TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 14, 2019 at 7:04 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I don't see a cause for you to do so. You would be chasing ghosts as of right now. I would however pull one of the valves off and inspect it just in case so you can see what the seal looks like. If it is starting to look all melted and destroyed then you have reason to be in a mild state of panic as the system is very finicky.
  2. Mar 14, 2019 at 7:15 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Dont know what to pull.
  3. Mar 14, 2019 at 7:18 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    :lalala:
    inwood customs likes this.
  4. Mar 14, 2019 at 7:31 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The two large aluminum electronic bypass valves on your passenger side valve cover.
  5. Mar 14, 2019 at 8:07 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    So, you teed that up and I’m just gonna let that go...
  6. Mar 14, 2019 at 8:13 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Pull, tug, not seeing a happy ending.
  7. Mar 14, 2019 at 8:14 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Sounds like a typical date. Expensive and something going wrong.
  8. Mar 14, 2019 at 8:15 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's right. A total waste of time..
  9. Mar 14, 2019 at 8:17 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Good thing I have a white taco to take my money. The pink ones are spendy and less reliable.
  10. Mar 14, 2019 at 8:28 PM
    ThomasMore66
    Such bitterness. Shopping at the wrong taco store.
  11. Mar 14, 2019 at 8:32 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True.
    12TRDTacoma[OP] likes this.
  12. Mar 14, 2019 at 8:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The strip club offers Tacos with too much varnish build up in their soft shells.
    Roostfactor likes this.
  13. Mar 14, 2019 at 8:43 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
  14. Mar 14, 2019 at 9:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ewwahhhh.
  15. Mar 14, 2019 at 9:33 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    So I just got a check engine code P2A03. Can't seem to find too much info on this here on TW. Some online searching leads me to believe this is an O2 sensor going bad. I've got the magnuson S/C with the bully dog tune (likely running rich). Only other mod is a snorkel. Anyone have seen this code? any ideas? are my cats going out?
  16. Mar 14, 2019 at 10:00 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No idea man. Is the truck running poorly? There has to be something regarding it. What scanner did you use? You may want to try global OBD instead.
    Actually. I wonder if that is a P2193 which I believe is an oxygen sensor biased rich code. I could be way wrong though and it may not be a biased rich code at all, but it may still be O2 sensor.
  17. Mar 14, 2019 at 10:05 PM
    henryp
    Henry
    Montana
    I know it sounds lame, but I'm using the scanner built into my pioneer stereo. I just ordered a proper one from Amazon. Truck seems to be running ok (no hesitation or misfires). Pretty bad gas mileage from day one on SC (12mpg highway), but i'm also fairly loaded (armor, bumper, 33" tires, etc).
  18. Mar 14, 2019 at 10:15 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    How much armor and how fast do you normally drive on the fwy? 12 mpg seems really bad to me. I average around 15.5 mpg driving like an arse hole and if I do 65/70 on the fwy I can get 17 mpg. I have front bumper, sliders, skids and 34” tires.
    Norton and loginfailed like this.
  19. Mar 14, 2019 at 10:20 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah you definitely gotta get yourself a real scanner but it is likely an air fuel ratio sensor code. How many miles on it?
    I get 12 myself. IF I'm lucky, MAYBE 13. Lol.
    mr.trd and Murphinator[QUOTED] like this.
  20. Mar 14, 2019 at 10:21 PM
    henryp
    Henry
    Montana
    ARB bumper, steel skid plate, sliders, topper, bed slide, dynomat inside cab, 33" cooper ST max, 33gal gas tank. I'm at 5000' above sea level. Highway speeds around 80mph (speed limit). I'm looking at getting the OVtune. AFR gauge pending installs, since getting this code, probably this weekend. The problem is that if I'm running rich, I'm not sure what the fix would be. A smaller pulley? I had it dyno'ed after SC install; about 285hp
