TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 14, 2018 at 3:05 PM
    #1361
    vegasstaco
    vegasstaco Well-Known Member
    Jose
    N,W Houston
    4x4 TRD Sport
    Many
  2. Jan 14, 2018 at 4:03 PM
    #1362
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    @Torspd @Lucario Runner
    vegasstaco[QUOTED] likes this.
  3. Jan 14, 2018 at 10:24 PM
    #1363
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    351 wheel HP? On a mustang dyno? Wow!
    Congrats! That's quite a bit more than I would have guessed (low 300s). That 44deg weather is better than NOS....no bottle to refill!
    Norton likes this.
  4. Jan 16, 2018 at 7:42 AM
    #1364
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Just a follow up. I swapped out the CAI with a AFE one I had and I put in a new AEM fuel pump with external filter. No codes since then. :)
    ...until the other day. Turns out I didn't put the gas cap on all the way. :)
  5. Jan 16, 2018 at 8:05 PM
    #1365
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Happy to help.
    HBMurphy likes this.
  6. Jan 17, 2018 at 10:37 AM
    #1366
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
  7. Jan 17, 2018 at 10:44 AM
    #1367
    inwood customs
    Dave
    VEHICLE SPECIFIC step by step instructions WITH PICTURES
    a definate GENUINE pump
    (there are alot of fake walbros out there, and ebay isnt the best source)
    Includes:
    (2) 5/16 hose clamps
    inlet filter sock
    2 crimp connectors
    wire harness
    5/16 high pressure fuel line
    3/8 high pressure fuel line
    4 EFI hose clamps
    stainless steel wire tie
    assorted zipties
    wire loom for 3/8 line
    maybe best of all.
    URD support thru Gadget
    oh derp...............the external fuel filter is included
  8. Jan 17, 2018 at 10:49 AM
    #1368
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Everything he just said. ^^^
    Just swapping in the "ebay special" will be difficult since you'll be missing necessary components for the install. Including the longer multi-fuel rated hose.
    It cost more, but you get more, and you won't be scratching your head.
  9. Jan 17, 2018 at 11:14 AM
    #1369
    ThomasMore66
    Dallas/Fort Worth & Durango
    Oh my. 12 degF this am. New belt. Whee!! Stupid traffic.
    Biscuits likes this.
  10. Jan 17, 2018 at 11:21 AM
    #1370
    excorcist
    Reno, NV
    Gotcha. It looks like someone can probably put together this kit for around 120$... but for the convenience, and instructions it is probably worth it just to pay the extra 60$ and go with the kit from URD.
  11. Jan 17, 2018 at 11:38 AM
    #1371
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It certainly is.
    inwood customs and excorcist like this.
  12. Jan 17, 2018 at 7:44 PM
    #1372
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    It's on my list to buy too. Very impressed with urd' s customer service. I misordered a part and Steve corrected it in minutes!
    inwood customs likes this.
  13. Jan 17, 2018 at 8:03 PM
    #1373
    inwood customs
    Dave
    U best be on top of wrong orders u make.
    Sometimes gadget literally has parts on a ups/fedex/usps truck within minutes.
  14. Jan 17, 2018 at 8:04 PM
    #1374
    inwood customs
    Dave
    And i dont mean "a tracking number has been issued"... no, i mean 1 time about 30 to 45 min after i placed an order, that package was in transit
    Roostfactor likes this.
  15. Jan 17, 2018 at 8:09 PM
    #1375
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I got lucky for sure. Thanks. Didn't realize the calibrator was of no benifit with a trd tune. Still learning more everyday.
  16. Jan 17, 2018 at 8:31 PM
    #1376
    inwood customs
    Dave
    Wait, what did i miss?
    Maf cal isnt beneficial with boost?
  17. Jan 17, 2018 at 11:19 PM
    #1377
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
  18. Jan 18, 2018 at 6:15 AM
    #1378
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    If you want to try it I have one for sale shipped for $100. I gave up after I couldn't get much help from gadget with it
  19. Jan 19, 2018 at 6:43 AM
    #1379
    Chickadee
    Chickadee No, It's not my husband's truck.
    Tricia
    Colo Springs, CO
    2013 DCSB TRD OR, Spruce Mica
    OME lift, Relentless Bumpers, Supercharged, UCON
    Update: The neighbor's scanner isn't working with my phone, so I ordered an Ultragauge which should arrive today. Now I'm wondering if bad gas could actually be the culprit for my misfiring issues -- I filled at a different station & haven't had any misfires since. Hmmmm.... Could it be that simple???
    91 Octane from both stations, normal one is Diamond Shamrock, most recent is Shell.
  20. Jan 19, 2018 at 7:14 AM
    #1380
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    91? Y'all live in one a them commie states what don't get 93?
