TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 14, 2019 at 10:23 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    285 eh? Those are rookie numbers. We gotta pump those numbers up.
    So you got mud terrains going 80mph, that's part of your problem right there. The toppers the skid plate and steel plate bumper woo that's some SERIOUS duty on that poor little V6.
  2. Mar 14, 2019 at 10:28 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    lol, that and now a code I can't read cuz, no obd2 reader.
  3. Mar 14, 2019 at 10:29 PM
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    You live it Cali, why not try to get it covered under warranty?
  4. Mar 14, 2019 at 11:28 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Do I here a 2.5 pulley?
    12TRDTacoma[OP] likes this.
  5. Mar 15, 2019 at 1:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  6. Mar 15, 2019 at 2:27 AM
    mulisharydr
    johnny
  7. Mar 15, 2019 at 4:22 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
  8. Mar 15, 2019 at 6:06 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Hewitt is working on a 13+ specific bypass system. I’m on their beta test list. They said they will email me when they have them ready for testing.
    https://hewitt-tech.com/store/index.php?l=product_detail&p=82
    12.5 here. :anonymous:
  9. Mar 15, 2019 at 6:53 AM
    ThomasMore66
    Thus the bigger gas tank. I took the same approach on my 80.
  10. Mar 15, 2019 at 7:04 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yessir, exactly the reason for the bigger tank! The LRA tank gets me back to what could be considered a “normal” range per tank.
    Stock city was 19 MPG x 21 g = 399
    Modded city is 12.5 MPG x 33 g = 412
    On the highway at 70 MPG, it gets 15-16 MPG. So on a longer trip, it could possiblly crack 500 on a tank now.
  11. Mar 15, 2019 at 7:06 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Oh wow you have a lot going on haha. The speed definitely kills it on these trucks. When I had a 2wd tacoma it seemed to get the best gas mileage at 75/80 mph. Now with my 4x4, the more you go over 55 it just gsts worse and worse.
    I like the sounds of that bypass. Hopefully it actually works.
    12.5 isn’t all that bad considering how much power you are putting down.
  12. Mar 15, 2019 at 7:36 AM
    ThomasMore66
    70?! This is TX, boy. You a sissy?
    rmepilot likes this.
  13. Mar 15, 2019 at 8:12 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Haha, maybe. I do it for the empeegees.
  14. Mar 15, 2019 at 1:20 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  15. Mar 15, 2019 at 2:31 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just took a look at this and I very much appreciate you looking out for me about this issue. I cannot see any differences physically with this setup over my own, however. I can't really justify dropping coin on the valves or manifold assembly (if that is how it is sold) at this point when I will be receiving this bypass kit come Monday.
  16. Mar 15, 2019 at 2:55 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Good looking out for sure. I just can’t wait for a FULL DELETE KIT. My OCD will be in such relief like cutting out a huge cancerous tumor from the engine bay. I am going to see if I can help out with the 4.0L donation research time to help.
  17. Mar 15, 2019 at 3:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Add one to the list of impending problems these trucks have. How annoying right.
  18. Mar 15, 2019 at 3:19 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    No sweat.....if I remember correctly, the tundra valves were corrected first of this issue and supposed to work flawlessly.....so to speak
  19. Mar 15, 2019 at 3:42 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    If it's under the hood and doesnt promote horsepower or vital engine necessity it needs to go away.
  20. Mar 15, 2019 at 5:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This right here. All other items (Egr Valves, AIR injection systems etc. Etc.) need to just go away already. Of course they have already gotten started and continued a recurring trend of EGR valves no longer being a part of the emissions systems because they figured out how to allow camshafts to be able to allow some EGR action into the combustion chambers on their own without the intervention of an external valve.
