TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 2, 2019 at 6:39 PM
    eon_blue
    Azusa, CA
    Not 100% certain since I bought my 04 in 2016 and the supercharger was installed by the previous owner, the Toyota dealer didn't have any info on it. But, the truck only had 24k miles on it so I predict the supercharger had the same (probably less) assuming it was new when installed. Currently at 76k miles on the truck so I figure around that much on the supercharger.
    Roostfactor[QUOTED] likes this.
  2. Feb 2, 2019 at 6:46 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Wow that is a surprisingly low price. Unfortunately I won’t make Laughlin in June. Hopefully actually doing rubicon in July which is why we were in Laughlin last year because rubicon got cancelled. Starting a roll cage in the spring, so that’s my big truck spending for this year.
    Murphinator[QUOTED] likes this.
  3. Feb 2, 2019 at 6:47 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Just pulled the trigger on URD headers. Has anyone waiting on their order received an update on the powder coat holdup?
  4. Feb 2, 2019 at 11:08 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That's an amazing find!!! Wow a 12 year old truck with 24K of probably easy miles.
    Well done! :cheers:
    EDIT: I wouldnt be concerned about additives to the main fuel tank. I have never heard of a premature bearing failure due to a 7th injector.
    eon_blue[QUOTED] likes this.
  5. Feb 3, 2019 at 6:06 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Looks a little smaller installed.
  6. Feb 3, 2019 at 6:10 AM
    ThomasMore66
  7. Feb 3, 2019 at 9:56 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Still doing some reading on the 2.7 pulley......
    I currently have a 255 Walbro fuel pump.
    Would the consensus be to swap to a 320 fuel pump or I’m I safe to stay with the 255??....
  8. Feb 3, 2019 at 10:10 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    255 Walbro can handle any TRD blower setup with room to spare
  9. Feb 3, 2019 at 10:53 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I got the 2.7 and will be staying on my 255lph pump. I have the deatschwerks but should be the same as the walbro.
    JuanitoBonito[QUOTED] likes this.
  10. Feb 3, 2019 at 11:30 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I got 2.6 and 255. Plenty of fuel.
  11. Feb 3, 2019 at 1:16 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's safe. I have ran BG intake cleaner solution through the blower before. It's best to introduce it through the brake booster port while you are running the engine at 2000rpm. Make sure you slowly meter the amount you put in as you go.
  12. Feb 3, 2019 at 1:36 PM
    JDLCmx
    JDLCmx New Member
    Jorge
    Laredo,Tx
    2014 G.Grey Tacoma TX ED
    Air intake and exhaust
    From urd
    Ordered my headers on Black Friday
    On Jan 28, 2019, at 7:56 PM, info@urdusa.com wrote:
    The batch of headers have been at the ceramic coater for a long time now. Can't get an answer when they will actually coat them and send them back.
    Steve (Gadget) Dopler
  13. Feb 3, 2019 at 5:48 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Ok, so URD is finally sending my headers (ordered them Thanksgiving...). o_O
    Do you guys recommend replacing the mounting hardware?
    If so, does anyone have the part numbers or prefer an alternate source?
    Roostfactor and JacksonTacoma like this.
  14. Feb 3, 2019 at 5:59 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Yes. ARP studs. I have to look for the part number for you.
  15. Feb 3, 2019 at 6:01 PM
    rmepilot
    Rob
    Huntsville, AL
    Sweet!
    When are you back in town?
  16. Feb 3, 2019 at 6:16 PM
    Scott B.
    Scott
    Georgia
    I’m in town now. Got here a little while ago.
    How’s the new driveshaft?
  17. Feb 3, 2019 at 6:22 PM
    rmepilot
    Rob
    Huntsville, AL
    Muuuuuuuuch better. :woot:
    I still need to shim the axle to get completely vibe free, but my main issue has been resolved.
    I do need to borrow your u-joint tool again, so I can break the shaft down and stow it away. I'm hoping a recall will eventually happen...:fingerscrossed:
    Plus, we need to do lunch again soon. :hungry:
  18. Feb 3, 2019 at 7:24 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Torspd likes this.
  19. Feb 3, 2019 at 7:26 PM
    rmepilot
    Rob
    Huntsville, AL
  20. Feb 3, 2019 at 7:42 PM
    DocME
    California
    '07 FJ Cruiser
    Yep, that’s it.
    rmepilot likes this.
