TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 26, 2018 at 12:54 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Superb!:fistbump:
    Roostfactor[QUOTED] likes this.
  2. Dec 26, 2018 at 4:28 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Anyone have a spare 1GR-FE fuel rail that I can borrow for a while? I need to measure some things.
    Roostfactor and BassAckwards like this.
  3. Dec 26, 2018 at 4:41 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Tank can actually make things slower if compressor is small, since it has to build up pressure, best thing would be to add a second compressor or put a valve so you can use single compressor directly for some tasks or after tank is low. Or put in smaller tank maybe...
    I looked into a tank and decided for my non air locker use I didn’t need it.
  4. Dec 26, 2018 at 7:27 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Yeah, I have one. Do you just want some measurements, or do you need the rail?
    loginfailed[QUOTED] likes this.
  5. Dec 26, 2018 at 7:30 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I just ordered one off of Ebay. I just need to use it for mockup/measurement. I'm going to try building some bigger fuel rails.
  6. Dec 26, 2018 at 7:45 PM
    DocME
    California
    '07 FJ Cruiser
    Sorry I missed you. Just packed it away along with a set of TRD injectors and factory stock injectors. Fuel rail should be pretty easy to turn out I would think. The hardest parts will be adapting to the return line.
    Roostfactor and loginfailed like this.
  7. Dec 26, 2018 at 7:49 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Thanks, no biggie! The plan is to run -8an from the pumps to the rails. A -6an from the rails to an Aeromotive FPR. Then -6an line from the FPR back to the tank.
    Torspd, Murphinator and Roostfactor like this.
  8. Dec 27, 2018 at 1:51 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Sooo, why do you need larger fuel rails unless you intend to move more air? Things are working now. Just curious if there is going to be an engine rebuild soon to accommodate more burnable mixture.
  9. Dec 27, 2018 at 1:57 PM
    DocME
    California
    '07 FJ Cruiser
    Any chance you could provide some dimensions? I looking into alternate locations as well, my first route is looking less like an option. Also, from the product description, the bungs are 1/2"npt. Are you just adapting the 3/4" lines to the 1/2" bungs? Any concerns with the reduced diameter? I would think the pressure side would be fine, but the pump inlet side could be restricted? The pump flow is minimal, but I always worry about cavitation.
    Roostfactor likes this.
  10. Dec 27, 2018 at 2:00 PM
    ThomasMore66
    Figgs. Done.
    Torspd, Roostfactor and JuanitoBonito like this.
  11. Dec 27, 2018 at 2:06 PM
    DocME
    California
    '07 FJ Cruiser
    Haha, I know you're all about that Figgs. I just can't bring myself to it. Plus I'm seeking a new location after installation of a Bussman RTMR that bumped the factory location in front of the master cylinder. Now I've got the displaced 120V inverter competing for space in the back driver's side corner. My first option, a $15 aluminum tank just doesn't offer the clearance I was looking for. Now willing to look at the passenger side where I was holding out for a dual battery.....Who knows, maybe I'll join you in the ridicule over another piece of engine bling.
  12. Dec 27, 2018 at 2:15 PM
    ThomasMore66
    Oh, you be you. I'm just hanging out here steeling other people's ideas.
    Torspd likes this.
  13. Dec 27, 2018 at 2:23 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    ......I dig da figgs.
  14. Dec 27, 2018 at 4:09 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Infrastructure. And yes, there might be eventually.
    5thGearPinned and Roostfactor like this.
  15. Dec 27, 2018 at 5:01 PM
    ThomasMore66
    Uh huh. Might be... I’m thinking there is planning occurring.
  16. Dec 27, 2018 at 8:14 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'll check shortly. It is the same size or larger than the stock resivoir. 3/4" hose fits correctly. 4 5/8"x4 5/8"x 5 1/4" tank size. 7" tall with lid.
    DocME[QUOTED] and Roostfactor like this.
  17. Dec 27, 2018 at 8:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm going passenger side with mine.
  18. Dec 28, 2018 at 7:31 AM
    BassAckwards
    For all of you out there that have installed a fleetrunner green belt and had to trim it down to size, please make sure when you do so you have the size edge of the belt flat and no lip on it.. I didn't cut mine perfect, and the belt ran off, rubbed through the thermostat housing, and it started spewing coolant everywhere. The belt then proceeded to wrap itself around the crank pulley and snap, wrapping a bunch of the belt around it (all of this happened in less than a half mile of me driving after the belt came off). Could've been much worse, but I am very fortunate all it needed was a new thermostat housing and a belt.
  19. Dec 28, 2018 at 7:32 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Oh no good man. How imperfect was your cut??
    BassAckwards[QUOTED] likes this.
  20. Dec 28, 2018 at 7:33 AM
    BassAckwards
    Agreed, but she's up and running again now, so all is well!
