TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 8, 2019 at 1:50 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I guess my sarcasm was lost :D
  2. Apr 8, 2019 at 5:24 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I know that when I require a rebuild, I’ll be getting the stroker kit. Cams, well, might find a place that can grind the lobes a bit because yeah, there doesn’t seem to be much out there. I drew the line at internals too - but all’s fair when the stock ones fail or it’s just that time. Which, could be a while yet. Or, not.
  3. Apr 8, 2019 at 5:31 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Balboa :D
  4. Apr 8, 2019 at 5:32 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Can you fill the uneducated in? I've heard of this Balboa dude on/off.. Whats the scoop?
  5. Apr 8, 2019 at 5:40 PM
    TRON
    Texas dude that got in tight with APR. One of the first to do APRx1 and e85. APR designed and made a few back mount turbos for our xrunners. So Balboa decided he wanted both. The plan was to build internals, keep the TRD Blower and have the back mount turbo too. Not quite sure what happened but I think he ended up with a Ford RS.
  6. Apr 8, 2019 at 5:41 PM
    Athlaos
    Leigh
    Edmonton
    He must have forgotten to install water meth injection.
  7. Apr 8, 2019 at 5:43 PM
    TRON
    E85 burns pretty cool. E85=110 octane or so
    12TRDTacoma[OP] and JustDSM like this.
  8. Apr 8, 2019 at 7:08 PM
    Athlaos
    Leigh
    Edmonton
    Oh. I somehow missed the e85 mention in that post.
  9. Apr 8, 2019 at 7:35 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Did you go with an ARB in the front end? If so the inner seal to the ARB is leaking and filling the housing with air and pumping the fluid out of the breather. Mine is doing the exact same thing. ARB is covering it under warranty but I still have to pull it from my truck, ship it back to ECGS, they will fix it in a day, then ship it back to me, then put back in the truck. So the truck will be down for a couple of weeks or I stuff an old front diff in and just know I can drive but not use wheel drive. The way I found out that the housing was getting pressurized was the ARB compressor started turning on to keep the locker engaged about every 10-15 seconds. Unlike when I first installed it and broke the front gears in and played in the sand for over 3 hours and the compressor cycled maybe 5-6 times the whole time and that was usually because I stopped to let the gears cool and turned the truck off.
    zippsub9[QUOTED] likes this.
  10. Apr 8, 2019 at 7:39 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yes, the compressor cycles frequently once I open the solenoid to the diff. I can hear air pissing out of the breather. I think I may have also overfilled slightly, since Imhavent engaged the front locker in quite some time yet still have some fluid weeping on the breather line. I did not have ECGS do the install but I may have them fix it. I am moving in two months about twenty minutes down the street from ECGS. My wife doesn’t understand all the money we are going to save on freight here before long.
    mr.trd[QUOTED] likes this.
  11. Apr 8, 2019 at 7:40 PM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    And I am late to the game as usual. LOL I guess I should catch up and then decide if I need to help. But yeah Chase said he has been doing a lot of them. I told him I couldn't send mine back until after winter was over since I didn't want to be without 4 wheel drive in a snow storm. He told me no worries, ARB knows there is and issue and I will be taken care of. ECGS is great to do business with. And I stock his front diff bushing here at the dealership. Because it works.
  12. Apr 8, 2019 at 8:21 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    New name to me. Still don’t want to go e85. I don’t even know where to get it in Dallas. Not a reliable source of fuel. H rods and a forged crank sound like a good idea.
  13. Apr 8, 2019 at 8:22 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    :stirthepot:
  14. Apr 8, 2019 at 8:24 PM
    ThomasMore66
    Can we get to 500 hp with the striker and some rpm?
  15. Apr 8, 2019 at 8:37 PM
    ThomasMore66
    I think we need a HP Tuner thread. I don’t have one yet, but I think this seems the way to go. Any thoughts yet?
  16. Apr 8, 2019 at 8:45 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
  17. Apr 8, 2019 at 9:05 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    This is why I want to go with a Harrop elocker over an ARB airlocker when I regear. So much less to fail. I will say I’ve been impressed with my Trutrac in the rear on and off road.
  18. Apr 9, 2019 at 6:39 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I was going to swap to a Harrop. I’m kind of over ARB at this point. I had ECGS put an OX in the 60.
    BUT... Chase told me the Harrops are weaker than ARBs. So, I’m going to give the ARB one more shot with the new seal.
  19. Apr 9, 2019 at 7:07 AM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I don’t see how that would be a problem given the CVs will grenade long before the differential. Interesting though since I heard it the other way around from some reviews.
  20. Apr 9, 2019 at 7:11 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    The only CV damage I typically see are torn boots. I guess the theory of an intentional sacrificial part would make sense to be the CV but it seems the diffs.
    12TRDTacoma[OP] likes this.
