TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 14, 2019 at 12:28 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You could also install everything but the belt and then just put the belt on after the reflash
    Making bypass stay open is also a good idea
  2. Feb 14, 2019 at 1:00 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Absolutely. Everyone’s needs are different. For me, the 60 was perfect.
    I have a shackle flip, Dakars, and B110s right now. Once this round of mods is done, I’m leaving this thing alone for the forseable future. I just need to wheel the damned thing.
    I only started that thread to let people know that there was another option out there. ECGS hadn’t advertised it previously.
  3. Feb 14, 2019 at 1:19 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Oh for sure it is a great option for probably a good handful of people. My buddy actually tagged me in that thread and I took a look, but not right for me. I assume you went with 4.88 gears?
  4. Feb 14, 2019 at 1:28 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    That’s a funny story...
    Last Spring I ALMOST did 37s. The only thing that stopped me was that I didn’t want to regear again. I had 35s and 4.56s then.
    So I bought new 35” Cooper Pros. Then, I broke my rear Diff. ECGS was kind enough to regear it to 4.88s while they were fixing it under warranty, and did me a solid on doing the front as well.
    A month after, I broke in my brandy new 4.88 ring gear.
    So yes, now I have 4.88s and 37s
  5. Feb 14, 2019 at 1:29 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    This will not be a problem at idle. The lack of larger injectors only become a factor as you introduce more demand for fuel based on boost.
    If the person who you responded to has a boost gauge installed, I'd like to see what his current air fuel ratio is under higher larger loads, the band aid for that would obviously be to do FPR if his AFR's are too lean under boost to aid richening it up. The obvious solution is the 455's, however.
    BassAckwards[QUOTED] likes this.
  6. Feb 14, 2019 at 1:30 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    how were the 35's with 4.56's and boost?
    :spy:
  7. Feb 14, 2019 at 1:39 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Felt WAY better than 33s and no boost :D
    I have some baby tires that I put on when I get an alignment. Although over geared, that feels much better than both.
    At this point, with 130 lb wheels and tires, I’ll probably need all the boost just to be driveable...
    Honestly, I now whish I’d stopped at the 2.85 pulley and stage 2 tune. That’s enough to make the truck OK to drive.
    Anything else is a waste of money on a 6000 lb ish truck with 130 lb 37s IMHO. It’s never going to be fast.
    henryp and RyanL like this.
  8. Feb 14, 2019 at 2:13 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Don't say that, I was just thinking I need new injectors and a 2.5 pulley. Along with all the other things that I need to do.
  9. Feb 14, 2019 at 2:13 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Well, Hunter S. Thompson said it best (change the topic in his text to your truck)"
    “We had two bags of grass, seventy-five pellets of mescaline, five sheets of high powered blotter acid, a salt shaker half full of cocaine, and a whole galaxy of multi-colored uppers, downers, screamers, laughers... and also a quart of tequila, a quart of rum, a case of Budweiser, a pint of raw ether and two dozen amyls. Not that we needed all that for the trip, but once you get locked into a serious drug collection, the tendency is to push it as far as you can.”
  10. Feb 14, 2019 at 2:13 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    That’s what I’m running and it’s fine. Going from 33’s to 35’s with the same gearing makes you notice it though. Hence why I don’t think 4.88’s and 37’s will be enough.
    @HolyHandGrenade how do the 4.88 and 37’s compare to the 4.56 and 35’s?
  11. Feb 14, 2019 at 2:16 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Blasphemy!
  12. Feb 14, 2019 at 2:37 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    No idea. Haven’t driven the truck since Oct.
    It seemed perfect with 35s and 4.88s TBH.
  13. Feb 14, 2019 at 2:39 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    You know? I say that, but towing the trailer to Moab, I was happy to have every single pony.
    Don’t listen to me. Best advice I can give :D
    mr.trd[QUOTED] and RyanL like this.
  14. Feb 14, 2019 at 2:40 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Ahh well you’ll have to report back after you drive it with 37’s. I already know 4.88 and 35’s are perfect because I have 4.56 and 35’s and it needs just a bit more gearing.
  15. Feb 14, 2019 at 2:45 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I certainly will. It’ll be another couple of months probably.
    I’m in NH right now because my Mother fell. Concussion, broken rib, etc. no work on the truck for a week or so.
  16. Feb 14, 2019 at 2:49 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Ouch, well hope she heals up. You mentioned Moab a few times, where you at? I’m in AZ but get up that way at least once a year or so. Have another option now that my parents bought a place in sand hollow
  17. Feb 14, 2019 at 2:53 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Sorry to hear that about family @HolyHandGrenade. I have been on 4.88s and 35s for quite a while now. 35s are Duratracs. Going to go larger shortly, but the only thing I can’t stand is 2600 RPMs at highway speed crushing fuel mileage. A new LRA fuel tank helps with that now, but boost and 4.88s will suit my needs fine with 37s.
  18. Feb 14, 2019 at 3:04 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    ive now heard 4.88s and 35s is a bit much for an auto multiple times. That 37s match the 4.88s are much better especially for highway cruising.
    im not regearing till my shit breaks :crapstorm:
  19. Feb 14, 2019 at 3:21 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thanks man. I’m staying up here so she can stay off her feet for at least a week.
    I’m in NJ, so it’s a hike out there. I went to Rock Therapy the last two years. Totally killed wheeling over here for me. I love it out there.
    It’ll be a couple of years before I go back most likely. My truck is moving from towing things to being towed.
    I need to figure out what I want for a tow rig now.
  20. Feb 14, 2019 at 3:23 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thank you.
    Tell me about it. Towing my trailer out last year, I checked my MPGs twice. Under 7 both times...
    Granted, I was doing 75-85 MPH most of the way with a 2.55 pulley etc.
    I had an auxiliary fuel tank setup though. That made it tolerable. Until the credit card bill came anyway...
