TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 2, 2019 at 8:42 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Unlikely. I had plug and play sims with the j-bung. Maybe 40 miles the first go.
    Roostfactor likes this.
  2. Mar 2, 2019 at 8:51 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Sure like my DT shorties and Vibrant cats:D
  3. Mar 2, 2019 at 9:28 AM
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    I read it was hit or miss for 2015, mostly miss, but I have nothing to lose trying it, if it don’t work I’ll install jbungs and try again, if not, gadget said the universal sims would work, I just don’t like the idea of splicing into the Ecu, did the light return? Or have you done anything different to correct the cel?
  4. Mar 2, 2019 at 9:29 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I think the universal sims are my option.
  5. Mar 2, 2019 at 9:35 AM
    mulisharydr
    johnny
    I swapped a set of jba shorties for these, and honestly loved the shorties but they got damaged due to my engine mounts mysteriously disappearing during a off-road trip, Soo figured I’d give these a go.
  6. Mar 2, 2019 at 9:43 AM
    ThomasMore66
    Hmm. There is a thread on here about some badass solid motor mounts. It was years ago, but I’ll look in my watched threads.
  7. Mar 2, 2019 at 12:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    My question would be what disadvantage would exist solid mounts?
  8. Mar 2, 2019 at 1:01 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    New idea for the header CELs:
    j-bung in a j-bung with sims
    rmepilot and BassAckwards like this.
  9. Mar 2, 2019 at 1:05 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Not sure what ones you’re thinking of, but I love my dmz motor mounts. I’ve heard of fitment issues on all the other options. These went in no problem, motor and trans. No disadvantages in my opinion.
  10. Mar 2, 2019 at 2:56 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    They are badass. I've had them for like 3 or 4 years now and they have served me and all my hard driving without fail. They were made by @Bonzen .. Be advised for 4x4 they are an absolute BITCH to install though. Get ready to curse and throw stuff.
    Bonzen likes this.
  11. Mar 2, 2019 at 4:21 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Got some projects done today. Put in a new fuel filter and the fuel check Valve I got from @crashnburn80 . Thank you. Also cut of the exhaust at the rear axle so I have room to build a cross brace for the hammer hangers. By doing so I removed the cherry bomb resignator and damn my truck is loud again. Need to come up with a new plan to get it back in there. Lol. But now it is time to go drink whiskey and play poker. Cheers
    Roostfactor, Norton, Torspd and 4 others like this.
  12. Mar 2, 2019 at 5:00 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I may be going this route at some point. Need the cats up there to assist with noise reduction.
  13. Mar 2, 2019 at 5:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ethereally dead to me. :bananadead:
  14. Mar 2, 2019 at 7:31 PM
    mulisharydr
    johnny
    Yes I’m planning on running the dmz ones soon. Hopefully in the next couple of months, I’m extremely lucky the headers were the only damage done.
  15. Mar 2, 2019 at 9:51 PM
    ThomasMore66
    Yeah, I couldn’t find the thread.
  16. Mar 2, 2019 at 9:52 PM
    ThomasMore66
    Haters gonna hate. Unless you want to send cash.
  17. Mar 2, 2019 at 11:21 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yeah. I'd send cash but I'm tapped out. Just bought my license back:/ 25k yes folks, a burnout is in order.
    Roostfactor and crashnburn80 like this.
  18. Mar 3, 2019 at 1:18 AM
    mulisharydr
    johnny
    I know a lot of people complain about the urd spec u full exhaust but I absolutely love it, the noise is soo tame and the rasp is non existent, for having no cats it sounds good
  19. Mar 3, 2019 at 7:30 AM
    ThomasMore66
    What does that mean? Bought your license back...
  20. Mar 3, 2019 at 11:20 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Bummer!
    But you are made of money!
