TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 16, 2019 at 6:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Head gasket was still good?
  2. Feb 16, 2019 at 6:33 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yes! Pulling a BF trailer.
  3. Feb 16, 2019 at 7:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Keep on truckin' then!
  4. Feb 16, 2019 at 10:38 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    All done. Damn I am tired but that was awesome and I haven’t even done more than a test drive to cycle the fluids. Rented a truck tomorrow to go pickup some tires and then hopefully Monday I can undo the safety wire holding open the bypass valve. Thanks for all the help on this forum, it is nice to know people are willing to help out at a moments notice.
    richiep, Torspd, Roostfactor and 7 others like this.
  5. Feb 17, 2019 at 10:01 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Safety wire? Sounds like mil aviation mech talk. You got another one here buddy.
  6. Feb 17, 2019 at 10:31 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Ha, just another dumb infantryman who learned about safety through race inspections. I safety wire everything now. Weapon sights, lasers, you name it.
  7. Feb 17, 2019 at 11:43 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Oh safety/lock wire. Nothing like having a crap ton to do on the 30mm gun for the Apache.
  8. Feb 17, 2019 at 12:05 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    How many twists per inch :D
    zippsub9, Torspd and Norton like this.
  9. Feb 17, 2019 at 12:14 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    For those that have a jfr y-pipe and attempt to use j-bung extensions you may be removing the pipe to get the j's on. The passenger side only worked on the upper bung.... just barely. Time to get warm, then put some miles on it for testing.:fingerscrossed:
  10. Feb 17, 2019 at 12:56 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Depends on the size of wire...
  11. Feb 17, 2019 at 1:17 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I think @Roostfactor is taking care of that now for jbungs
  12. Feb 17, 2019 at 2:13 PM
    rmepilot
    Rob
    Huntsville, AL
    TSB issued for the rest of us? :ohsnap:
  13. Feb 17, 2019 at 5:28 PM
    Roostfactor
    TX panhandle
    6 to 8 TPI is my standard is suppose, I just look at it to see what looks right.
    Stryker420 likes this.
  14. Feb 17, 2019 at 5:33 PM
    Roostfactor
    TX panhandle
    Yes I have checked fitment with one y-pipe but that doesn't mean that all will fit exactly perfect. As with many installs, its best to temp install all parts before tightening everything down. So before anyone torques the flange bolts down, install the j-bung adapters and see if they fit.
  15. Feb 17, 2019 at 6:16 PM
    rmepilot
    Rob
    Huntsville, AL
    In all fairness, you said to install the j-bungs first.
    I chose not to, because I wasn’t sure my headers would ever show up.
    Roostfactor[QUOTED] likes this.
  16. Feb 17, 2019 at 6:20 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    My experience went just fine. Trying to pass on important tips. As of 5 miles tested things are working out.
  17. Feb 17, 2019 at 6:32 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Small orifice?
  18. Feb 17, 2019 at 6:34 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes, smallest in the kit. They require snap ring pliers. Ask me how I know....
  19. Feb 17, 2019 at 6:35 PM
    rmepilot
    Rob
    Huntsville, AL
    Probably as eventful as my axle shimming that’s going on tonight. :angrygirl:
  20. Feb 17, 2019 at 6:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Oh boy. That definitely sounds like something I shouldn't force with needle nose pliers.
    rmepilot[QUOTED] likes this.
