TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 26, 2019 at 6:48 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  2. Jan 26, 2019 at 7:16 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I can’t thank you enough for the maintenance post. I am doing a full rebuild since I have yet to install the supercharger. I finally got the rear needle cup bearings out, holy crap that was brutal. I am taking some pics to add to the maintenance section if anybody wants to go that far later on. I did swap the pulley and c-clip, but I don’t think I am going to change out the nose cone bearings or seal.
  3. Jan 27, 2019 at 5:56 AM
    Roostfactor
    TX panhandle
    Yes pics would be great. How did you get the needle bearings out?
  4. Jan 27, 2019 at 6:42 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Well because of the cold lately, I started by bringing the housing indoors. I tried propane on the backside to heat up the housin as well but don’t think this was much help. I didn’t want to remove the boost bypass valve again or damage it from too much heat in the vicinity as well (another story but I fixed that as well, the mounting plate was bent from resting the weight of the system on it).
    Blind Hole Bearing Puller is the tool needed. The one at harbor freight will work but I found a cheaper one with more options on Amazon (pictured). I did not realize the needle bearings are completely cupped and you can’t damage the housing or machining. Don’t set the bearing puller at the bottom of the bearing. You want to catch the top lip of the bearing and then use a bunch a small taps with the slide hammer. There is a rubber/nylon synthetic casing that holds the bearings in place that will fall apart and become destroyed. It is fine and will often affect the seating of the puller so you may end up tearing it out banging away on the puller. I pinched the heck out of my hand which hurt like hell, but my taps became increasingly more angry as I channeled @Torspd build thread vibes. Eventually they come out, I used a small bit of anti seize on the new bearings to seat them in. I used the back side of a 3/8 ratchet extension that fit perfectly inside the cup to seat them. I also left them in my freezer overnight to help. I was told they only need to be .002” depth and can be as deep as .006”. I checked the depth often since just bottoming them out in the housing may be too deep.
    More pics to follow
    51559FFE-6724-44DF-BDE0-31B5ECEB2152.jpg 2AE854BA-AFF5-4DED-80C1-BB7E6C2EBD06.jpg F762A935-79C3-4125-AB2E-C6CE6F414E13.jpg
  5. Jan 27, 2019 at 2:04 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I’m curious how much the TRD intercooler displaces heat on a 2.5 or lower pulley on those 90 degree days. But You really are moving everything to the passenger side. Wish there was a completely broken blower out there to test cutting/welding on :thumbsup:
  6. Jan 27, 2019 at 2:14 PM
    TRON
    My blower has around 90K on it. And most of that is on 2.55 and NST Kit. And my blower still purrs at idle. I think these blowers are pretty much indestructible. But it would be fun to dissect and rebuild. I don’t know of anyone that’s rebuilt the shaft bearings yet on the 2nd gen TRD.
  7. Jan 27, 2019 at 2:32 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    My shaft bearings were replaced at 90k. I also had scoring on the shaft (drive side) that had to have a sleeve installed. I think they’re pretty durable but, certainly not indestructible. This was all on the stock pulley.
    Torspd likes this.
  8. Jan 27, 2019 at 2:37 PM
    TRON
    Who did your rebuild? I presume you swapped out new needle bearing too?
  9. Jan 27, 2019 at 2:51 PM
    DocME
    California
    '07 FJ Cruiser
    Yeah. Jon Bond did my rebuild. I was his first 4.0 S/C. Still running good at 176,000. I originally had a factory spring coupler fail, which is why I had the whole unit rebuilt.
  10. Jan 27, 2019 at 4:24 PM
    Roostfactor
    TX panhandle
    Was the scoring on the shaft from the coupler spring?
  11. Jan 27, 2019 at 4:26 PM
    Roostfactor
    TX panhandle
    I've seen a couple videos. It doesnt look difficult but a press and a few tools are needed.
  12. Jan 27, 2019 at 4:35 PM
    Roostfactor
    TX panhandle
    2.85 pulley I would see a 20° delta at 75mph
    2.5 pulley I see 25 to 30° delta at 75mph
    Something to note is the above temps are when the engine is still in vacuum.
    A hard run up to the speed limit yields a 45 to 50° delta.
    Highest temps I've seen was when going up a long incline in a headwind with 112°F oat. 200° inlet and 140° outlet was observed and steady for at least a few minutes. Engine was running about 5 psi boost the whole time.
    No issues, no knocking, nothing.
    I would have felt much better with a small shot of methanol though!
  13. Jan 27, 2019 at 5:57 PM
    DocME
    California
    '07 FJ Cruiser
    I'm not sure. Sounds plausible, but I never really fully understood exactly what caused the scoring.
    Roostfactor[QUOTED] likes this.
  14. Jan 27, 2019 at 6:18 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    2.9L whipple supercharger
  15. Jan 27, 2019 at 9:11 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    :eek:
  16. Jan 27, 2019 at 9:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Is that a hole saw, with a bearing attached? Prototype genius!
    aboftofbeam and TodayWasTHeDaY like this.
  17. Jan 28, 2019 at 8:41 AM
    Roostfactor
    TX panhandle
    Yes it would be nice but I'm not too worried about it. :D
  18. Jan 28, 2019 at 8:04 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I may have reached the limit of the TRD tune. Still waiting on the new O-Ring for the lid, but preliminary tests (leaking) showed much higher afr’s at part throttle with new plugs, new tensioner, closed bypass, and 2.5”. May have to go back to 2.6” until ov, fuel pump and bigger injectors.
  19. Jan 29, 2019 at 8:10 AM
    Roostfactor
    TX panhandle
    Are you running FPR mod?
  20. Jan 29, 2019 at 8:11 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Are you still running the stock fuel pump or do you have a 255lph?
    Roostfactor likes this.
