TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 7, 2018 at 12:39 AM
    #1281
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    What is the question? Someone here may have the answer.
  2. Jan 7, 2018 at 4:09 PM
    #1282
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    before I go tearing into the engine and removing valve covers, I want to be 100% sure that all I need to do for the UCON isntall (without the S/C) is do the exhaust cam gears, thermostat, and injectors (and of course the UCON itself).
    Talkin to gadget...it was kind of a nonchalant "yea yea, that should be it" and with having to work M-F and it being my DD, I always make sure I have a plan laid out and I just didnt get the best warm and fuzzy after talking to him. I'll be the one left without a vehicle, not him haha so I have a little more invested in this part going smooth; thats all.
  3. Jan 7, 2018 at 4:16 PM
    #1283
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    The thermostat, injectors and UCON install are not that bad. The cam gears are not difficult, but will require a hefty wrench to break the bolts loose, while keeping the cam stationary. I'd reserve a day for the install, and maybe have a mechanic friend on call if possible.
    Skootter14 likes this.
  4. Jan 7, 2018 at 6:05 PM
    #1284
    Roostfactor
    TX panhandle
    I installed the front intercooler (fmic) crank pulley, intercooler pump and hoses (which I know you are going to re-route), etc. prior to install of sc. Just browse through the instructions and do EVERYTHING you can that won't take your truck out of service before the sc install. As Voodoo stated, thermo, UCON, injectors, and gears don't take that long but you could even do thermostat on a separate day prior to sc install. That way all you would have to do on sc install day is ucon, gears, and injectors.
    Someone correct me if I'm wrong here...tossed a few back tonight.
  5. Jan 7, 2018 at 7:04 PM
    #1285
    ThomasMore66
    Dallas/Fort Worth & Durango
    Anybody else tuning into the Dakar Rally?
    ls1 prerunner likes this.
  6. Jan 8, 2018 at 8:35 PM
    #1286
    Skootter14
    Jeremy
    Thanks gents, I appreciate it!
  7. Jan 9, 2018 at 2:01 PM
    #1287
    ThomasMore66
    Truck is in the shop. Mechanic says he's tried 5 different belts, one of which URD. Belt is slipping right at mid-range. Thoughts?
  8. Jan 9, 2018 at 2:11 PM
    #1288
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Try one size smaller belt?
    Notch the pulley like @12TRDTacoma ?
    12TRDTacoma[OP] likes this.
  9. Jan 9, 2018 at 2:23 PM
    #1289
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Question, you did the bypass valve jet mod right? Are you still running it that way?
    What size pulley are you running now?
    RIP mod may not be necessary if I know what size pulley you got.
    Spot on. :thumbsup:
  10. Jan 9, 2018 at 2:25 PM
    #1290
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    The 69.5" belt did not fit my 2.8 pulley. Not sure if I should be concerned. For now I put the old belt back on. Still need to put the fan back on and add oil to the SC before starting it.
  11. Jan 9, 2018 at 2:26 PM
    #1291
    ThomasMore66
    I'm running the 2.85" stealth with bypass jet removed and boost referenced.
  12. Jan 9, 2018 at 2:31 PM
    #1292
    12TRDTacoma
    Rob
    Concordia
    Boosted
  13. Jan 9, 2018 at 2:33 PM
    #1293
    ThomasMore66
    I'm searching, but where did you cover that mod? Edit: Googled it. Some machining required.
    Damn all you people. I was just going to leave things alone and now I can see the call of the UCON is back...effing quick-change pulley...
  14. Jan 9, 2018 at 2:43 PM
    #1294
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Got a dremel? Easy mod.
  15. Jan 9, 2018 at 2:45 PM
    #1295
    ThomasMore66
    GT7 likes this.
  16. Jan 9, 2018 at 4:28 PM
    #1296
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    maybe bad or worn tensioner pulley?
  17. Jan 9, 2018 at 5:55 PM
    #1297
    Chickadee
    Chickadee No, It's not my husband's truck.
    Tricia
    Colo Springs, CO
    2013 DCSB TRD OR, Spruce Mica
    OME lift, Relentless Bumpers, Supercharged, UCON
    So, my misfire problem isn't going away... Sorry to say you may have been right @12TRDTacoma
    It's worse when the engine is cold, has only thrown a code once a few weeks ago (cylinder #4). Since it's not throwing a code all the time, how do I go about trouble shooting the underlying problem?
    Also, which cylinder is #4?
  18. Jan 9, 2018 at 6:18 PM
    #1298
    richiep
    Rich
    NY
    what code are you getting? Miss-fire cyl #4?
  19. Jan 9, 2018 at 6:19 PM
    #1299
    richiep
    Rich
    NY
    middle pass side
  20. Jan 9, 2018 at 6:20 PM
    #1300
    richiep
    Rich
    NY
    clogged/bad injector, spark plug or coil
