TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 25, 2019 at 7:56 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Keep an eye on your afr, my cats died not long after i did the fpr mod on my shorties while running the 2.85 on trd tune.
  2. Feb 25, 2019 at 8:27 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Either @Torspd or @Roostfactor once mentioned the idea of tacking a little honeycomb material from an old cat over the sensor or j-bung orifice. Try that if you have an old cat laying around. Or try to find a smaller orifice if possible.
  3. Feb 25, 2019 at 8:29 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I'll be experimenting with this combo myself here soon.
  4. Feb 25, 2019 at 8:29 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm running the pinhole insert. Maybe if I glue it shut the sensor will be happy:thumbsup:
  5. Feb 25, 2019 at 8:31 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Maybe wait and see how mine develops. That 200 bucks is quite a head start on a ucon.
  6. Feb 25, 2019 at 8:32 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Too late, wallets already lighter. Parts Sims are on the workbench and j-bungs are with the ypipe
  7. Feb 25, 2019 at 8:34 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    If mine throws a code I may try the larger orifice with a piece of subtrate from my stock cat in it.
  8. Feb 25, 2019 at 8:38 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Without air flowing through it constantly I would wonder if it gets hot enough to function. Great to try though!
  9. Feb 25, 2019 at 9:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    He may have as well, but I have thought about that for years, since I have a surplus of cats. Probably said it too.
  10. Feb 25, 2019 at 9:18 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I thought you didn’t need the fpr mod until you put the 2.7 on? OR....you don’t need the fpr mod if you have the ovtune.....even with a 2.7
  11. Feb 25, 2019 at 9:28 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    You'll be fine with a 2.7. I was just teasing that you should get a 2.5
  12. Feb 25, 2019 at 9:31 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol.....what about the fpr?? I know with a 2.7 it’s suggested......I thought you didn’t need it though if you had the ovtune (on a 2.7). I tried finding where one of you guys said that but I can’t locate it.
  13. Feb 25, 2019 at 10:30 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That's because aftermarket catalytic converters are utter crap.
    No seriously, they are designed in such a way that they barely (and sometimes not even at all in most cases) pass emissions and satisfy the on board monitoring systems of the vehicle specific computer.
    If you have ever compared the overall size of an OE to an aftermarket catalytic converter you will find it is physically MUCH smaller over the OE direct replacement. There is a reason for that.
  14. Feb 25, 2019 at 10:49 PM
    inwood customs
    Dave
    I had my oem cats put on dt shorties at around 40 or 60k
  15. Feb 26, 2019 at 12:53 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Were the welds solid, no exhaust leaks were present right?
  16. Feb 26, 2019 at 10:42 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Wish I had v-bands on the header side as well as the y-pipe side. My cats got welded too, but so far they are performing fine.
    Speaking of exhaust, new Maserati fired up in the parking garage as I was walking back in from lunch. Wow, that sounds way better than my Tacoma.
  17. Feb 26, 2019 at 11:36 AM
    inwood customs
    Dave
    No soot present around welds, no ticking.
    rmepilot likes this.
  18. Feb 26, 2019 at 11:42 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Gotta love a Ferarri pitch, but all bark no bite. I just traded in my wife's Levante and it sucked in terms of capability. We did love the exhaust note though.
    mr.trd likes this.
  19. Feb 26, 2019 at 12:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh okay that's good. Eliminating that front the equation there are more factors than just doing the FPR to it, if you were high mileage we have to take account lazy air fuel ratio sensors and possibly other stuff that we aren't accounting. The possibility of a defective cat isn't out of the realm of possibility either.
    Another factor to take into account is the new flow rate of the collector before the cat. It is possible that due to how close in proximity the cat is to the collector that the major change in flow design may have superheated the cat to the point of failure as well as it is now handling much larger rushes of scorching hot air than it was originally designed to be handling.
    A lot of unknown variables present here.
  20. Feb 26, 2019 at 12:29 PM
    ThomasMore66
