TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 8, 2019 at 3:30 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Good to know. That brings up another thought about how much room there is at the header merge for the sensor. I will be running a j-bung on the downstream sensors so that probably limits me to keeping them in the ypipe anyway and just plugging the front bungs.
    Roostfactor likes this.
  2. Feb 8, 2019 at 3:48 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    2.85". Nothing crazy.
    BassAckwards[QUOTED] likes this.
  3. Feb 8, 2019 at 5:12 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Don’t have any but IPT was very helpful over the phone.
    I guess “HD” just signifies stiffer springs eh. Will probably still go with IPT so I don’t make a big giant mess. How much was the ratiotek?
  4. Feb 8, 2019 at 5:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yup. AEM, interfaces with the can system. So still good for OBD inspections. Except only plug n play with 05-08. Haltech is great, but does not interface with the CAN system on ours.
    Or possibly @OVTune, as you only are tuning the factory equipment, so it will always be good with the OBD inspections. Just have to weigh your overall needs.
  5. Feb 8, 2019 at 5:51 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I wonder if ovtune could reprogram the ecu. If not I am sure finding an ecu shouldn’t be too difficult. I would have to get one that could be flashed to the trd tune as well. That way it will have expanded tables for optimum tuning. Probably a pipe dream but if I find one for sale for cheap enough I am probably stupid enough to buy it lol.
  6. Feb 8, 2019 at 5:52 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    It was like $25 on Amazon if I remember correctly.
  7. Feb 8, 2019 at 6:02 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I found mine on car-part.com for $200 bucks. The ECUs arent too hard to find
    Torspd and Murphinator[QUOTED] like this.
  8. Feb 8, 2019 at 7:05 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I have a stock 2013-2015 ecu if any one wants it
  9. Feb 8, 2019 at 8:17 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    What do you want for it?
  10. Feb 8, 2019 at 8:42 PM
    Kelvin
    Kelvin Wheeeeee
    Wonder how it compares to IPT
  11. Feb 8, 2019 at 8:45 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'd say ipt would be better. I would have went for the ipt vb but this is my daily ride. Down time isnt an option. I like my ratiotek upgrade. But for me too much is barely enough.
    12TRDTacoma[OP] likes this.
  12. Feb 9, 2019 at 8:30 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I would hope that a VB replacement would not be any comparison to an Amazon special. WAT sold me on the concept that their entire VB had been reconfigured. I'll go take a picture of the contents of my ratiotek box.
    Edit: here is everything in the box.
    118BB0A7-F167-4A4B-BF3D-488FE13962E5.jpg OD8769DB4-B295-42B9-B6F0-DCE909364AA4.jpg
    12TRDTacoma[OP] and rmepilot like this.
  13. Feb 9, 2019 at 8:43 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
  14. Feb 9, 2019 at 8:47 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Is that a gen 4 model prototype?
    BassAckwards and rmepilot like this.
  15. Feb 9, 2019 at 8:52 AM
    ThomasMore66
    Shouldn’t there be a kid in that picture?
    Norton likes this.
  16. Feb 9, 2019 at 9:18 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Nice! Here are a few of my son's over the years...
    Tiger Car
    Tank (with swiveling turret)
    Gold Bar
    Concrete Block
  17. Feb 9, 2019 at 9:22 AM
    ThomasMore66
    We still have my son’s cars in a box in the garage. Did you buy a scale, wheel mandrel, jewelers polish, etc.? We (maybe me) got into it.
  18. Feb 9, 2019 at 10:18 AM
    rmepilot
    Rob
    Huntsville, AL
    :anonymous:
  19. Feb 9, 2019 at 10:23 AM
    ThomasMore66
    It’s about the kids...said no dad ever.
    rmepilot[QUOTED] and Roostfactor like this.
  20. Feb 9, 2019 at 2:29 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You may have waited too late to do the Ratiotek kit. It just depends on mileage out on the tranny as a whole. Mine started flaring at around 50K. I did the upgrade at about 65K, but I also let off on the gas everytime I upshift to 5th.
    I don't do that so much anymore, but it was a method I learned from my GTO to baby the clutches a little longer when I was having slippage from 3-4 shift with the 4L65e transmission. That huge piece of crap.
    GT7 and Torspd like this.
