TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 17, 2019 at 9:49 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    There's someone that makes a better pipe, I just can't remember what his name is or how to find him...
    :rofl:
  2. Feb 18, 2019 at 5:49 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I thought the new driveshaft fixed your vibration issue?
  3. Feb 18, 2019 at 5:52 AM
    rmepilot
    Rob
    Huntsville, AL
    95% of it, but still had an excessive angle at the pinion. I have a slight vibration at startup and wanted to eliminate that as well.
    The D/S was toast.
    Roostfactor likes this.
  4. Feb 18, 2019 at 6:20 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Reason I need suspension done. Cant tune a d/s when the axel isnt as solid as it could be.
    Just more money.
    Roostfactor and rmepilot like this.
  5. Feb 18, 2019 at 6:28 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Question- is the j-bung extension intended to lessen the code tripping or eliminate it for good? Trying not to celebrate too early but it's working for me. Nice hard pull this morning with the meth dumping and no issues. Awesomeness.
  6. Feb 18, 2019 at 7:06 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Nice. What all did you install?
  7. Feb 18, 2019 at 7:39 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    J extension and sims. PM me your PayPal info.
  8. Feb 18, 2019 at 7:53 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    some claim it's eliminated for good
  9. Feb 18, 2019 at 8:22 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Peanut butter jelly time...all for $108, more than fair. Although not local and they never called back, still got it done.
  10. Feb 18, 2019 at 9:34 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Yeehaw!
    BassAckwards likes this.
  11. Feb 18, 2019 at 4:49 PM
    rmepilot
    Rob
    Huntsville, AL
    Had to adjust again (I over shimmed last night), then verified my work with the TREMEC app.
    Everything is now within the recommended angles. Thank you for suggesting it! :hattip:
  12. Feb 18, 2019 at 8:06 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How's it drive now???
  13. Feb 18, 2019 at 8:53 PM
    rmepilot
    Rob
    Huntsville, AL
    Still have a slight vibe below 25mph.
    I'll have a better idea tomorrow, while headed to work.
  14. Feb 18, 2019 at 9:55 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Or changed the drivers side plugs without pulling the sc. BBB4951D-5C1A-4E20-B29F-8EDF280F6EEB.jpg
  15. Feb 19, 2019 at 3:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Using mine as an example. Very slow speeds (5-10) on a smooth surface, I would notice a bumping or bouncing. As if the road surface was highly irregular or uneven. The next grouping of speeds would be over 70 miles an hour. And then there would be a tremendous amount of rear end vibrations.
  16. Feb 19, 2019 at 5:55 AM
    rmepilot
    Rob
    Huntsville, AL
    Sounds like mine.
    My old DS had excessive wear in the slip joint, causing moderate vibrations above 55 mph. This was resolved with the new DS, but today I had vibs again above 80mph... :anonymous:
    Torspd[QUOTED] likes this.
  17. Feb 19, 2019 at 10:49 AM
    Roostfactor
    TX panhandle
    Grrrrr
    rmepilot[QUOTED] likes this.
  18. Feb 19, 2019 at 12:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Try rotating your tires, to see if the vibration moves? I had a very out of balance tire once. Manufacturer flaw. Found out when I swapped the fronts to the rear.
  19. Feb 19, 2019 at 12:29 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Concur, just did it yesterday after having vibrations at 50-55mph and it all is smooth as butter now. I am going try checkered flag tire balancing beads only with 37s on SCS 17x9 -38mm, in the next week or so. But, yeah an out of balance tire on the front even slight will drive me bat sh!t crazy.
    Torspd[QUOTED] and rmepilot like this.
  20. Feb 19, 2019 at 12:42 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    What do you guys think of this to retain my sleeper look? Not sure if it can even be done to my mirror but it looks cool. Other option would be PLX. Also no gauge pods available for my car so whatever I rig up will probably be ugly.
    http://www.radar-mirror.com/AEM.html
