TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 29, 2019 at 7:45 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Mines out. Love it with out it.
  2. Mar 29, 2019 at 8:25 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Me too.
  3. Mar 29, 2019 at 8:30 PM
    ThomasMore66
    I went with an Australian valve body. Wholesale Automatic Transmission. I had a vibration issue and the valve body plus flushing the the trans took care of that issue. IMO, Ratiotek cannot manage the supercharger like a valve body upgrade. :crapstorm:
    HappyGilmore and loginfailed like this.
  4. Mar 29, 2019 at 8:42 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    So quick question one of you all in guys probably knows, I changed my coolant tonight and swapped in the URD 170f thermostat so when does the thermostat go wide open? I know 170f means it starts to open then but when is full flow reached? I’m only asking because I’ve had my truck plug the radiator off-road and I like knowing when and if the thermostat is wide open lol.
  5. Mar 29, 2019 at 9:14 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Same, snappy response.
    12TRDTacoma[OP] likes this.
  6. Mar 29, 2019 at 9:24 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I dont know if this is the answer but I have a 170* typical engine temps are 185 for me.
    loginfailed likes this.
  7. Mar 29, 2019 at 9:32 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yeah I did a 20 minute shakedown after finishing flushing air out of the system and my temps never went above 181. It is only 7 c outside though lol.
  8. Mar 29, 2019 at 9:38 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That's very similar to mine. Should have my lady here to calculate the c* to f* ratio faster. Shes from up north.
    BassAckwards likes this.
  9. Mar 30, 2019 at 3:27 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I too have the 170* .....my temp never goes above 190 and always averages between 186-190.
    Also, I kept my little jet in.....
  10. Mar 30, 2019 at 5:21 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have the 160* thermostat. I normally see a 175*-185* operating range.
  11. Mar 30, 2019 at 8:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    170, is practically a waste.
  12. Mar 30, 2019 at 8:49 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Do tell your thoughts on this. It was the one time I chose to go average in my adjustments. Is it just too little gain to be effective?
    Norton likes this.
  13. Mar 30, 2019 at 8:55 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I steered away from the 160* basically because URD’s info stated not to do the 160 if you live in a colder environment.....or something like that...
  14. Mar 30, 2019 at 9:09 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Im running mine without the restrictor. I took mine out, put it back in, and then took it out again because i liked it more without it.
    Im running a 2.6 with UCon, and quick throttle tip ins are much smoother with the restrictor removed. I think a lot of that has to do with having a 6spd though. If you have an auto, might notice less of a difference on that
  15. Mar 30, 2019 at 9:21 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just placed my csf radiator order. Figured I'd get one before the weather puts them on back order. @JuanitoBunito, do you have any pics where your radiator was tapped for a temp fitting?
  16. Mar 30, 2019 at 9:28 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I didn’t tap it. I ended up putting the sensor in the top radiator hose. I’ll send ya a pic in a little bit....
  17. Mar 30, 2019 at 10:05 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ahhh. I have the same thing.
  18. Mar 30, 2019 at 10:10 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Well given in -20c here my stock thermostat wouldn’t get above 180f sometimes for over 30 minutes, I’d say his warning is probably fair. I’d expect a 160f thermostat to have trouble hitting operational temperatures once the temperature gets near 0f outside.
  19. Mar 30, 2019 at 10:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your last sentence is the answer. Those with the below freezing climates are better off with the 170°. To be honest though, it all depends on what restrictions are in front of your radiator, size of radiator, climate, and how you drive.
    The OEM on on a 4Runner, which has better ducting around the radiator, keeps the engine as cool as a Tacoma with the 170°.
    Most people with the 170°, in a Tacoma, notice only a few degrees difference from OEM, if any. Even after a radiator upgrade. Hmm.
    With the 160°, temps actually change to stay in the 170's to low 180's. Well away from the 200's. Where the slightest problem can raise can take the engine to its demise.
    Also consider this. Keeping the engine a little cooler, taxes the oil temps that much less. Aiding in prevention of liquification of the oil (over temp).
  20. Mar 30, 2019 at 10:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There are inline radiator hose sensor adaptors. Basically cut the hose, insert metal tube with threaded sensor port, reattach hose ends.
