TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 27, 2019 at 7:51 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Depends... are there any shiny reservoirs under the hood?
    GT7 and White lightning boosted like this.
  2. Mar 27, 2019 at 8:11 PM
    Masshole19
    Masshole19 Well-Known Member
    Eric
    Dudley, MA
    15' TRD Sport AC 6 speed
    URD short throw, TRD SC, TRD catback exhaust, AFE stage 2 intake
    Hey guys, my warranty is finally up and I'm looking to change the pulley on my TRD supercharger from stock to the 2.85 pulley. Are there any other tuning options becides the UCONN and OVtune? I've heard bullydog was making something but I can't find it on their website. Also are there any necessary supporting mods to go with the pulley change? Not looking to go overboard as this truck is my daily and I'm currently running the TRD tune.
    HappyGilmore likes this.
  3. Mar 27, 2019 at 8:20 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Sadly no. My plan is LS swap. Still working details.
  4. Mar 27, 2019 at 8:22 PM
    ThomasMore66
    Thank you. It will go anywhere you might want to go, just not very fast. Cruiser is the word.
  5. Mar 27, 2019 at 8:26 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Thank you! He is such a good boy!
  6. Mar 27, 2019 at 8:33 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Multiple up and coming tuning options discussed on the last few pages. Honestly though, you don’t even need a tune for the 2.85.
  7. Mar 27, 2019 at 8:34 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    Is it necessary to run a different tune when changing pulley size? Once you start getting really small, I could see how but wouldn’t think it’s required for a 2.85...
    I’m not sure what mine has, but PO stated that he had a smaller pulley installed, and it still has the TRD tune. Making 7lbs of boost with stock intake and exhaust. Still runs rich as the TRD tunes have been known to do so I don’t think I’ve had anything to worry about?
  8. Mar 27, 2019 at 8:35 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    ......you sounded just like me when I got mine. The 2.825 doesn’t need anything but there are other things that you would benefit from. CAI, exhaust etc....and screw bullydog , you don’t want that.
  9. Mar 27, 2019 at 8:49 PM
    Masshole19
    Eric
    Dudley, MA
    Thanks for the replies guys, sorry I forgot to mention that I have the TRD exhaust and the AFE CAI. I mean I knew the TRD tune was rich, but it's so rich that even with a pulley size change there's no need for a tune? I'm a little hesitant about that, i've never messed with boost before so this is new to me. I mean if the 2.85 pulley isn't even putting enough air into the motor that it requires a tune is it even worth getting? Does anyone have any dyno runs with that size pulley? or know what the actual gains are versus the claimed gains?
  10. Mar 27, 2019 at 8:54 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    the 2.825 is worth it if you just want a little more....the s/c should’ve come with that size to begin with. It’s what I have now. The TRD tune is indeed rich, part of the problem is you have the TRD exhaust which is only 2.5”. You’d be much better off with a 3” cat back and a y-pipe to help the motor breath. You’d also eliminate the rear cats in the process.
  11. Mar 27, 2019 at 9:03 PM
    Kelvin
    Kelvin Wheeeeee
    I was tempted to go with a 3” single and a Y on my car for less weight but two things stopped me. Dual exhaust cutouts in my bumper and was told my V8 would sound better with duals and an X. So I went 2.5 duals. We all know the better it sounds the faster it is.
    mr.trd and JuanitoBonito[QUOTED] like this.
  12. Mar 27, 2019 at 9:04 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I agree the blower shoulda come with a smaller pulley, but exhaust changing the afr?
    Boost psi is a measurment of restriction isnt it?
  13. Mar 27, 2019 at 9:08 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Perhaps, that’s something someone smarter than I can expel on. I can tell ya mine runs better with my setup than before and my afr’s are at 14.7 at idle
  14. Mar 27, 2019 at 9:11 PM
    Kelvin
    Kelvin Wheeeeee
    I think TRD learned their lesson from the UZ motors. Doubt they would have gone too crazy with the pulleys. Super restrictive stock exhaust manifolds and a 2.2 pulley. A small bump in power is all they advertise for you guys whereas with the 2UZ blower I think they advertised something crazy like an additional 120 hp.
  15. Mar 27, 2019 at 9:14 PM
    inwood customs
    Dave
    They should be 14.7-14.9 regardless of exhaust until the truck sees load.
    For me, oem manifolds, shorties, long tubes... All same afr, they are pre wraf sensor.
    The truck def hauls better when the exhaust is open.
    JuanitoBonito[QUOTED] likes this.
  16. Mar 27, 2019 at 9:17 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm also curious about this but, FWIW, I've had no problems with my OVTune (once I got it...).
    Murphinator likes this.
  17. Mar 27, 2019 at 9:19 PM
    Norton
    Everybody who owns one of those gutless engines...?
    +1. Profile and rearend are OK. Still not a fan of the frontend or the engine.
    BassAckwards likes this.
  18. Mar 27, 2019 at 9:19 PM
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm not faulting ovtune for what I experienced. I just have added lots of mods. Need an update done. Went back to the trd tune to compare. Anybody want some j-bung extensions? I'll probably sell mine. PM if interested.
  19. Mar 27, 2019 at 9:21 PM
    Norton
    Don't waste your time with the 2.85 pulley. Supercharger Quick Change Pulley FTW!
  20. Mar 27, 2019 at 9:26 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm running a 2.5 on the trd tune. 30 mph rolling tire burn on bone dry pavement with new 275's. Afr's were happy still.
