a full rebuild is around 800$ with rotor (doubt it needs that but like to plan for the worst) IF thats the case, and including new plugs, and belt, I would still be around half the cost of a new one, I guess everyone has a different sense of value, but this seems like a no brainer to me, maybe there is something I am missing?
  4. Dec 8, 2017 at 7:45 PM
    #1104
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Look in here to see the parts list.
    www.trdsparks.com/install/PTR29-35120inst.pdf
    Norton and excorcist[QUOTED] like this.
  5. Dec 8, 2017 at 7:57 PM
    #1105
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Nothing wrong with recycling.
    excorcist[QUOTED] likes this.
  6. Dec 9, 2017 at 2:29 AM
    #1106
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    I don't see the lower radiator hose or the thermostat extension & a bunch of hardware.
    you are going have an issue.
    See if you can find the install manual & you will have a better idea of what you should have with the kit.
  7. Dec 9, 2017 at 3:02 AM
    #1107
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The manual:
    Skootter14 likes this.
  8. Dec 9, 2017 at 8:41 AM
    #1108
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Many parts missing in these pics. Center latch support, upper pulley bracket, thermostat housing relocation tube and spacers/bolts. I wouldn’t worry about the hoses and the belt. You’d be replacing that stuff anyway like the spark plugs.
    If you can pick it up dirt cheap, and you trust that the guy is being honest about the blower itself being ok, I’d say buy it.
  9. Dec 9, 2017 at 8:49 AM
    #1109
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You can get any type of injectors reflowed to any spec you'd like for cheaper than what it would cost for these injectors. Even our TRD orange injectors.
    I would much rather have a true plug and play design over bolt on, adapt on and maybe play on design.
  10. Dec 9, 2017 at 9:52 AM
    #1110
    richiep
    Rich
    NY
    IMO for the amount of work involved with a s/c instillation, if your not going do a part for part replacement with the seller, then be prepared for a problems. a lot of the parts are not available by them selves & along with finding a particular part number for a missing part, it will be a major pita.
    If you can get the blower it self for a good price, then I would just pay for a new fit kit & I know at least I have all the parts.
    Norton, Torspd and loginfailed like this.
  11. Dec 9, 2017 at 9:55 AM
    #1111
    excorcist
    Reno, NV
    The install manual with parts list was very helpful, if IF the guy doesn't have ALL of the parts Im sure I can negotiate some more... What would you consider a good price for just the supercharger assuming it needs a rebuild as Im probably just going to rebuild it anyways.
    loginfailed likes this.
  12. Dec 9, 2017 at 10:10 AM
    #1112
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    That is an option. Take the injectors off. Ship them out or take them wherever to have it done. Wait with no injectors. Then put them back on. That may not be an option for some people, if it is their daily driver. How much money did they actually save?
    Buying new, one could also return to their original setup later on (if needed). After installing the new ones, they could keep the originals for a period of time to ensure they have a backup set in case there is an issue with the new setup. Then they could sell the old injectors if they wanted. Make a few bucks back or even come out ahead of the re-flow option.
    Lots of options, and best one is different for each situation.
  13. Dec 9, 2017 at 10:19 AM
    #1113
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I wonder if you have the stock injectors if you could reflow those and keep the orange ones as backup. I know nothing about reflowing injectors and how sucessful it is or how much they can increase the flow rate.
  14. Dec 9, 2017 at 10:28 AM
    #1114
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That is true. I know all about the daily driver situation, as this one is mine..
    If you live in or close to a major city there are usually fuel injection services available. Whether or not reputable, idk. Lol. Regardless, like in my case I know there is one local to me in the bay area and I could have them back within one business day for sure. They definitely offer reflowing services for injectors to match the CC size you desire.
    Sky is the limit on how much they can increase the flow rate. You could use any style injector to get the amount of flow you desire. The only difference is color in the situation you are talking about.
    Murphinator[QUOTED] likes this.
  15. Dec 9, 2017 at 10:30 AM
    #1115
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Glad I didn’t sell my stock injectors then
  16. Dec 9, 2017 at 10:42 AM
    #1116
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just did not too long ago. So I screwed myself, but luckily a set of 6 are cheap enough to buy. I am actually seriously considering going down this route as it would be an inexpensive plug and play swap which would allow me suffice fueling at the boost levels I want to run.
    I'm just a fan of direct bolt on, and/ or plug and play parts. The less adapters, splicing, modifying etc. involved for me, the better.
  17. Dec 9, 2017 at 11:09 AM
    #1117
    BillDaCat8
    Jake
    PHX
    I’m thinking like 500-750 or so. What’s he asking?
  18. Dec 9, 2017 at 11:48 AM
    #1118
    richiep
    Rich
    NY
    So If a whole new one from URD is 5 grand(a little on the hi side) i think i've seen them cheaper, then if you could get just the blower for a grand or less, you have the $800 for the rebuild & say about a grand for a fit kit, you will have a new setup for under 3 grand. just my thoughts.
  19. Dec 9, 2017 at 1:00 PM
    #1119
    excorcist
    Reno, NV
    Do you know where I can buy the fit kit seperate? Dont seem to be able to find it on Magnuson's website
  20. Dec 9, 2017 at 1:31 PM
    #1120
    excorcist
    Reno, NV
