TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 10, 2019 at 5:15 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Isn't that what the URD thrust bearing upgrade does? adds the steel sleeve?
    BassAckwards[QUOTED] likes this.
  2. Apr 10, 2019 at 5:19 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    All the cool kids are on hp tuners thread. I also have no idea about tuning. But I’m very interested and very eager to learn. I can’t wait. It’s scary to think about but everything is until u understand it
  3. Apr 10, 2019 at 5:23 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Yes. Its learning at the expense of my motor that concerns me.
  4. Apr 10, 2019 at 5:23 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I bought one too.
  5. Apr 10, 2019 at 5:25 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I second that, I bought one too. At least the MPVI2 wireless module.
    I'll get a tune ironed out for me and move forward as I go. Baby steps, but this is how it starts. :)
    And in other news, upgrading post Y pipe to 2.5" exhaust and replacing the muffler to a different brand on Friday. I can't wait for the new sound and potential power gains. :)
    Possible video with updated truck exhaust sound, and some whinage for you folks. ;)
  6. Apr 10, 2019 at 5:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes but the problem with E85 is that at any given fill up there can be an inconsistency in the fuel. So if the fuel is E50 or E60 and you are tuned for E85 specifically you can potentially grenade a motor.
    I have actually read tons of stories regarding grenades motors due to poor E85 fuel quality.
  7. Apr 10, 2019 at 5:31 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yikes. I'll stick with premium and meth. Sounds safer. Ups just dropped off the shroud. Damn, box is big enough for me to fit in. Some mammal in shipping isnt so bright.
  8. Apr 10, 2019 at 5:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah, that is actually what ultimately turned me away from E85, as I had intentions of wanting to have the ability to run dual switching tunes which I could either change or automatically detect on the fly. Not worth it as much boost as we are pushing now. I'll rather stick to tried and true standard octane fuels. Sometimes less is more.
  9. Apr 10, 2019 at 5:41 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    For a full s/c rebuild I'm going to have a shop do mine. Do I just need to have a stock intake plenum so I can still drive it?
    Athlaos likes this.
  10. Apr 10, 2019 at 5:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes you would, but honestly a full rebuild would just take a few hours. So why would you revert back to NA temporarily?
  11. Apr 10, 2019 at 5:44 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So I could ship it away to be ported as well.
    JuanitoBonito likes this.
  12. Apr 10, 2019 at 5:44 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Not sure if any Seattle shops could do that correctly.
  13. Apr 10, 2019 at 5:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh... I understand what you mean now.
    I don't see a necessary need in doing so as Eaton has proven their Gen 5 roots blowers to have maximum airflow from the gate.
    Now the OE lower intake plenum... hell yeah, that could use work for sure.
  14. Apr 10, 2019 at 5:50 PM
    ThomasMore66
    Hmm. FOMO. What shop? Next we’ll be back to stroker stuff with beefy rods.
  15. Apr 10, 2019 at 5:53 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    It was a ways back in my methanol thread someone with a first gen had his s/c ported with great results. Maybe I'll call them and see if its fact or fiction for us.
  16. Apr 10, 2019 at 6:00 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    If you got the URD upgrade kit then yes, thats all you need
  17. Apr 10, 2019 at 6:53 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    The only thing I had done to my supercharger in Seattle was a recoat with cerakote.
    All porting my guy had outsourced to other shops. One in CA and the other was steigemeier.
  18. Apr 10, 2019 at 7:01 PM
    VolcomTacoma
    Jeff
    NorCal
    I was gonna say, Steigemeier wouldn't be in business if Eaton ported their blowers for perfect airflow.
  19. Apr 10, 2019 at 7:04 PM
    VolcomTacoma
    Jeff
    NorCal
    Also, might have to make the kids move into the living room and blow out their rooms to make a 2 story garage so I can get a lift in here. Amazing the shit you notice when a car's on a lift. Noticed my brand new blower belt had a small fray on it, looked around, saw belt had popped one rib over on one of the pulleys, must have been slowly grinding on that side.
    TLDR I need a truck lift in my garage.
  20. Apr 10, 2019 at 7:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Kids like camping it the yard right?
    BassAckwards likes this.
