TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 29, 2018 at 1:47 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Agreed. That makes sense. Basically the multiplier would have to change to equal the new efficiency.
  2. Dec 29, 2018 at 1:48 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
  3. Dec 29, 2018 at 1:51 PM
    DocME
    California
    '07 FJ Cruiser
    If you mod the intake, I think there’d be a change in the maf reading that would equate to power gains or losses
  4. Dec 29, 2018 at 2:05 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don’t think MAF flow is directly affected by increased efficiency. But increased efficiency could indirectly produce more MAF flow.
    Not sure if that is the right wording to articulate that but it makes sense in my head.
    Take one unit of energy produced that is used for, say turning the accessories. Divert that unit of energy toward, say sucking more air in. Then you have more MAF flow.
    EDIT: but we know it’s not that simple!
  5. Dec 29, 2018 at 4:31 PM
    Roostfactor
    TX panhandle
    Im thinking of it like this: lets say max maf is 300 at 5500 rpm and 10lbs of boost with the stock sc inlet. I know there is a measure of restriction (vacuum) in the stock inlet at higher cfm which will put more load on the sc and sc pulley. Lets guestimate this at 60hp to drive the sc at max cfm and boost (with stock sc inlet).
    Now with a modified inlet under ideal conditions would have 0 vacuum at the sc inlet giving it all of the airflow it needs without any restriction. Thinking of it this way I think there may be some gain in maf but also a decrease in hp required to drive the sc. So the sc may only require 40hp instead of 60hp at 5500 rpm and 10 lbs of boost. This not only frees up hp to the wheels but just as important especially for our application is the reduced load on the sc, sc pulley, and belt. Because of the reduced load, belt slippage is less likely to occur.
  6. Dec 29, 2018 at 4:48 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think the gains would be more noticeable at the wheel than at the MAF.
    Either way besides maybe an increase in induction noises, I can’t see any scenario where reducing parasitic load via less air intake restriction is a bad thing. Unless there are some fluid dynamics principles or engineering stuff that say otherwise.
    @Lucario Runner
  7. Dec 29, 2018 at 5:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    And heat.
  8. Dec 29, 2018 at 5:35 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Everything in life follows the path of least resistance. ;)
  9. Dec 29, 2018 at 5:37 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Another thing to consider are vacuum pumps like the ones on race cars for the crankcase
    Roostfactor likes this.
  10. Dec 29, 2018 at 5:42 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Also another thing is to get a maf that has the readable value range that is desired. Like how on an sr20 or rb26 you get a 300z maf as it has more range. So i believe an equivalent for us would be a maf off a 3ur from a tundra.
  11. Dec 29, 2018 at 6:13 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I like a bit of resistance in certain areas. If you know what I mean... ;D
  12. Dec 29, 2018 at 6:25 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not all things should flow so freely, eh.
  13. Dec 29, 2018 at 6:29 PM
    Roostfactor
    TX panhandle
    True story.
  14. Dec 29, 2018 at 6:33 PM
    Roostfactor
    TX panhandle
    Like a well built engine. A lot of pressure with just enough lubrication to prevent excessive friction.
  15. Dec 29, 2018 at 6:35 PM
    Roostfactor
    TX panhandle
    @Torspd, how did you run your catch can that integrates the passenger side breather normally running to the atmospheric side of the intake?
    aboftofbeam likes this.
  16. Dec 29, 2018 at 8:50 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    you can do street acceleration extrapolations to get wheel horsepower/torque. more data points you have the better. delta speed change over delta time change i think it is. probably easier to look up how to do it than my half assed explanation
  17. Dec 29, 2018 at 8:51 PM
    Roostfactor
    TX panhandle
    That's a possibility. Especially if the data points are taken in close to the same conditions.
  18. Dec 29, 2018 at 10:05 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
  19. Dec 29, 2018 at 10:16 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
  20. Dec 29, 2018 at 11:07 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    ......yeah what the fuck lol good stuff
    mr.trd, loginfailed and zerotimeouts like this.
