TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 14, 2019 at 6:22 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    What is this bypass you speak of? I’m at 80k+ miles now and that stupid air injection thing bothers me.
  2. Mar 14, 2019 at 6:26 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Last I asked them they had no idea if their system even worked and haven't returned my emails. Please keep us posted on this. Very enticed to do it if it works.
    BassAckwards and loginfailed like this.
  3. Mar 14, 2019 at 6:26 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Do the umi filter mod. By taking that foam piece out, it prevents the foam from breaking down and breaking the fins of the fan in the air pump. This will prevent the broken pieces from making their way to the valves
    BassAckwards and rmepilot like this.
  4. Mar 14, 2019 at 6:28 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    @12TRDTacoma theres a warranty enhancement on entire air pump system for ur truck. For the p2442 code. Bring to dealer and have it fixed for free lol. If u want to pm me ur vin i can double check in the morning to make sure ur truck is apart of it.
    Roostfactor and mr.trd like this.
  5. Mar 14, 2019 at 6:28 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I heard that bypass system is hit or miss. Toyota also has a full recall of that stuff for the 12 and 13’s
    loginfailed likes this.
  6. Mar 14, 2019 at 6:28 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Eyeh8chu :curls:
    rmepilot likes this.
  7. Mar 14, 2019 at 6:28 PM
    ThomasMore66
    I did that already. One of the easier things I’ve done.
  8. Mar 14, 2019 at 6:29 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    https://hewitt-tech.com/store/index.php?l=product_detail&p=44
    Everyone seems to be pleased with their system so I don't know where all that came from?
    That is only part of the problem man. The filter I pulled out of mine was fully whole. The problem is the system runs with a torch in front of its face. Seals melt making the valves jam up because the rubber seal disintegrates inside the valves.
  9. Mar 14, 2019 at 6:33 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    It came from me contacting them directly. They seemed to be very uncertain on their set up. I was willing to give them money to cancel the underhood spaceship. This was July I last heard from them.
  10. Mar 14, 2019 at 6:33 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No I know there is. 10 year or 150K. I never got a letter, but at this point it is a flawed system which is only destined to either make my truck catch fire, or get rear ended from going into sudden limp mode. Both of which is bulllshlackaah.. I would rather eliminate it completely and be done with it.
  11. Mar 14, 2019 at 6:33 PM
    ThomasMore66
  12. Mar 14, 2019 at 6:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No I know you contacted them directly, what I'm saying is I don't know what would make them suddenly say that. Interesting.. but there are tons of people who have seemed pleased with it so Idk?
  13. Mar 14, 2019 at 6:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes it is. 2013 runs after the vehicle has been shut down to eliminate the blow torch effect. 2012 no matter either before or after warranty runs while the truck is on.
  14. Mar 14, 2019 at 6:35 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Damn California and their pollution.
  15. Mar 14, 2019 at 6:36 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Same.....in 14 they made an improvement that should’ve solved the problem.
  16. Mar 14, 2019 at 6:36 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Good to know. Thanks for bringing it up. I'd like to eliminate it. Does it allow full removal of the unit or just disable it while leaving it in?
  17. Mar 14, 2019 at 6:40 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    My air injection is working fine. Perfect time to amputate it. Why wait til it breaks?
    rmepilot, mr.trd and 12TRDTacoma[OP] like this.
  18. Mar 14, 2019 at 6:45 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It was a silent implementation at that too because they wanted to try to screw the 2012 owners.. that ended up biting them in the ass because now they extended the warranty for that stuff instead of making the system work correctly.
    It disables it while leaving the unit in place looking like it is all hooked up just fine.
  19. Mar 14, 2019 at 6:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You know why they are not sure if it would work for yours @White lightning boosted, it's because ththe strategy for later models are different and it's even highlighted on their site that on the Tundra's which have received the ECM update which cycles the valves differently it will not work. Yours operates similar to the Tundra's with the ECM update.
  20. Mar 14, 2019 at 6:58 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So in your opinion should I not pursue this?
