TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 20, 2018 at 9:09 PM
    #1401
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    No worries mate...a lot of knowledgeable peeps here.
    UCON has been the only viable aftermarket tune until recently. Bullydog worked with Magnuson to develop a tune to support the supercharger after TRD discontinued them. Now OV Tune is coming out with a tune since the factory tune had been unlocked. The OV Tune has promise but is not proven yet.
    Hope this helps.
  2. Jan 20, 2018 at 9:46 PM
    #1402
    oni06
    oni06 Well-Known Member
    If you buy the Magnuson SC you get a bully dog. But it is only used to load the pre determined tune. You can't actually tune it with the unit. Pretty much like the TRD flash. It's preset and you can't change it once it's loaded.
  3. Jan 20, 2018 at 9:49 PM
    #1403
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    @White lightning boosted also, you do have the option to NOT get the BD tune with the Mag S/C from URD. It knocks some $$ off, then I just turned around and applied to the UCON.
    Roostfactor likes this.
  4. Jan 20, 2018 at 9:49 PM
    #1404
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I bought my taco with the trd supercharger that was dealer installed. I really don't know what tuning it has. I'm learning baby steps
  5. Jan 20, 2018 at 10:01 PM
    #1405
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2022 Raptor
    You can then safely bet that you have the TRD flash.....
  6. Jan 21, 2018 at 5:37 AM
    #1406
    oni06
    Sorry I missed the fact that you already have the TRD charger installed.
    Like @JuanitoBunito said you most likely have the TRD flash.
    If you get the UCON I would still get a new unflashed ECU.
  7. Jan 21, 2018 at 10:40 AM
    #1407
    Roostfactor
    TX panhandle
    Or alternatively wait until more info comes out on the OV Tune. They will be able to reflash the ecu.
  8. Jan 21, 2018 at 10:43 AM
    #1408
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm practicing patience. Still feel like a 5 year old waiting for the answer on when we're going for icecream!
  9. Jan 21, 2018 at 10:57 AM
    #1409
    Roostfactor
    TX panhandle
    What is it you are waiting for?
    If you are looking for more performance then I would suggest developing mod plan and upgrade in that order so you aren't buying parts more than once.
    For example, I have the URD 2.85 stealth pulley now but am going to get the quick change setup so I can play with boost levels MUCH easier. (The quick change pulley was not known to fit at the time I purchased my 2.85.) Big shout out to @12TRDTacoma for pioneering this.
    1st thing I would do if I was you is upgrade your valve body. With 35's and a sc your tranny is in duress.
  10. Jan 21, 2018 at 10:59 AM
    #1410
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    What size are you going to get for your quick change pulley?
  11. Jan 21, 2018 at 11:04 AM
    #1411
    Roostfactor
    TX panhandle
    Still deciding, probably 2.6. I have some other ideas I'm considering as well that are based on efficiency so a 2.6 may make more power than a 2.5 with supporting mods.
    Mods for me are currently on hold as I am military so I am not getting paid right now.
  12. Jan 21, 2018 at 11:07 AM
    #1412
    Jesse
    Poulsbo
    15' DCSB OR S/C
    My plan is next week installing urd tcai, then methanol injection, pulley (2.8), then afr gauge and fuel pump. Direction on where to buy/ install tranny support would be greatly appreciated. I do have a great warranty. If I nuke something I'm out only a 200 dollar deductable.
  13. Jan 21, 2018 at 11:17 AM
    #1413
    Roostfactor
    TX panhandle
    1st page of this thread. Look for Ratiotek hd kit for a750e and a750f.
    Did you already order the urd tcai? Mine might be for sale soon.
  14. Jan 21, 2018 at 11:24 AM
    #1414
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes, it's here in 2 days. May I ask why you're selling yours?
  15. Jan 21, 2018 at 12:24 PM
    #1415
    Roostfactor
    TX panhandle
    Part of my upgrade path. It's a nice kit but if I was you I would get the shield and outer filter skin for it. Especially since I imagine you get a fair amount of rain where you are.
    I may get rid of mine because I might go larger diameter intake tubing. A whole redesign of my intake. You have to be careful with this though because the MAF sensor is sensitive to intake tube diameter changes and will make the truck run rich/lean if setup incorrectly.
  16. Jan 21, 2018 at 12:27 PM
    #1416
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks for the tips. I'll do that.
  17. Jan 21, 2018 at 6:16 PM
    #1417
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Bully Dog Flash alone = Lean/Suck
    TRD flash alone = Rich/Decent
    UCON + TRD Flash = Suck
    UCON + Bully Dog Flash = Suck
    UCON + Stock ECU = Golden
  18. Jan 21, 2018 at 6:18 PM
    #1418
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks for the clear and honest breakdown!
    inwood customs and loginfailed like this.
  19. Jan 21, 2018 at 6:53 PM
    #1419
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Hmmm, just bought a bullydog tuner to run with the s/c so I didn't have to re-flash, curious how you came to the conclusion it ran lean / sucked? Not doubting you at all just would be interesting to read for myself.
  20. Jan 21, 2018 at 6:55 PM
    #1420
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Possibly
