TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 24, 2018 at 1:05 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Merry Xmas boost brothers
  2. Dec 24, 2018 at 1:15 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Merry Christmas my speedy friends, without you all my truck would be way slower and my bank account way healthier! Cheers to you all!:santa:
  3. Dec 24, 2018 at 1:21 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Merry Christmas. Today is one year with this truck too:thumbsup:
  4. Dec 24, 2018 at 1:24 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Sounds like you need to buy an anniversary present.
  5. Dec 24, 2018 at 1:28 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My wife decided to get creative with the wrapped gifts.
  6. Dec 24, 2018 at 1:33 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @Roostfactor Sassy wants to know when you’re coming to visit again.
  7. Dec 24, 2018 at 1:37 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Haha, I was just going to say...MY SASSY!!! I love that cat!
  8. Dec 24, 2018 at 2:25 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Already done.
  9. Dec 24, 2018 at 8:18 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    A Southwestern Christmas to you guys too.
  10. Dec 24, 2018 at 11:11 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Merry Christmas and may your New years be full of boost.
    Been trying to figure out what to do about the idler bearings. The stock NSK bearings are a specialty item that I'm having trouble finding a direct replacement. I got 10 years out of the stock set and this truck has seen it all. The stock NSK bearings are essentially higher quality automotive deep groove roller bearings that most likely have better grease and tighter tolerances than your standard roller bearing. This helps them survive the close to 20,000 rpm surges that the idlers can see. I originally thought ceramics sounded like a neat route as they can be made to be a durable bearing at higher speeds. My call to Micro Blue turned me away from their offering.
    I also called Ortech Advanced Ceramics, whom also makes custom Ceramic Bearings, to ask about the application. Their application engineer recommended their hybrid ceramics for this application. He said chrome steel or stainless races would be good. Silicon Nitride balls, PEEK retainers, seals, their SRL lube offering and either ABEC 5 or 7 specifications were recommended. The ABEC 7 is only available on the 6203 bearings. However these bearings in all are about $350-$400 total and take 2 weeks to ship. They actually hand assemble your bearings for you. These look awesome, but definitely a lot of money for idlers that really aren't going to free up much horsepower.
    Links to Ortech:
    6303- https://www.ortechceramics.com/prod...arings/6303-hybrid-ceramic-bearings-17x47x14/
    6203- https://www.ortechceramics.com/prod...arings/6203-hybrid-ceramic-bearings-17x40x12/
    Also looked into Boca bearing's offerings, which are a little cheaper. They had an option for some with heavy duty seal specifically made for offroading. I found a civic forum where an owner had one bearing fail after only 8,000 miles. Turned me off to the ceramics in general. I don't want to be left on a trail if the marbles come loose.
    Links to Boca:
    6303: https://www.bocabearings.com/products/smr6303c-2ys-th9-c4-3-nb2-9779
    6203: https://www.bocabearings.com/products/smr6203c-2ys-th9-c3-3-nb2-7583
    I started focusing heavily on the stock bearings or at least an equivalent. Most of these idler bearings share a lot in common with alternators. EMQ, or electric motor quality, is a term you'll see a lot of during these searches. Essentially, this means the bearings have tighter tolerances, steel retainers, and higher temperature lubricant. Alternator outlets are about the best places to look. I never did find an exact replacement, but Maniac Electric Motors does have a B17-102dg38 bearing for around $18 each. I'm not sure what the 8 denotes, but I'm sure it would be a good replacement. I also looked through NSK's catalogs and engineering manuals, but couldn't determine all of the stock specifications.
    After looking at the on the shelf options for high speed bearings, I came across these Timkens:
    63032RSC3 - https://www.qualitybearingsonline.com/63032rsc3-timken-deep-groove-radial-ball-bearings-17x47x14mm/
    62032RSC3 - https://www.qualitybearingsonline.com/62032rsc3-timken-deep-groove-radial-ball-bearings-17x40x12mm/
    They have some of the highest limiting speed and reference speed ratings that I could find in an on the shelf bearing. I've been a Timken fan for OEM replacements, I put them up there with Koyos for my preference. All in, these cost $70 delivered from Leeds. 2 day delivery time. We'll see how they last. Freed up enough to buy a shiny reservoir if I was so inclined.
    mr.trd, 5thGearPinned, Torspd and 8 others like this.
  11. Dec 24, 2018 at 11:28 PM
    Roostfactor
    TX panhandle
    Good stuff Doc. Thanks for doing the research on this and for the detailed post. :thumbsup:
  12. Dec 24, 2018 at 11:35 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Science of spherical goodness.
  13. Dec 24, 2018 at 11:40 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    When my OE bearings start failing I'm just going to replace with either Timken bearings or NTN and not analyze too deeply into it. If it lasts me just 60K I would be really happy with that for aftermarket replacements.
    On that note, Happy Holidays gents, and a very Happy New Year!
  14. Dec 25, 2018 at 2:06 PM
    ThomasMore66
    Since we share all kinds of ideas around here, I thought I’d share that the Viair 450P is a good portable unit. My latest toy. It will air up my 285’s relatively quickly. I haven’t bought off on the on-board air yet.
  15. Dec 25, 2018 at 2:44 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I’ve got the exact same set up. Anything better would be air on board with a tank. I’m very happy with it.
  16. Dec 25, 2018 at 7:20 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    i have a tank and cant say its overly useful. i dont run air tools and it doesnt make airing up noticebly faster :notsure:
    henryp[QUOTED] likes this.
  17. Dec 25, 2018 at 7:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You ventured deep into the bearing rabbit hole, Sir.
  18. Dec 25, 2018 at 9:54 PM
    DocME
    California
    '07 FJ Cruiser
    Yeah, that’s for sure. It would’ve been an easier decision if I could find identical oem pieces. Ceramics were a nice distraction, I haven’t had need to research them before. Just didn’t like the idea of replacing reliable parts with just any off the shelf bearing. I figure others will be coming up on their replacement timelines soon as well. Hopefully this helps.
  19. Dec 26, 2018 at 9:20 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Does anyone in here that has done an e-fan conversion have a stock fan/fan clutch that they want to get rid of? I have a 2nd gen 2.7L with 245k miles on it and I want to replace the fan clutch for preventative maintenance.. Let me know if you've got one and what you would be willing to take for it
  20. Dec 26, 2018 at 12:39 PM
    Roostfactor
    TX panhandle
    I've got one. You can pick it up in Jan if you want.
