TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 7, 2019 at 10:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Move there. Then....
    Build a wall on the West Boarder. Lol
  2. Jan 7, 2019 at 10:33 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Definitely want out of Illinois where ever we go....
    rmepilot likes this.
  3. Jan 7, 2019 at 10:34 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    You can have him. We already have too many people coming from Cali since we are right next door.
  4. Jan 7, 2019 at 11:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hopefully right minded people. Hopefully.
    rmepilot and snowsk8air2[QUOTED] like this.
  5. Jan 7, 2019 at 1:25 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    There's houses right by me in Durango. Pretty close to AZ, UT, and NM.
    mr.trd likes this.
  6. Jan 7, 2019 at 1:26 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Col is on the list too.
  7. Jan 7, 2019 at 1:26 PM
    ThomasMore66
    Can you tell what exactly failed? I've worried that too much richness would foul the cats, but failure wasn't part of that calculus.
  8. Jan 7, 2019 at 1:31 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Do the AFE headers + cats have a metal core? With all the failures sounds like cheap material. Probably fine for an N/A motor, but junk with boost.
    Torspd likes this.
  9. Jan 7, 2019 at 1:31 PM
    ThomasMore66
    LOTS to do in the area: biking, skiing, climing, etc. I can be in Moab in a couple of hours. As long as the parks are open (I won't make any political remarks), you can go all over even in the winter. There are a few of these books: https://www.amazon.com/gp/product/193483825X/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1. I have one for CO and one for UT. I like seeing what's on the other side of the hill.
    JuanitoBonito[QUOTED] likes this.
  10. Jan 7, 2019 at 1:52 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Probably ceramic core.
  11. Jan 7, 2019 at 1:53 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Well, I cannot say for sure the cause of failure. Looking at the bank 2 side, the center section is symmetrically sliding out. Kind of like one of those frames of needles that you could get at the mall. Where you can imprint an image from the backside. Know what I mean?
    The cats are metal core with a ceramic coating. The bank 2 side is in crumbles, like packing material in my Y pipe. That cat chamber is completely cleaned out and smooth.
    Reading online it seems that there is little benefit from running a gutted cat, to issues of echo and reverse pulsation back to the motor. Guessing the increased diameter of the cat chamber overcomes the restriction from the media. Removing media results in turbulence and less scavenging.
    Maybe these are a good option for N/A...?
  12. Jan 7, 2019 at 1:57 PM
    findingthingsout
    midwest
    That CO book is priceless. I was able to spend a week on the alpine loop, black bear pass, Imogene, almost all my bucket list roads this past fall. Amazing, terrifying, and beautiful!
  13. Jan 7, 2019 at 3:02 PM
    ThomasMore66
    I haven't been too many places yet in CO. Took my father-in-law up past Silverton right before Thanksgiving in an effort to hit part of the Alpine Loop (I think that's what it is called). Then he asked me what elevation we were at because he had a headache... Argh! He's 86. I took him back down because hurting the father-in-law would not improve my odds... He had fun, though. So, I'll probably take him towards Moab and Arches. Lower elevation... He's my ticket out of the house! Gee, dear, your dad really wanted to go.
    mr.trd likes this.
  14. Jan 7, 2019 at 3:09 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I believe the afe headers are a ceramic core. Best compromise imo would be to buy shorty headers and weld or vband a cat or high flow cat w/metallic core to factory flange or vband (less stealth but good for quick change).
    Torspd and jojotoo like this.
  15. Jan 7, 2019 at 4:04 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Plus, the mountains are amazing! Montana, Idaho, Wyoming, Utah and Colorado have the best mountains by far.
    Norton, JuanitoBonito and rmepilot like this.
  16. Jan 7, 2019 at 4:16 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    That’s what ruined Oregon 40ish year’s ago. Now I can’t ever move back. :facepalm:
  17. Jan 7, 2019 at 4:33 PM
    rmepilot
    Rob
    Huntsville, AL
    I ordered my URD headers over 6 weeks ago and they’re stil out of stock. What pisses me off, is they charged my CC back in November... :rant:
  18. Jan 8, 2019 at 7:36 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Update on my truck running rich again. Hooked it to the uTune and monitored my AEM gauge versus the WRAF #1 and #2 and my AEM is way off. Under idle it is corect, but under boost or lower vacuum it is not right at all. My AEM goes clear to 8.02 under boost and the WRAF is sitting at about 12.5-12. On a closed course for testing procedures. Not sure why the gauge is so far off. Brand new X-guage as of November.
    DocME likes this.
  19. Jan 8, 2019 at 7:38 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    That makes me nervous. I've got those gauges too. I hit low 9's this morning. Wonder how to see what's really accurate.
    mr.trd[QUOTED] likes this.
  20. Jan 8, 2019 at 8:05 AM
    findingthingsout
    midwest
    I would start at the sensor, not the gauge. I think if the gauge is failing you are more likely to see it bad across the spectrum. This may be a case of a Bosch sensor giving up early. May try a Denso version instead.
