TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 3, 2019 at 11:48 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    They did not resurface properly (or at all) or they followed an incorrect torque sequence on the cylinder head or did not torque the head bolts to the correct multi pass specification. The bolts themselves will not be an issue even if re-used.
    Bummer man. It's too bad that happened to you, but I don't blame you. It's a lot of work to do both a head gasket, as well as a main shaft bearing or an entire bearing set. If LS is more cost effective, do it. The tech is so commonplace that finding parts for it will quite literally never be an issue.
  2. Mar 3, 2019 at 12:38 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I wish. LS conversion suddenly got more cost effective. I’ve addapted.
    Roostfactor[QUOTED] likes this.
  3. Mar 3, 2019 at 1:44 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I'm running the URD spec u headers and y-pipe, then the TRD cat back. I had to add a resonator due to the rasp... but the power gains are worth the extra noise.
    rmepilot likes this.
  4. Mar 3, 2019 at 3:02 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    When I first got my S/C put on I still had my TRD exhaust. It had a ton of rasp and that was before my headers and URD y-pipe. Adding the y-pipe and URD mark lll 3” exhaust made all the difference in the world.
    zippsub9 likes this.
  5. Mar 3, 2019 at 4:10 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
  6. Mar 3, 2019 at 9:33 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Everything has a price.
  7. Mar 4, 2019 at 6:48 AM
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Your referring to the competition y-pipe? I’m referring to their full exhaust, from headers down, the exhaust only works with their y-pipe, as it goes directly from the headers into the muffler, the muffler is dual opening single exit. But it sounds good to me. No rasp, not loud and it’s dumped after the axle
  8. Mar 4, 2019 at 8:12 AM
    ThomasMore66
    So in WA if you’ve been a bad boy you can make restitution and get your license back?
  9. Mar 4, 2019 at 5:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    In a way. Costs almost what a new Tacoma does.
  10. Mar 4, 2019 at 5:08 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm never well behaved anyway.
  11. Mar 5, 2019 at 7:11 AM
    ThomasMore66
    I gathered that. That’s crazy. I’ve never heard of such a thing.
  12. Mar 5, 2019 at 12:09 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Bottom line is it's much cheaper but arguably less exciting to be a good boy.
  13. Mar 5, 2019 at 1:05 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    I paid a shop ~$500 to install mine and it was probably worth it. I bought new bolts too in case they needed them. I think I have a slight bit of cab vibration but I don't notice it. I couldn't confirm but it felt like my factory mounts were getting sloppy.
  14. Mar 5, 2019 at 1:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The factory mounts for 4x4 are designed in such a way that they are meant to be in there for the life of the vehicle, which is stupid.
    Are you a 4x4 or 2WD? $500 for putting those in is well worth the cost. The polyurethane Bonzen mounts will induce some vibration, but that is due to the inherent (higher than rubber) amount of durometer of polyurethane. A little bit of vibration in "D" is a great trade off for the amount of increase in reliability you are getting over the factory units.
  15. Mar 5, 2019 at 1:26 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    4x4, I took it to a shop in Oakland but i'll bet you could find similar or cheaper further out in East Bay. the biggest time i notice is when no one is in passenger seat sometimes the headrest vibrates at idle but not noticeable while driving. definitely worth it. not a lot of miles but after 2 years no issues so i'd confirm the recommendation above on the Bonzen mounts!!!
  16. Mar 5, 2019 at 3:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    See I did my power steering rack the same day so maybe I was just exhausted as a whole from all the BS. I'd probably say total time for both was about 10 hours.
  17. Mar 6, 2019 at 12:44 PM
    ThomasMore66
  18. Mar 6, 2019 at 4:06 PM
    Roostfactor
    TX panhandle
    Good stuff. That's why I was saying the TRD tunes table probably maxes out at 322 g/s. Fortunately with fpr mod it seems to keep increasing fuel on our trucks.
    The UCON must have larger internal map tables which would explain why we can read higher than 322.
  19. Mar 6, 2019 at 5:09 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Very cool explanation, thanks for sharing. So it seems us higher boost TRD guys will need to use one of those 4 options to get a complete custom tune. I'd like to know what the pros/cons are for tuning with MAP vs MAF
  20. Mar 6, 2019 at 5:11 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Very helpful video. Dual intake pipes and maf sensors it is.
    BassAckwards likes this.
