TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 4, 2019 at 8:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The donor engine that I used for the fitment originally, was mine, but was from an 03-04 4Runner. The 05+ did have a tighter stud tolerance.
    The trick was then to get a thread chaser , since it has a flat tip. Allowing it to clearance threads, all the way to the bottom.
    DocME[QUOTED] likes this.
  2. Feb 4, 2019 at 8:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  3. Feb 4, 2019 at 9:54 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Bummer......:pout:
    loginfailed[QUOTED] likes this.
  4. Feb 4, 2019 at 10:57 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Not sure I can pull this off. I’ve been out of town for a quite a few weekends skiing. What is the best day to go?
  5. Feb 4, 2019 at 11:09 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Saturday. 3PM. That's when the bikini contest is scheduled.
  6. Feb 4, 2019 at 11:18 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Exhibition Class ehh... man that would be cool to drive out for this..
    BassAckwards likes this.
  7. Feb 4, 2019 at 2:07 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Who has nst light weight crank pulley and likes it? I no it needs to have steel insert. Just wondering if it’s worth it
  8. Feb 4, 2019 at 4:14 PM
    ThomasMore66
    I’ve never heard a complaint. Been thinking about it myself.
  9. Feb 4, 2019 at 4:14 PM
    ThomasMore66
    You’re a bad man. We’re there for horsepower.
  10. Feb 4, 2019 at 4:18 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    @TRON I think
  11. Feb 4, 2019 at 4:19 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I think he has the larger crank pulley, that's not available any more?
  12. Feb 4, 2019 at 4:20 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    This is what i thought too.
    Im also interested to hear what people think of the lightweight nst pulleys. Theyre on my list as well
  13. Feb 4, 2019 at 4:39 PM
    ThomasMore66
    Like it needs to rev faster... yeah, it needs to rev faster. Regear too.
    BassAckwards[QUOTED] likes this.
  14. Feb 4, 2019 at 6:11 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Don’t you jump my shit @ThomasMore66 :crapstorm:, what are these crank pulleys you guys are talking about?
  15. Feb 4, 2019 at 6:18 PM
    BassAckwards
  16. Feb 4, 2019 at 6:43 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
  17. Feb 4, 2019 at 6:45 PM
    BassAckwards
    Thats what i want to know.. If you get serious about buying them, i have a bunch of 20% off codes. they always email them to me. They're always putting things on sale
  18. Feb 4, 2019 at 6:56 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Nice, I can’t imagine that they are too difficult to put.....
  19. Feb 4, 2019 at 7:19 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I definitely think they are great quality pulleys. It’s true the overdrive SC TRD pulley is not made anymore. But I think getting the crank and steel sleeve pulley, alternator, fan, and water pump pulley would make for higher performance revs.
  20. Feb 4, 2019 at 7:21 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Not bad for $250....
