TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 23, 2019 at 9:42 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I might abstain from formal advice until the code is known regarding the CEL. Specifically the URD headers aren’t too loud for my tastes, and I really don’t want a loud truck. I would say the loudness of the exhaust is heavily dependent upon the muffler and resonator combination. What exhaust do you have?
    I have a URD exhaust that has a magnflow muffler and vibrant resonator that does a good job at curtailing the exhaust note. However, I also have 4:88 gears and the exhaust noise in the cab is certainly louder than I’d like right now (keep in mind I have an FJ). I would think that if I had a bed with an exhaust tip outside the confines of the body, I’d be pretty happy. Exhaust sounds very good for this engine and not raspy as I currently have a stock y pipe with Cats.
    You stated you have a mid pipe, I assume URD. If you add headers, your exhaust could end up with a raspy less desirable note. Definitely something to be aware of.
    BassAckwards and Torspd like this.
  2. Jan 23, 2019 at 10:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Crafty plan. ;)
    Good note on the cams. I haven't done any research.
    I have a Boomslang harness in my 1GR. Flawless construction. Connecting my Haltech.
    Engine builder that did my 1GR has also done at least one 1FZ. As an additional option only.
    I wouldn't mind a 1FZ in my 328is Bimmer. Giggity.
  3. Jan 23, 2019 at 12:28 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
  4. Jan 23, 2019 at 12:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only 2 tenths a liter more. Wanting a "big block." :D
  5. Jan 23, 2019 at 1:15 PM
    ThomasMore66
    Hey @Roostfactor, where did you post that graph of pulley size to supercharger speed? I'm curious how much faster and how much more air I move going from a 3.0 to a 2.5 pulley. Things are coming back together. Waiting on the freakin' o-ring. Trans valve body is installed. Shifts are good. Some additional tweaking of the solenoid was required to get rid of a shudder that predated the valve body install. That was my driveline vibration - converter shudder.
  6. Jan 23, 2019 at 1:19 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I suspected the converter at one point for a thud I was experiencing. It went away when I replaced the driveshaft. Glad I was wrong!
  7. Jan 23, 2019 at 1:30 PM
    ThomasMore66
    Still have all 5 gears. I thought about you when it came back together.
    loginfailed[QUOTED] likes this.
  8. Jan 23, 2019 at 4:52 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    S65 DCT. do it!
  9. Jan 23, 2019 at 5:43 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    BassAckwards likes this.
  10. Jan 23, 2019 at 6:12 PM
    ThomasMore66
    @12TRDTacoma, where did you tap in to get temp up/down of the intercooler?
  11. Jan 23, 2019 at 6:44 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    6.5" crank pulley ÷ 3" = 2.16
    2.16 x engine rpm so 2.16 x 5500 = 11,916 blower rpm
    6.5" ÷ 2.5 = 2.6
    2.6 x 5500 = 14,300 rpm
    zippsub9 and BillDaCat8 like this.
  12. Jan 23, 2019 at 7:40 PM
    ThomasMore66
    So a 20% increase. Nice.
    Roostfactor[QUOTED] likes this.
  13. Jan 23, 2019 at 7:47 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I re-removed my bypass restrictor jet yesterday. For those of you with the UCON and a 6spd i recommend it. Heavier throttle tip-in is much smoother vs before. With the restrictor jet in, i noticed a hard jerk/shudder if I got on the throttle a little too quickly. Now it feels like im rolling into the throttle even when getting on it. I was considering getting a sprint booster or pedal commander to try to work around this, but now im happy with it. Dont know if im making more boost or if vacuum has been affected, but its more drivable in my opinion
  14. Jan 24, 2019 at 8:23 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Quick follow up on my failed cats. Swapped in my OE headers and issue was resolved, obviously. Got a lot of power back. Roads have been too slick to do any data logs yet to confirm all is well.
    And a shout out to aFe, they sent me a complete set of replacement headers with the HW kit. All I did was show picks of header removal, media stuffed in the Y-pipe, and a shot of my invoice through Amazon. Shipped to my door, no cost.
    A mean, I have helped sell some of their intakes so they kind of owe me anyways...
  15. Jan 24, 2019 at 8:29 AM
    Roostfactor
    TX panhandle
    Still that's great customer service. What is the HW kit?
    inwood customs likes this.
  16. Jan 24, 2019 at 8:29 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Good on AFE for sending you new headers, but they may want to address their product's multiple failures on boosted applications...or start providing a disclaimer. I would only run these on an N/A setup after all the cases of failure.
  17. Jan 24, 2019 at 8:31 AM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Hardware?
  18. Jan 24, 2019 at 8:32 AM
    findingthingsout
    midwest
    HW= Hardware.
    I am hesitant to bother putting these in. The media looks the same, guessing the outcome would be as well.
    URD is really blowing it with the lack of header availability...
    Roostfactor, DocME and inwood customs like this.
  19. Jan 24, 2019 at 10:18 AM
    Roostfactor
    TX panhandle
    You mean headers with cats or are they out of stock on their regular URD equal length headers?
  20. Jan 24, 2019 at 10:36 AM
    findingthingsout
    midwest
    Referencing the equal lengths. They have been waiting to get ceramic coated for months. Someone ordered a few months back, was charged but still have not received product. Not cool.
    I don't need the cats where I live. Just trying to be good and keep the stink down. If I switched to long tubes I would add a 3" cat further down the line.
    Maybe it's time you improve on the equal length offerings...?
    Might be hard to keep it near the URD price point. To my small mind they look really complicated to fabricate...
