TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 6, 2019 at 8:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :cheers:
    12TRDTacoma[OP] and rmepilot like this.
  2. Jan 6, 2019 at 9:10 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I’m no louder than a Porsche with the factory sport exhaust option. I’m good.
    I in no way support the new law but maybe people will think twice about just turning the knob to 11. I’ve been woken up at 3-4 am enough times by some kid with an overly loud exhaust.
  3. Jan 7, 2019 at 6:09 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Well fellas, Scott nailed it. Clogged Catalytic in Bank 1. Checked bank 2 and that was failing as well. Need to get rid of these. And just my luck the URD headers are not available right now...
    When I separated the header from the Y pipe, I could see the guts were blown out and clogging that leg. Removed the header to find it completely empty of media. Peeked at the other side and the media was starting to separate. I bet I have less than 20k mi on these. @Chickadee is having similar issues. Looking around other car forums I start to see a pattern.
    So I have to take the whole exhaust off, shake it, vacuum it and hope all that junk is out so that it doesn't rattle and clog some more.
    I have been on the stage 1 tune the whole time these have been on and I have data logs showing that it was running properly. I am guessing this would happen again with a replacement set unless aFe has made some changes.
    In the mean time I could throw my stock manifolds back on; boooo! Or I could gut the other aFe header and just run them both open.
    I wonder how the truck will like running with those empty cat sections so close to the motor? I assume it will be louder but will I cause any trouble?
    Torspd and BassAckwards like this.
  4. Jan 7, 2019 at 6:16 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Glad Scott figured out the issue! Gutting the front cats wont cause any issues. You have the UCon, so no need for o2 sims, as they're built into the UCon. Truck will likely run better without the cats since it will be able to breath more easily. Expect it to be a bit louder though
  5. Jan 7, 2019 at 6:19 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    What's the issue with the URD headers not available?
  6. Jan 7, 2019 at 6:21 AM
    findingthingsout
    midwest
    Sold his stock, waiting for the next batch to be built.
    I inquired on status last night, waiting for reply.
    Torspd and JacksonTacoma like this.
  7. Jan 7, 2019 at 6:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You should definitely inform AFe. I think I have heard of this from a handful of other members as well.
  8. Jan 7, 2019 at 6:31 AM
    findingthingsout
    midwest
    I sent an email with pics last night. I don't think anyone would be satisfied with a $1500 set of headers failing so soon. Not sure how they could make this better besides a refund...
  9. Jan 7, 2019 at 6:33 AM
    617mike9c1
    617mike9c1 Well-Known Member
    Newton, MA
    2008 DCLB Sport 4wd
    A little of this and a little of that
    I talked to Gadget last week and he said the headers are done but are waiting to be ceramic coated at the vendor and he doesn't have an ETA. The headers have been there since before the holidays.
    JacksonTacoma likes this.
  10. Jan 7, 2019 at 6:35 AM
    findingthingsout
    midwest
    Thanks for the heads up.
  11. Jan 7, 2019 at 6:36 AM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Good to know. Might be pulling the trigger on these soon. Thanks for the heads up.
    mr.trd and 617mike9c1[QUOTED] like this.
  12. Jan 7, 2019 at 6:41 AM
    findingthingsout
    midwest
    Truck had been running great up until this point. Now I am getting the mod bug real bad. Wanting to get the 7th inj kit and a 2.5" pulley. But I should probably spend that money on a re-gear and then revisit that idea...
  13. Jan 7, 2019 at 8:32 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    My set that I ordered in August/September were in that batch. I kept in constant contact (squeaky wheel) and he was able to get 6 sets to fulfill a couple of orders. He's going to have to find new source for ceramic coating, that has to be killing his sales on these.
    617mike9c1[QUOTED] likes this.
  14. Jan 7, 2019 at 8:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Setting up his own station to do the spraying, would/could help a lot in that regard. It would take out at least one middle man.
    617mike9c1 and DocME[QUOTED] like this.
  15. Jan 7, 2019 at 8:41 AM
    DocME
    California
    '07 FJ Cruiser
    You got that right. Plus he could control the quality. I think his equal length headers are some of the best performers out there, hopefully he gets it all straighten out.
    617mike9c1 and Torspd[QUOTED] like this.
  16. Jan 7, 2019 at 8:43 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Signed earlier.
    Just another reason, I can't live on the left coast anymore... :angrygirl:
  17. Jan 7, 2019 at 8:45 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  18. Jan 7, 2019 at 9:32 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    :cheers: Its really nice here ...
  19. Jan 7, 2019 at 9:39 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    We’ve been thinking of the possibly of retiring there in 7-8 years. (Arizona) It at least is one of the front runners....
    Biscuits, mr.trd and GT7[QUOTED] like this.
  20. Jan 7, 2019 at 10:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
