TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 25, 2017 at 2:13 PM
    #1201
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Merry Christmas you speedy bastards:taco:
  2. Dec 26, 2017 at 5:14 PM
    #1202
    Nachotaco
    Nachotaco Well-Known Member
    Jonathan
    Georgia
    2012 tacoma v6 manual transmission 30k on truck 2.85 pulley ucon ems. Running into some issues and am thinking it may be my clutch. Supercharger installed a little while back but less than 1000 miles since install and seems fine under low-medium throttle. Under 3/4 to full throttle (already in gear) it looses power and even bucks like a bad clutch let off. EXAMPLE- in third gear once I reach 2500 rpms I give the vehicle 3/4 to 100% of throttle vehicle will not smoothly accelerate through the rpm/power band. Im not a mechanic I just learn something new each day. Am I expecting too much from my stock clutch or could this be another issue entirely? Where do I start? Any help would be fantastic. Posting here by recommended by @20tacoma17
  3. Dec 26, 2017 at 5:38 PM
    #1203
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    If while in gear & accelerating, & the the tach is climbing & the truck isn't going faster, then it's the clutch. Clutch slippage after a s/c install is common with a stock clutch.
    The bucking you describe sounds a little like rev limiter, hilting the max rpm's shuts down the ignition to prevent engine damage.
  4. Dec 26, 2017 at 5:42 PM
    #1204
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    .......mine does it
  5. Dec 26, 2017 at 6:00 PM
    #1205
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Are u running an oiled air filter like k&n?
    Maybe its time for a maf sensor cleaning
  6. Dec 26, 2017 at 6:13 PM
    #1206
    oni06
    oni06 Well-Known Member
    Bucking sounds like the UCON Guardian feature kicking in.
    Is your ECU stock, TRD Flash, Magnuson/BullyDog Flash??
    If you can reproduce the issue I would do a Data Log using the uTune app.
    Nachotaco[QUOTED] and richiep like this.
  7. Dec 26, 2017 at 6:22 PM
    #1207
    Nachotaco
    Jonathan
    Georgia
    No reflash just the ucon.
    Took me a few runs but now i can replicate the issue when needed. Need to research this utune app
  8. Dec 26, 2017 at 6:30 PM
    #1208
    oni06
    Officially you contact Gadget and he puts you in touch with Scott.
  9. Dec 26, 2017 at 6:36 PM
    #1209
    Nachotaco
    Jonathan
    Georgia
    @Gadget@URD Gadget i need some assistance. Can you help me?
  10. Dec 26, 2017 at 6:39 PM
    #1210
    oni06
    I would email or call him. Forum is hit or miss.
  11. Dec 26, 2017 at 7:58 PM
    #1211
    inwood customs
    Dave
    Very high miss.
    Call him, ext 3
    JuanitoBonito and oni06[QUOTED] like this.
  12. Dec 27, 2017 at 3:57 AM
    #1212
    Nachotaco
    Jonathan
    Georgia
    Could someone pm me gadgets phone or email if you have it handy? Thanks!
  13. Dec 27, 2017 at 4:44 AM
    #1213
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Just call the number on the urd website and ask for him
  14. Dec 27, 2017 at 5:08 AM
    #1214
    inwood customs
    Dave
    877-8URDUSA
    ext #3
    leave a messege, Gadget WILL call u back.
    He has called me at some respectable times (my time zone) that have been VERY late or early (his time zone).
  15. Dec 27, 2017 at 7:03 AM
    #1215
    Nachotaco
    Jonathan
    Georgia
    Called this morning. I will post as i get updates.
    inwood customs likes this.
  16. Dec 27, 2017 at 7:48 AM
    #1216
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Do you have a AFR gauge? I think your the AFR goes too rich. Mine do it too at certain throttle.
    Vote for another issue. Do you have an AFR gauge? I think the AFR goes too rich. Mine do it too at certain throttle. 2.85, UCON and manual too, but FJ, not Tacoma.
  17. Dec 27, 2017 at 4:54 PM
    #1217
    Nachotaco
    Jonathan
    Georgia
    [QUOTE=" Do you have an AFR gauge? I think the AFR goes too rich. Mine do it too at certain throttle. 2.85, UCON and manual too, but FJ, not Tacoma.[/QUOTE]
    I do not have an afr gauge. I guess i had hoped that the ucon would do a better job of engine management as a plug and play unit. :notsure: it is possible though that it is not related to the ucon ems at all. I called gadet today but did not hear back from him( i know its vacation time for alot of folks). Saying that afr and boost gauges are on my short list.
    I just need to put together a workable kit/gauge/mount/time/money solution.
  18. Dec 27, 2017 at 5:06 PM
    #1218
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I could just be that the UCON guardian feature is kicking it to protect your engine. Need to do some datalogs.
  19. Dec 27, 2017 at 5:19 PM
    #1219
    Nachotaco
    Jonathan
    Georgia
    So this is going to sound newbie cause it is. Im not afraid to learn something new. @Torspd how do i do datalogs?
  20. Dec 27, 2017 at 8:06 PM
    #1220
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Best way is to email Gadget with URD the symptoms of the engine, and Scott who manages the UCON stuff will email you instructions on how to datalog.
    Nachotaco, oni06 and Torspd like this.
