TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 6, 2019 at 5:15 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Bigger tables or maybe MAF voltage scaling?
  2. Mar 6, 2019 at 5:17 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Initially, at least, it seems the MAF is limited in power capacity and then finding a newer or more capable MAF to replace stock in order to gain more fuel. The FPR seems to bypass this digital limitation through analog means of forcing the fuel wether the ECU thinks the engine needs it or not. The MAP tuning is probably more accurate, although time consuming. And by time consuming, I mean more expensive. Hence, the UCON systems that overwrites via piggyback to the engine sub components the demand signal required. I wonder if any of the Tundra V8 MAFs would work? Surely a N/A V8 flows more air than the older v6 4.0s. I am not sure of their specs, but the video makes it seem that if the MAF can exceed the 322 flow rate then the ECU should follow suit with fuel. However, this may require different tuning since the ECU probably doesn’t recognize the larger injectors or colder plugs.
  3. Mar 6, 2019 at 6:24 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Ive been checking out semi-local tuners in my area and found one that has some history with toyotas. They have their own dyno and have developed their own software and want to get into the Tacoma platform. Took my truck in this week to have them read the ecu to see if they can work with it. Waiting to hear back. It's called Monkey Wrench Racing
    The tuner seemed pretty confident that the MAF limitation could be overcome by scaling the voltage with a multiplier and not require any other mods.
    https://www.monkeywrenchracing.com
    Not sure what will come of it but worth a shot.
  4. Mar 6, 2019 at 6:42 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    map >>>>> maf anyday
    12TRDTacoma[OP] and GT7 like this.
  5. Mar 6, 2019 at 8:12 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    The FPR doesnt bypass anything. What happens is the ecu is calibrated for 43.5psi fuel pressure. When in boost with the FPR mod fuel pressure rises commensurate with boost so fuel flow is increased WITHOUT the ecu knowing about it.
    So at 10 psi boost you have 53.5 psi fuel pressure which injects more fuel for a given injector pulse width thereby richening the mixture in open loop beyond what the TRD tune tables call for. Since the ecu doesnt know what to do past the table it seems it just keeps on the same fueling path beyond the table and since the FPR mod is ultimately providing more fuel, afr's stay safe.
  6. Mar 6, 2019 at 8:30 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    ^what he said...
    I should have said it achieves a somewhat safe correlation utilizing the fuel through an analog means, overcoming (not bypassing) the ECUs inability to provide more fuel since it cannot read the additional air input.
    Roostfactor likes this.
  7. Mar 6, 2019 at 9:53 PM
    Roostfactor
    TX panhandle
    Yessir!
  8. Mar 6, 2019 at 10:10 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I believe tuning with the MAP is what would be labeled as a "Speed Density" tune... which is why I love GM's HPTuner's platform so much. There is literally so much flexibility within the PCM tuning and you can change anything your heartstrings desire. This is also why I have been so disappointed with Toyota's lackluster tuning capabilities from the getgo.
    There were no cons with tuning via speed density but it made the MAF in essence a decorative engine item at that point. Since it was no longer being used it was just a dummy.
    I would personally not use a Tundra MAF, as those are the same style MAF used amongst many manufacturers which have shown an evident shortcoming in long term reliability.
    This is a prominent discovery! I am looking forward to seeing what comes of him if he is capable of cracking the tuning code properly.
    JacksonTacoma[QUOTED] likes this.
  9. Mar 7, 2019 at 2:42 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    @australian hilux this is the place for you to learn about supercharger mods. Read at least the first post, the OP here does update it.
    Torspd and 12TRDTacoma[OP] like this.
  10. Mar 9, 2019 at 2:27 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Anyone got a stock supercharger coolant pump they wanna get rid of?
  11. Mar 9, 2019 at 3:10 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  12. Mar 9, 2019 at 4:32 PM
    Roostfactor
    TX panhandle
    There are higher output options as well that @12TRDTacoma had found and posted on post 1, unless you are looking to do a dual pump setup?
  13. Mar 9, 2019 at 4:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The Mercedes Benz version of the Bosch pump outputs roughly at least 1.10 GPH more than the stock pump. The only fallacy is that you have to change out the plug for it, but it's an easy 2 wire switchover. It worked out for my retrofit as well as my stock pump was weeping out from the two outputs for some reason despite correct hose clamp placement.
  14. Mar 10, 2019 at 7:11 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Yeah just looking for a second pump for duals
  15. Mar 10, 2019 at 12:03 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Still gotta get this ice box figured out and how I wanna run the lines. I dunno i should just plum in the the lines from the ice box so it goes right from the ice box to the super charger then through the intercooler and all the way back to
    The ice box. Thinking that’s the way I’m gonna go. Or figure out a way to run just ice box through the intercooler when drag racing with shut offs on the regular system.
  16. Mar 10, 2019 at 12:08 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'd get the coldest liquid possible to the place its needed most first.
    DocME likes this.
  17. Mar 10, 2019 at 1:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would also mount that box in the bed where there is zero engine bay heat to melt it because if you put it in the engine bay that ice will be water within a matter of 2 minutes. 3 minutes tops.
  18. Mar 10, 2019 at 1:04 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Also sucks I live where it’s cold so
    I’ll have to run coolant through everything before winter.
  19. Mar 10, 2019 at 1:05 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Figured I’d check here first.
    Anyone interested in the following?
    -URD 7th Inj Kit
    -URD UCON Expansion Harness
    -URD 70MM Throttle Body Adapter Plate
    -70MM Throttle Body
    $575 shipped
    I’ll also include the bolts needed to use the 7th inj plate and the 70mm TB Plate together. Gadget does not supply these. I had to find them.
    Also, gasket material if you want to make a new gasket for the throttle body to adapter plate. There is no provision for an O-ring here. You must make a gasket for it.
    Finally, I will send a couple of spare O-rings for the fuel rail tap. They can be a pain.
    So, that’s everything you need to add a 7th injector and 70 MM TB to your UCON tuned Supercharger.
    It all came off my truck this morning because I put the factory air box back on.
    If you’re curious, I put the factory air box back on because I’m tubbing for 37s. I lost some of the mounting points for the AFE, and had to cut into where the snorkel went.
    I never liked the snorkel anyway, so I ordered new fenders and sold it.
  20. Mar 10, 2019 at 1:07 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
