TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 19, 2019 at 12:51 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I second all of this. Still needed the valve body. In the instructions they have you make an adjustment to the solenoid that controls lockup rpm.
    If you’re all manual, ignore all of this.
    rmepilot likes this.
  2. Feb 19, 2019 at 1:23 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    I plan on that, prior to any further adjustments. I’m due for a rotation and balance anyway.
    Torspd[QUOTED] likes this.
  3. Feb 19, 2019 at 1:55 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I like it. Can you get it with dual displays so you can monitor both sensors?
  4. Feb 19, 2019 at 3:56 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Not sure of what the limitations are. I’d assume whatever the AEM gauge displays is what the mirror could. I just require AFR. Boost gauge seems rather pointless for me. I want to know how much it costs really.
  5. Feb 19, 2019 at 5:31 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    That’s pretty slick. Lots of gauges. Now like AEM, PLx, Innovate are pretty thin so if you can find a spot on dash you can probably just drill hole and mount them. But that mirror is pretty stealth.
  6. Feb 19, 2019 at 5:58 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Damnit. J-bung sim combo lasted a couple days. Codes a tripped.:censored:
  7. Feb 19, 2019 at 5:59 PM
    rmepilot
    Rob
    Huntsville, AL
    :sorry:
  8. Feb 19, 2019 at 6:08 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That's ok. This is what I get for screwing with a perfectly fine truck.
  9. Feb 19, 2019 at 6:13 PM
    rmepilot
    Rob
    Huntsville, AL
    I really hope sims or sims/j-bung combo works for me. I fk’n hate CEL’s.
  10. Feb 19, 2019 at 6:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'll reset and keep trying. I was idling in traffic.
    rmepilot[QUOTED] likes this.
  11. Feb 19, 2019 at 6:19 PM
    rmepilot
    Rob
    Huntsville, AL
    Never give up! :thumbsup:
  12. Feb 19, 2019 at 7:07 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    What’s the deal with ovtune not being able to get those codes disabled? As far as I remember he was confident he could disable them..
  13. Feb 19, 2019 at 7:10 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ovtune can. I just suck at computers. I cant figure out how to mail my tune back. Sounds simple. Not for me. Last time I had to mail my handheld to him because neither of us could figure out why it wouldn't load.:frusty:
    rmepilot and JuanitoBonito like this.
  14. Feb 19, 2019 at 7:12 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’m no bueno at computers either.....
  15. Feb 19, 2019 at 9:04 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Here you go...
  16. Feb 19, 2019 at 9:06 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Oh no it’s illegal... :rolleyes:
  17. Feb 19, 2019 at 9:08 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    He has to say that, publicly I’m sure.
    BassAckwards likes this.
  18. Feb 19, 2019 at 9:25 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    But there are no laws where I’m at. And the truck is for closed course competition use only. (Unless we get snow like the last 2weeks)
  19. Feb 20, 2019 at 5:34 AM
    ThomasMore66
    And by no means are we advocating for the circumvention of any laws.
  20. Feb 20, 2019 at 6:36 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    so i have dtlt headers and urd y pipe and thinking my cat back is limiting more power. i have a cheery bomb welded in and a weld in muffler. should i go with a urd cat back for the most performance gains? i just dont want it stupid loud. and i hate the thought of spending that money on a cat back and then welding a resonator in.
    loginfailed and BassAckwards like this.
