TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 5, 2019 at 3:03 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yeah the wheel/tire combo on my other truck is 90lbs per corner. And thats with 295s. Dont even want to imagine how much my wheels and 35s would weigh
  2. Apr 5, 2019 at 3:14 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    You know there’s a middle option right? I run 295s aka 34s even though they measure only a hair over 33.5”. I’m going to regear to 4.56 or 4.88 at some point. Your quote seems high for gears. I can get a set installed with master kits on both for under $3k CAD which is only about $2.2k USD.
  3. Apr 5, 2019 at 3:17 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I do now! Thanks. Yeah. Definitely a pay to play sport.
  4. Apr 5, 2019 at 3:52 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Does anyone have input on a grease bearing packer for the bearings for all these pulleys? Trying to be proactive and not be without boost...or worse.
  5. Apr 5, 2019 at 3:53 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Solid coupling from where?
    BassAckwards likes this.
  6. Apr 5, 2019 at 4:14 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    From personal experience, I've had 33s, 34s and 35s now...i plan on wearing down the 35s, probably regearing to 4.3s or 4.10s and going either 33s or 34s. just the jump from an AT 34 to a ST Maxx 35 I lost so much power. It still gets up and goes, but I definitely noticed a power loss. And I'm STILL tubbing shit to stop rubbing. Should have just stayed with 34s. 4.56 on 35s isn't bad, but its still alot of weight per corner. 4.56 with 34s felt like I revved up way to fast. So I think 4.10 with 33s or 4.3 with 34s would probably be perfect in a 6 speed.
    DoulosXP, DocME, zerotimeouts and 3 others like this.
  7. Apr 5, 2019 at 4:15 PM
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    Anyone have a write up or video on how to remove the gears to inspect the supercharger? We want to take a look the bearings and etc to see if there is something we don't see.
  8. Apr 5, 2019 at 4:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks for your feedback!
  9. Apr 5, 2019 at 4:16 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I don’t think so. Bearings are bearings and they can only spin 15k so many times.
  10. Apr 5, 2019 at 4:19 PM
    VolcomTacoma
    Jeff
    NorCal
    Currently waiting on a mechanic to call me back. Transmission took a shit on me. Guy think either catastrophic failure (trans replacement) or the clutch disc exploded or something lol. I can put it in gear just fine, no difference in clutch pedal, but when I put it in gear and let out the clutch, I can hear a whirring/slight grinding from the trans and get zero power to driveshaft. I think he said maybe clutch hub broke apart on the shaft or something like that. I dunno. I just called and they said they are in process of of removing trans right now.
    TodayWasTHeDaY and Athlaos like this.
  11. Apr 5, 2019 at 4:19 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I would really appreciate a full bearing list on page 1. I want to buy all new to be certain. @12TRDTacoma, can you help with this?
  12. Apr 5, 2019 at 4:20 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I cant hit the like button on this man. Sorry to hear.
    mr.trd likes this.
  13. Apr 5, 2019 at 4:30 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So after a week of watching gauges I have some temp info. In the 60* temps I have currently thr front heat exchanger does its job even with a 2.5" pulley. My 30 minute commute in the morning with basic driving and a few power bursts keeps the post intercooler temps at ambient. In the afternoon temps are 5* above ambient with lots of idle through traffic and the occasional burst. Bottom line, front heat exchanger is totally adequate unless you buy a chill box to make sub ambient temps in the intercooler possible.
    12TRDTacoma[OP] and Roostfactor like this.
  14. Apr 5, 2019 at 4:31 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah's its shitty, I had no warning, driving along just fine, no clutch slippage at all, go to accelerate around someone, all of a sudden *CLUNK* and everything rev bombs, no power. was able to limp off the highway, kept it in second gear and just cruised, anytime i tried to give it any power more than maintaining speed it would rev up with no power. Was forced to stop about 2 miles from home, after that it just quit on me, had to tow it home.
  15. Apr 5, 2019 at 4:31 PM
    VolcomTacoma
    Jeff
    NorCal
    Praying its just a clutch replacement.
  16. Apr 5, 2019 at 4:32 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    zerotimeouts and Norton like this.
  17. Apr 5, 2019 at 4:33 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Well, shit man. I hope it's a clutch disc.
  18. Apr 5, 2019 at 4:33 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah that's an easy 1k instead of like 4K+ for a new trans :(
  19. Apr 5, 2019 at 4:35 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Trust me, I feel your concern with cost of breakage. I'm 5 years away from paying my truck off. A deal like that would be no good here too. I'm getting clutch failure by your description of circumstances.
  20. Apr 5, 2019 at 4:37 PM
    VolcomTacoma
    Jeff
    NorCal
    IS your clutch slipping? Stock clutch?
