TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 19, 2019 at 6:12 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    B6EF8E3B-15E1-44CD-861E-5F7B7E9950BD.jpg Does this count as a shinny new coolant over flow?
  2. Mar 19, 2019 at 6:16 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yes it does.
    BassAckwards and inwood customs like this.
  3. Mar 19, 2019 at 7:14 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I believe it was @Roostfactor that said we are now far from shore. Found myself eyeing a Brian Crower Stroker kit the other day...
  4. Mar 19, 2019 at 7:27 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh dude, at this point about 85% of us on this thread are deep sea fishing. :rofl:
  5. Mar 19, 2019 at 8:03 PM
    ThomasMore66
  6. Mar 19, 2019 at 8:07 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    BassAckwards, Roostfactor and Torspd like this.
  7. Mar 19, 2019 at 8:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  8. Mar 19, 2019 at 8:13 PM
    ThomasMore66
    JuanitoBonito[QUOTED] likes this.
  9. Mar 19, 2019 at 8:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thought you were going crazy for a second. That one is nice!
    loginfailed and inwood customs like this.
  10. Mar 19, 2019 at 8:30 PM
    ThomasMore66
    Well, odds are in your favor.
  11. Mar 19, 2019 at 8:40 PM
    ThomasMore66
    Here’s my 1994. Only has 105k on the clock.
  12. Mar 19, 2019 at 10:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  13. Mar 20, 2019 at 7:11 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Got two Speedhut Revolution Silver Gauge Bezels for 2 1/16" size gauges if anybody wants to use as silver or paint for color match. I will donate for free to anyone in this thread since most others aren't using gauges to begin with outside of S/C.
    In addition, to whomever won the race to or has access to a snout cutter. Hit me up whenever you are complete.
    Roostfactor, Norton and loginfailed like this.
  14. Mar 20, 2019 at 9:28 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm not sure how quickly he'll be done with it, or what his plans are for it at that time, but I sent you a PM with the buyer's user name and him one with yours. Good luck!
    mr.trd and zippsub9[QUOTED] like this.
  15. Mar 20, 2019 at 9:44 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Glad to see that thing is making the rounds! Anyone that uses it should be able to use it and sell it forward without losing $ out of it. Hopefully it continues.
  16. Mar 20, 2019 at 10:09 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I know I used @loginfailed's snout cutter when I did mine and @5thGearPinned and I borrowed @white lightning booster's cutter to do his.
    What I'm saying is that there are a lot of whorish snout cutters out there now.
    I love our little virtual community! You guys and gals are rad!
  17. Mar 20, 2019 at 10:27 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So much for URD's pulley sales and snout cutter selling business. :D
    I love how everyone is willing to help everyone out, even for little things on here.
  18. Mar 20, 2019 at 11:52 AM
    Roostfactor
    TX panhandle
    Absolutely true!
  19. Mar 20, 2019 at 2:41 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Speed freaks, would you run track oriented suspension parts on your DD?
  20. Mar 20, 2019 at 2:46 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Why not? If I had the bank, I would drive a Baja Trophy Truck to work.
    We put crawl boxes and over landing gear on a DD.
